Rexel +100 auto feed shredder cover sensor issue
The sensor for the top cover appears to be faulty causing the shredder to not function. If the top cover is closed with force there is no cover open light and it works. Also if the machine is powered off then back on with paper in it will also work. Once the top cover is opened to load paper the cover/drawer open error is active again.
5 Suggested Answers
  • 883 Answers
SOURCE: Paper Shredder will not shut off when in auto mode
if you answer no to the following question, then I do know your solution: Q: When you unplug the unit immediately after your action of "When those paper complete the shredder does not turn off."...and then plug it back in, does the shredder STILL continue to operate? if no, then the solution is to disassemble the feeder unit and manually unclog the paper sensor.
Posted on Jun 14, 2007
fellowesrep
  • 102 Answers
SOURCE: Rexel rdx1750 shredder jam
This is the available numbers for ACCO Rexel 0845 658 6600 or 01296 732466/732468 in the UK or you may contact by email mailto:informationeurope@acco.com and this is the web address http://www.acco.co.uk/
Posted on Mar 06, 2008
  • 35 Answers
SOURCE: Shredder runs continuously in AUTO position.
There are three reasons why:
1. paper particles or oil are still causing the optics to think you are inserting paper. Remove cover and clean thoroughly!
2. Optics are misaligned.
3. Optics are defective.
Posted on Feb 23, 2009
  • 35 Answers
SOURCE: Old Rexel 1250 - falsely detecting safety cover is open
You'll have to unplug the machine, then remove the screws front (inside door or cabinet) and rear to remove the top cover. Insure that the safety cover arm which contacts the microswitch is not broken or the microswitch is out of adjustment.
Posted on Mar 03, 2009
Wont automatically feed paper to shred
there is a small switch or an infra-red sensor that sees the paper. Check it in the slot of the shredder.
Paper Shredder Parts
shredderparts.com/
We sell all sizes of paper shredder gears, switches, blades, etc. to facilitate your repair. We also have shredder replacement parts for crosscut paper shredders, ...
General Shredder Parts - Shredder Repair Services
www.shredderrepair.co.uk/general-shredder-parts-227-c.asp We can supply a wide selection of parts for various makes of shredder some of the ... Paper Shredders ... Please note SRS take no responsibility for loss, damage or personal injury caused by the fitting of spare parts by non SRS personnel.
Paper Shredder Parts ' All brands inc Fellowes & Rexel ยป Document ...
https://www.documentdynamix.com.au/service/paper-shredder-parts/ Document Dynamix Australia has a strong reputation for responsive supply of paper shredder replacement spare parts and support. Whatever brand your paper ...
Jul 17, 2017 | Cars & Trucks
No power. Seems to be overloaded
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Oct 25, 2013 | Office Depot Ativa DSD160D Shredder
Wont turn on
Oct 01, 2013 | Cross Infoguard Shredder SX102M
Rexel shredder
Spray with WD-40 or similar lubricant/release agent and let it soak for a while, the remove anything that's jamming the sensor with tweezers and switch the unit on and keep cycling between auto and reverse for a minute or two until unit gets unjammed. Then to reduce friction and to protect the blades use some oil in the feed opening, especially after using WD-40 Good luck
Oct 01, 2013 | Office Equipment & Supplies
The shredder is totally inoperable
Sep 17, 2013 | HSM Office Equipment & Supplies
Staples SPL -TXC15A Shredder on all the time
This is what worked for me.
1) unplug the shredder
2) put the selector in "auto" position. This pulls back the guard which blocks the paper and hids the sensor.
3) a little right of the center of the paper slot is the sensor. You can feel this by inserting a cotton swab in ths slot.
4) put some alcohol on the cotton swab and clean the sensor!!!!
Also the "bin full" sensors are under the shretter head. You can easily see those when you remove the head from the bin by flipping it over. I would advise cleaning those while you are at it. Mine were covered with dirt and dust.
Hope this helps!!
Tommy
Sep 06, 2012 | Office Equipment & Supplies
Rexel RSS1627/RSX1227 Red light always on when
I have an Acco Rexel RSX 1227 shredder. Can you use any oil to oil the shredder or must it be a special oil
Aug 22, 2011 | Office Equipment & Supplies
We have a rexel shredder 250 but i wont work,
Either your shread bin is full or the sensor is dirty. Blow out with canned air.
Dec 10, 2009 | Office Equipment & Supplies
Oct 24, 2008 | Office Equipment & Supplies
Mar 01, 2008 | Office Equipment & Supplies
51 people viewed this question
k24674
jasbo
jasbo
