Question about Maytag MSD2456G Side by Side Refrigerator
Maytag Side by side MSD2456 DE - Bad Coil ?
During the summer of 2006 our refrigerator stopped working on and off. It made a loud humming noise ending with a loud clunking noise and shut down. We had a repair man come out and he told us that the freezer coil was going bad and it would cost too much to replace it. He also mentioned that we should start looking for a new frig. He showed by husband the coil that was frozen at the top but as you looked downward it was not frozen. While we still have the frig, it continues to make this horrid sound on and off. We are now in the summer of 2007 and are afraid that it will stop working again because of the warmer temps. It is still very nice. We purchased it in 2004 and would like to sell it in order to buy a new one but we want to make and effort to repair it. Do you have any suggestions? Karen
    Scholar:
  • 76 Answers
Karen Most likely the problem with you fridge is a bad compressor. The compressor is a part of the cooling (professionally called "sealed") system which included also the evaporator coil (the part your "repair man" called freezer coil), Freon and all tubing. This sealed system has FIVE years manufacturer warranty. You do not have to by a new fridge. Just call Maytag and they must fix it free of charge to you. Even if you do not have prove of purchase Maytag will go by the manufacturing date coded on the serial number. Good luck. Gendos. post back...
Posted on Jun 26, 2007
Loud humming noise stops when re fridg door open than continues when close-side by side refrigerator
Humming noise is normally the compressor running,,,usually nothing too worry about
Jun 13, 2013 | Refrigerators
Model MSD2735GRB Refrigerator and Freezer stopped working yesterday. I can hear what sounds like a humming for about a minute, and then a contact making noise when they close, then the humming stops. Any...
The overload/relay , which is pluged onto the side of the compressor , is bad . The manufacturer part number is 12002794 . It is easily replaceable , with only 3 wires attached to it .
Nov 18, 2009 | Maytag MSD2454G Side by Side Refrigerator
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
Maytag refrigerator clicking noise and stopped working
either inside fan out of alignment or defrost timer could be bad
Jun 02, 2009 | Maytag MSD2756G Side by Side Refrigerator
Amana/Maytag ACD2234HRS sometime not working
If your compressor is running with the noise you described, I would make sure the parts that were replace on compressor are working properly. Also use a amp meter and get a reading on amp draw while it is humming. Anything that is above normal readings for the compressor would indicate compressor is bad or the relay and starter are not working properly. I need a series number also like a number 15 before the model number, Thanks, Sea Breeze
Mar 21, 2009 | Maytag MZD2766GES Side by Side...
Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Comppresor stoped working
Go to the back of the machine and take the lower rear plate off. Taking this plate off will expose the compressor. Check to see the compressor is humming or is hot. If niether take off the relay (located on the side of the compressor) Shake it and if a loud rattling noise is heard replace it. If no rattling noise or the compressor is hot or humming then the compressor is bad.
Jan 15, 2009 | GE Profile PFS22 33" Artica French Door...
Bad Coil ?
the prob.sounds like a compressor prob.the motor in laymans terms.yes you probably would be better of shopping around now.before it totaly goes on you.comp.are more on the exp.side.
Jun 25, 2007 | Maytag MSD2456G Side by Side Refrigerator
Maytag MSD2456G Side by Side Refrigerator Logo
347 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
