Question about Dayton (3C674) Fan
Fan runs for 15 seconds, then cuts off. - Dayton (3C674) Fan
Homelite gas edger cuts off after running about 10-15 seconds
The fact that is runs slightly longer on full choke may point still to a fuelling issue.. Does it actually Rev in those 10 seconds or does it just want to bog down and stall.?
May 18, 2016 | Homelite Garden
Why does my fan stay running for more then 90 minutes until the battery goes dead
Radiator fan runs continuously - volvoXC.com
www.volvoxc.com > Forum > The Vehicles > 2001-2007 XC70 (V70XC)
Jul 12, 2011 - 10 posts - ‎6 authors Hi, I have a problem with the radiator fan running continuously. ... According to Volvomechanic, when the pressure in the aircon gas goes ... 2002 xc70 cooling fan stays on
Jul 15, 2012
Blower Motor stays on.
Jan 15, 2011
fan after cutting off ignition?
Jul 25, 2004
More results from www.volvoxc.com
Oct 20, 2015 | Volvo S80 02 2002
Diplomat Gas Oven cuts off after few mins
The oven is probably overheating and shutting itself off to prevent damage/fire. If the cooling fan isn't running. Check/replace the thermostat that switches the cooling fan on.
Aug 02, 2014 | Hotpoint Diplomat Oven Grill Selector...
I have a Samsung rs21!!! it wont cool in either compartment. when I plug it in the compressor fan does a quarter turn then stops. the compressor runs for about 30 seconds then cuts out? any ideas plea
most likely the start relay on the compressor that changes from start windings to run windings. the compressor will run for about 30 seconds on start windings then click out on internal thermal overload.
this can be confirmed by turning it on and letting it do the 30 second run then when it stops just wait and see if it cuts in and tries to run again (usually takes about 5 min) the second time it cuts in it wil most likely not run for as long (usually about 10 seconds). if this is what it does get a new compressor start/run relay.
as for the fan flick it with your finger and see if it spins freely.
Jun 05, 2014 | Samsung RSA1SHPN American Platinum Inox...
My AC unit runs for 15 minutes the cuts off. Then there is no
Hello, if there is a condensate safety switch this will cut off power to the tstat if the comdensate line is backed up. Check the condensate line to make sure it is clear.
May 06, 2012 | Heating & Cooling
GE Profile Side-by-Side running warm
If it's cutting off at too high a temperature it is a good possibility the probe is faulty. However if the compressor is not cutting off at all, suspect short of gas.
Apr 24, 2012 | Refrigerators
York Diamond 80 furnace (propane conversion), about 1998 model. Solid Ignitor comes on, but no flame. Main fan works for about 90 seconds then cuts off. Fan only switch on thermostat does the same, fan...
Check for 24 volts across the two terminals on the gas valve when the ignitor glows. If yes, bad gas valve or blockage in the gas train. If no, bad ignitor or circuit board. Even if the ignitor glows, it still may be bad and not sending the proper signal to the board. If you jump the R and G terminals on the circuit board, does the fan still only run for 90 seconds? If so I would say replace the board.
Dec 28, 2009 | Heating & Cooling
Aeg oven d4100 cutting out
There is a cooling fan in the cabinet of the oven which is not working either the fan is faulty or the controling cut in stat is, The fan should run when the grill is selected if does not it is more likely to be the fan/motor at fault.
Dec 07, 2009 | AEG D2100-4 Electric Double Oven
Fan continues to run after desired heat is established , I blew out the line at pilot and the unit is taking 10 to 15 mins for fan to cut off
Looks like your fan limit switch may be bad. It fits into the warm air side of the furnace. It tells the fan to come one and off when the heat is blowing over the limit switch. Now if that limit is defective it also will affect the lighting of your heater being it electronic ig-niter or just common thermocouple type controlled pilot light. Now above your post I think the wong information was given about your gas heater, so giving you the exact information will be difficult. Now from hearing you explanation of the problems, I hope my information was a help to you, Thanks Sea Breeze
Oct 26, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Dayton (3C674) Fan Logo
26 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Piyal Perera
Piyal Perera
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
