My iwd61450 keeps tripping the sockets help - Washing Machines
When I put the plug in the wall it keeps tripping the fuse what can I do
hi ya
if its tripping the MCB on the consumer unit there could be several reasons,
The fuse in the plug is too low / high in the plug, as the Air con, requires more power on start up,
it is also worth checking the plug is wired correctly E N Live etc..
or the MBC is too low, normally sockets are 16 amp - if its lower check with a qualified electrician it will be noted on the MCB denoted sockets
if the air con is portable, or able to be plugged in else where try upstairs sockets or kitchen sockets as these should be on a different circuit - if it does trip on these the air con is faulty and dump or see if a qualified repair agent is local
but always consult someone who is qualified - simply doing the above should be fine,
Apr 13, 2015 | Heating & Cooling
Advice on RCD tripping
yes
an accredited electrician can test the circuits for insulation failure , vermin shorting across active / neutral/ earth points and the rcd itself
it is not a diy job
May 12, 2017 | Ovens
My zanussi washer dryer keeps tripping the electrics
check ground wire for tightness on plug in and on breaker box.
Mar 31, 2012 | Zanussi ZWD12270 Front Load Washer / Dryer
The trip breaker in my home for the electrical outlet keep tripping off what do i do. the breaker in my electircal box for my electrical socket keep tripping off
go to the qualified electricians on your place... but there is some helpful tips that can help you.. (1) for continued protection before starting. turn off the main circuit breaker. (2) unplug all the appliances or equipment installed... (3) check all the wall socket outlet... look for any damages on the wall socket... if the wall socket outlet have no signs of burned or wet marked, try to turn on the circuit breaker. check if the problem is solved.. (4) if the wall socket outlet have a signs of burned or wet marked.. just replace that w/ the same type of socket... check also the appliances that may caused the problem... the easiest way to know is to look at the socket plug itself... ty
Jun 21, 2011 | Microwave Ovens
My Hotpoint ultima WT721 1200 spin keeps tripping out all plug sockets. Have changed fuse but still does it. What could it please?
hello, bad earth check all the wired connection to the washer if these are ok then check your socket wires make sure wires are tight if these ok then there may be fault inside the washer power supply hope it helps
regards
shaun
Jan 15, 2011 | Hotpoint Washing Machines
Dryer keeps tripping the circuit breaker
hello mam please change the mains breaker after tripping for several times the breaker will be defected and check the power socket outlet by removing the socket there should not be any loose connections and skinned wires.
Oct 02, 2009 | GE Profile Harmony DPGT750EC Electric...
GARMIN KEEPS SHUTTING OFF
Check the fuse for the cigarette lighter socket. Chech that power is getting to the socket. Try plugging something else into the lighter socket to see if it delivers power.
HTH
Peter
Feb 24, 2009 | Garmin StreetPilot C330 GPS Receiver
Hoover VHD Washing machine
Surely it is the wall socket.
Mar 19, 2008 | Washing Machines
My dishwasher when switched on keeps throwing the trip switch
Try plugging into another socket preferably one that uses a different circuit. It could be a fault in the socket.
Feb 18, 2008 | Zanussi 24 in. DA6141 Built-in Dishwasher
Washing Machines Logo
Top Washing Machines Experts
