Question about Canon PowerShot S50 Digital Camera
Sliding Lens Door Problem -- Canon S50
This seems like a nice camera, but half the time it seems like the door won't slide shut and the lens won't retract. One has to be very patient. It feels like the sliding door is loose or "off the track" but unfortunately, it's not obvious how it's attached, but when it's almost closed, it's very wobbly. Something is not right about the way it slides.
  • pfc0 Mar 17, 2009
    Lens door on front of camera won't slide enough for lens to come open.
    The lens seen to slide sideways.
  • hillar May 01, 2009
    I now have the same problem. Your description of the problem matches mine exactly. I bought my S-50 new and have been ever so gentle with it. I had read of this problem when I bought it but shrugged it off as being a problem only experienced by "bulls in china closets".
    Seeking a solution. Having fixed many a screw mount Leica, I'd be happy to tackle the job on my own camera, given one could get some exploded view diagrams of assembly/disassembly.
    Contact me via hillarsphotos.com posted May 1,'09
  • 3 Answers
I had the same problem with a S50, where the lens door would not operate properly and would not open enough to cause the camera to activate. I took it apart and found that there are two small gears that keep the door on track, one had split in half and jammed the mechanism. They were white plastic, perhaps nylon? I found another S50 on ebay with broken electronics but a working lens door and took parts from it to fix my system. Getting the tiny gear in place was tricky as there are several springs used to activate the camera on switch.
Posted on Jan 21, 2010
I have the same problem as you said for a while. Now it totally can not retract the lens. I wait for the camera time out and remove battery.
Posted on Dec 30, 2009
Hi I am using ps50 canon digital camera.But coming in airplane and opened my camera ,could not activate the lens. I tried to slide it slides but lens could not come out. Once again i further tried some black small red broken and come in my hand. Plz suggest my camera can be repaired or not.
Posted on Jan 11, 2012
Canon powershot S50: Sliding door stuck.
this can happen,gently tap the door(GENTLY) may loosen it works on my a70
Aug 18, 2009 | Canon PowerShot S50 Digital Camera
Turns off due to sliding lens cover
may need to replace the screws in the door or even tighten them up
Dec 30, 2008 | Olympus Camedia Stylus 300 Digital Camera
Canon Powershot S50 -lens extends and then retracts
There is a common problem with the A series Powershots, that the lens assembly jams in the telescoping zoom, or in the digital imaging module, in which the lens assembly has to be replaced. I'm not sure if the S series has these issues. You can check with Canon support to find out.
Aug 08, 2008 | Canon PowerShot S50 Digital Camera
Canon sliding lens cover door
I have been having the same problem. Once opened, the sliding door will not close and the lens won't retract. But I have found that if you plug the camera into a computer via a USB, the lens then retracts enabling you to close the lens cover.
I'm still trying to find a way to fix this problem, since this is a great camers and still takes fantastic pictures.
Apr 21, 2008 | Canon PowerShot S50 Digital Camera
Lens cover slide stuck closed
Take a butter knife and slide it where the crease is. move the close/open button till it open it could just be stuck due to moisture. Hope this helps.
Mar 09, 2008 | Canon PowerShot S70 Digital Camera
Canon S50 Not working
Kgiangus and others....
Try using some canned air around the lens housing and lens door.
Dec 02, 2007 | Canon PowerShot S50 Digital Camera
Shutter v soft
Are you talking about the sliding door that powers on the camera and covers the lens?
There is a metal plate with two screws on the bottom of the sliding door that holds the door to the camera, try tightening the screws and see if that helps. Or else see if the door is slightly bent out of shape, and try to bend it back if you can.
This is a common problem on the Stylus-300 camera, you can buy a replacement door from eBay -
http://cgi.ebay.com/Olympus-Stylus-300-Camera-Parts-Repair-NEW-LENS-BARRIER_W0QQitemZ250147262921QQihZ015QQcategoryZ64352QQcmdZViewItem
Nov 19, 2007 | Olympus Camedia Stylus 300 Digital Camera
Lens will not retract
In my case, there was dust in the switches that sense the cover movement.
  1. Close the sliding door and wait until the lens is drown inside (timeout).
  2. Open the screws that secure the front cover.
  3. Remove the sliding door covering the lens. There is no trick (hidden screws etc) so just use the force. The door is mounted by two-sided tape and adhesive.
  4. Remove the front cover. This is also mounted by two-sided tape / adhesive in the center, so you have to be a bit brave.
  5. The sliding door rails and the movement sensors are now visible. Clean all dirt.
  6. Try the door functionality.
  7. Mount the front cover after the lens works as it should. Close the screws.
  8. Mount the sliding door.
May 27, 2006 | Konica Minolta DiMAGE G400 Digital Camera
The slide doesnt open
Contact this site as theres as well a toll free Tele # Good Luck http://www.nikoncamerarepair.com/
Apr 09, 2006 | Konica Minolta DiMAGE G400 Digital Camera
Slider Prob
Dang, what a weird design. The lens needs to go threw a cycle before it can reach the idle position where it waits for a comand from the user. If its in the closed position and you turn it on it extends to its full range then stops at the idle position. It sounds like it is stuck in some spot between close and idle. Since it cant reach the closed position or idle its shutting down. The only way to get it to work is to try and free the lens so it can cycle threw. There must be a lip on the slider and the lens is stuck on this lip so you cant slide it. Remove the batteries then try and slide the door open try and slide somthing between the lens and the door to free it up. This is the only way to get it threw the cycle. It may need to be serviced It sounds like the switch for the slider door is warn or has broken. It may work again if you can free the lens.
Aug 31, 2005 | Canon PowerShot S30 Digital Camera
Canon PowerShot S50 Digital Camera Logo
1,083 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
