Question about Microwave Ovens
Mw93395B 900watt Emerson micowave want heat up why
Power comes on but micowave does no cook
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 15, 2011 | Emerson Black Microwave Oven
Rest all works,but not heating micowave xl1800
When the microwave does not heat the food, it means that the magnetron circuit has failed. It the part that generates the microwaves that heat the food. Often the part fails by shorting out causing a loud buzzing sound when you try to microwave something. The replacement part usually costs almost as much as a new oven, so it rarely cost effective to replace. Sorry.
Jan 18, 2011 | GE JVM1850 1000 Watts Microwave Oven
Micowave works but no heat fuse is good mw8992rcd,what other checks can i do thanks wg
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 30, 2010 | Emerson Microwave Ovens
Micowave oven just stopped working in the Middle of heating something up. what would have caused this.
If everything went off and nolonger works then the fuse blew. If it came back on after a cooling off period then the thermostat on the Magnatron sensed an over heat condition. If the mag continues to overheat there is a problem with it or the High Voltage components.
Eric
Sep 17, 2009 | Microwave Ovens
My emerson micowave mw8119sb blow the fuse, I replace with a new one same rating, it turns on but when I put something for heat it blew the fuse again. Any help! Thanks!!!
Could be a short in the HV system for the magnetron--usually the HV diode. Another possibility is the metal stirrer fan in the waveguide above the oven cavity may have a shorted bearing (plastic). The short occurs internally within the bearing.
Aug 01, 2009 | Microwave Ovens
Micowave is not heating up, and is making a
It may be a shorted diode in the HV power supply for the magnetron. Open the case to get to the part. Unplug the machine before opening anything. This is normally a high voltage area when running.
Jul 17, 2009 | Microwave Ovens
Microwave Ovens Logo
83 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
