Question about Samsung HL-S6187W 61 in. HDTV
CABLE AND SATRELLITE TOGETHER
I WANT TO BE ABLE TO HAVE THE SATELLITE AND CABLE TOGETHER
  • 54 Answers
Hook up the cable box to component # 1 or hdmi 1 and the satelite reciever to component # 2. i'm not sure if this model has 2 hdmi inputs,but you can also hook the satelite reciever to hdmi 2 if it does.
Posted on Jan 19, 2009
Printer not connected to computer
If you are using Windows you will get a chime sound when you plug & unplug a usb cable. I would try using a different USB port on the laptop and see what happens. Did the dog/cat/hamster chew on the cable maybe? I would also try another USB A-B cable.
Mar 08, 2014 | Kodak Office Equipment & Supplies
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
Took the comp. apart an put it together but the screen wont come on now, how do i fix it ?
Chances are the video cable became disconnected during your assembly. Recheck your cable and assemble the system carefully. Reboot.
Good Luck
C2Solutoins
Jan 18, 2011 | Toshiba Satellite L25-S119 Notebook
How do i connect,tv,vcr,and satellite box together,so they will work together?
Hi. I can help you. Run cable from the out on the satellite box to the in on the vcr.
Then run a cable from the out on the vcr to the in on the tv.
if you don't have the cables you need you can obtain them at a radio shack, a walmart, even a home depot or a lowes
Jul 04, 2009 | Televison & Video
Can sirius antennas be cut and spliced back together
If your antenna cable has been cut or severed, it can be repaired without the need for a replacement.
You will need the following things:
Small 600 degree soldering iron and solder.
Liquid flux for soldering the braid.
Small sizes of heat shrink tubing.
Small heat gun.
Small pliers, cutter, and Xacto knife.
1) The first step is to use the Xacto knife to cut both ends of the antenna cable so you have a clean end.
2) Using the Xacto knife roll the cable on a board and gently cut all around the cable to cut the outer insulation. Remove about 1/2 inch of the insulation from each end.
3) Push the braid back to expose the center wire and gently roll the cable and cut the center insulation to expose about 1/10 inch of the center wire. With your small long nose pliers, bend the center wire into a small hook shape.
4) Repeat all the above steps on the other end of the wire.
5) Put a 1 inch piece of heat shrink tubing on one end ( the black piece), and a 1/4 inch piece of heat shrink (the white piece) on the center conductor. Look at the picture to see this.
5) Hook the two ends together. Gently squeeze the hooks closed and solder them together. Be very careful when soldering this. Be quick so you do not apply to much heat and cause the heat shrink tubing to shrink on the side where you do not want it to be.
6) Slide the small white heat shrink to cover the cooled solder joint you just made and use the heat gun to shrink the tubing in place.
7) Now push the braids back together to cover over the connection you just made. Try make the braid smooth together by GENTLY rolling the cable between your fingers. Carefully solder the braid. A little liquid flux on the braid prior to soldering helps the solder flow and makes it look better.
8) Slide the final piece of heat shrink tubing over the braid and shrink it with the heat gun.
Jun 12, 2009 | Sirius Satellite Radio Receiver
I have satellite broad band on the host computer with a lap top via belkin.how do I connect the two computers together as a net work sharing printer internet etc?
Hi and welcome to FixYa,
With the indulgence of jmichelsen4, two ways:
  • a router if the satellite modem uses Ethernet port;
  • a hub or crossover cable if the satellite modem uses USB port on the host computer.
Good luck and Thank you for using FixYa.
Dec 07, 2008 | Computers & Internet
Lightning strike
press menu and input both in together on the front of the TV and hold them both in together for 8 seconds then let me know if the LED blinks a two digit code.
Jun 10, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Samsung HL-S6187W 61 in. HDTV Logo
55 people viewed this question
Jerry Greenberg
Jerry Greenberg
