Question about Smith Corona Wordsmith 100 Typewriter
Advancing the paper
My wordsmith 100 will not advance paper at the end of line . Platen (sp) does not move at all
  • Anonymous Feb 07, 2009
    We cannot get the paper release lever to lock, therefore the paper does not advance when we press the return key, what do we do?
    Scholar:
  • 75 Answers
I need ti know if you turn the platen knob with the power on is there any hasitation or is it free wheeling. if it's free then the motor belt is broke or a gear has snapped. if there is hasitation it may just need some light oiling on the bearings. turn the type off turn the platen if fills hard lightly oil both shafts at eather side of platen by side frame. hope this works
C.W.H.
Posted on Jan 23, 2009
The roller does not hold paper tight so will not roll or advance
on either end the platen roller has collars, some you can sqeeze and lift the roller out.some have release and turn type mechanism. under the platen roller there are several smaller rollers . 6 to 8. inspect this area for foreign debris. clean with 70% alcohol. reseat the platen roller and test.Platen will lock in if not its in that latch.the worst case is you have a broken gear.
Jul 24, 2015 | Brother Ml-100 Electronic Typewriter -...
Why does paper not advance to next line when carriage returns?
There might be a setting for how many lines it moves when the carriage gets to the end. It is mechanical so you'll see it!
Sep 01, 2014 | Office Equipment & Supplies
WP3400 & AX-12M
  1. Is the daisy wheel locked in the forward position?
    1. Pull the black lever back, away from the platen.
    2. Lift out the daisy wheel and inspect it for damage; replace the daisy wheel if it is damaged.
    3. Re-insert the daisy wheel and push the black lever towards the platen until it locks in place.
  2. Is the ribbon moving?
    1. Lift the ribbon cartridge out of the typewriter
    2. Inspect the ribbon for damage
    3. If the ribbon is silver, it is exhausted and must be replaced
    4. If the hammer has been striking in one place, there will be a clear area near the center of the ribbon.
    5. Turn the colored knob on the left side of the ribbon cartridge counter-clockwise to advance the ribbon a small amount. Replace the ribbon if it will not advance.
    6. Re-insert the ribbon
  3. Turn on the typewriter, insert a piece of paper into the typewriter and type a few letters
    1. Did the hammer move forward?
    2. If the hammer moved, did the ribbon advance with each keystroke?
If the hammer did not move or the ribbon did not advance, the typewriter will require service. If the typewriter still does not make an impression on the paper, your typewriter will require service.
Dec 09, 2013 | Brother Office Equipment & Supplies
How to make the paper move to the left to begin tying on a 1932 remington typewriter
The platen is the (usually black) cylinder around which the paper is rolled. There is a carriage return lever mounted at the left end of the platen, which needs to be pushed inwards when the line is finished to move the paper into position for the next line.
Jun 04, 2011 | Computers & Internet
The platen does not turn to advance the paper to the next line when typing so each line is just typing over the next.
Remove the platen by squeexing the black plastic retainers at both ends of the platen and lifting it out. Look for debris under the platen, press paper up key and see if the gear on the left end is moving, if it is the gear on the platen may be broken (new platen) or if someone has been in here check to be sure the paper tray is properly installed (rounded edge to the rear).
DickyO
Apr 08, 2009 | Lexmark Wheelwriter 3 Typewriter
Daisy wheel will not stay on wordsmith 100
CHANGING Changing The Ribbon Cassette 1) Move the print carrier to the center of the platen using the SPACE or BS key. 2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette. 3) To insert a new cassette, place the back end of the cassette on the cassette holder on the carrier and gently press down on the front of the cassette unit it clicks into place. 4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon. 5) Presss the CODE + = (SETTING) key.
Changing The Print Wheel 1) Move the print carrier to the center of the platen using the SPACE or BS key. 2) You will see a lever on the right side of the carrier. Pull this lever toward you and lift out the daisy wheel. 3) Place the daisy wheel into the slot with the characters facing the platen. 4) Push the lever back into position. 5) Press the CODE + = (SETTING) key.
It appears as though you have something that is preventing the print wheel from being locked in place by the release lever. It should make a snapping or similar noise when it is locked down.
Dec 10, 2008 | Smith Corona Wordsmith 100 Typewriter
Wheelwriter 30 paper advance
The paper release lever may be in the release mode. try holding the left platen knob and pulling lightly on the paper is should not allow the paper to move freely, if it is ok try holding the left knob and turning the right knob in the direction you would to turn the paper in it may have come loose if so turn it all the way back in do not over tighten it your machine does not click when the platen is turned it uses electronics to hold the platen on line.
credits : JUSTOLDJIM
thank you
Aug 08, 2008 | IBM Wheelwriter 30 Typewriter
Smith Corona 235 DLE doesn't advance
Does the platen move or does the paper not advance? Check the paper release lever to make sure the feed wheels are snapped in place. If the platen does not move something in the paper feed motor area.
Jul 28, 2008 | Smith Corona Wordsmith 200 Typewriter
Paper advance
Dec 13, 2007 | Office Equipment & Supplies
PAPER WON'T FEED THROUGH
The tension spring has probably come loose I can e-mail you a copy of the platen removal and replacement page from the repair manual jcagle12@msn.com
Nov 07, 2007 | Smith Corona Wordsmith 200 Typewriter
Smith Corona Wordsmith 100 Typewriter Logo
83 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Jim Keysor
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
