Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Whirlpool Cabrio Top Load Washerw 10280475A - Whirlpool Cabrio WTW6600SBT Top Load Washer
canbruce75
  • 1776 Answers
SOURCE: f1 code on whirlpool cabrio top load
This is from a service bulletin. This may be of interest to you. There have been many problems with these machines in this area. Anyway, I sympathize and hope this helps. Best wishes.
CORRECTION:
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 – CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A – C above, and verified that there are no issues
with the air pressure system.
Posted on Aug 09, 2009
  • 180 Answers
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Posted on Nov 27, 2009
  • 122 Answers
SOURCE: Whirlpool Cabrio WTW6600SBT Top Load
f1 is the error code for your main control board at console, replace boad
Posted on Aug 22, 2010
SOURCE: My Whirlpool Cabrio WTW6200sw2 top load washer
Belt is either broken or may have a nick in it.
Posted on Sep 29, 2010
  • 202 Answers
SOURCE: whirlpool cabrio top load, has flashing dial and
The F51 error is a RPS (rotary position sensor) board failure where the control board looses contact with the RPS during the machines operation. The RPS uses hall effect sensors to determine the speed and direction of the drive motor, allowing the control board to constantly monitor the motors operation. Because this error is a communication error and not a mechanical error with the motor itself (that would be and F52 error) we can limit our trouble shooting to the three items that make up the RPS circuit, the control board, the wiring harness, and the RPS itself.
Posted on Apr 09, 2011
Why do I have this Clicking Noise after bearing and seal replacement
  1. Ft. Cabrio Top Load Washer‎
    Adwww.sears.com/‎Black Friday Sale Save Over 40% on Select Appliance
    Hot Buys. Free Delivery Over $399.
  2. Appliance Hot Buys
    You'll Save More When You Shop Hot
    Appliance Buys on Select Products!
Search Results
    Whirlpool WTW6400SW Cabrio Washer Makes clicking ...
    www.fixya.com > ... > Whirlpool WTW6400SW Cabrio Washer
    Whirlpool WTW6400SW Cabrio Washer, makes clicking noise spin cycle related issues. Get free help, solutions & advice from top Whirlpool experts.
Nov 26, 2015 | Whirlpool WTW6400SW Cabrio Washer
How to take top off whirlpool cabrio washer top load
remove about 6 or so screws on the back (top) then slide the top forward about a 1/2 inch then lift.
Jul 22, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Keep getting F1 error code on my cabrio whirpool top load washer. Can you help?
Hello & Welcome to FixYa
F1 error in your whirlpool cabrio indicates bad control board and should be replaced to resolve the error code. However, you can contact Whirlpool as well prior to replacing the control yourself as I have seen whirlpool paying for the parts themselves just because this is known to be a common issue. Please get back to me if you have any other questions.
Kevin
Sep 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Brown spots left on new CABRIO TOP LOAD WASHER bought at LOWES 27 days ago!!!!!!!!!!!!!!!!!!!!!!!
I have the same problems with the Cabrio washer. I hate this pair. I have always had Whirlpool appliances but after all the problems I have had with this set from day one I will never buy Whirlpool again.
Jun 19, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
What is the washing technique in whirlpool washing machine
Are you referring to the Whirlpool Cabrio WTW6600S Series of washers?
They don't use an agitator like a conventional washer. They have a movable wash plate located in the bottom.
http://products.howstuffworks.com/whirlpool-cabrio-top-load-washer-wtw6600s-review.htm
Jul 22, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal De
