Question about RCA 24V511T 24" TV
2004 MODEL 24V511T. DO I NEED DIGITAL TUNER IN ORDER TO RECIEVE
SIGNAL AFTER FEBRUARY 17?
  • 4,234 Answers
If you receive your TV signal ovr the air using rabbit ears or a rooftop antenna, yes you will ned a converted box. If you have cable or a satelite signal, no converter is needed.
Dan
Posted on Jan 30, 2009
Is the Magnavox TFT LCD 17 MF200v/17 have a digital or analog tuner?
I believe it has an analog tuner (NTSC) only. The original remote is pictured here: http://www.replacementremotes.com/philips/buy-313923807911-remote-control.html . The TV is listed as having been available in 2004 from Amazon.com. The manufacturer didn't have to include a digital tuner until 2005 for 36"+ models. For a 17" TV, they didn't have to have a tuner until 2007.
I hope this helps.
(You'll need to have a set-top box (digital-to-analog converter) to watch over-the-air signals.)
Jan 25, 2016 | Magnavox Televison & Video
Hitachi 57G500A DTV & upcoming analog to digital changeover
To answer your direct question, yes it has a digital tuner. To answer your real question, NO it WILL NOT receive the new ATSC (digital) broadcast stations. The tuner itself is a digital one but works only for analog signals. The changeover in February will change the broadcast signals to a new digital format that will require a converter for your set to continue to function. Please note that the converter is only required if you receive your signal from rabbit ears or a rooftop antenna. If connected to cable or satelite, no change will be seen and no converter is needed.
To simplify:
Over air reception = need converter
Cable or satelite = no converter
Dan
Jan 28, 2009 | Hitachi 57G500 57" TV
I HAVE A 2004 RCA MODEL 24V511T. dO i NEED A DIGITAL TUNER IN ORDER TO FOR IT TO WORK AFTER FEBRUARY 17?
Model has one NTSC RF and two NTSC composite inputs. It's compatible with analog Over The Air and non-scrambled analog cable broadcasts. After the US analog cutoff (currently scheduled for June 12) it WILL require a digital to analog converter to receive ATSC digital TV transmisions.
Jan 18, 2009 | RCA 24V511T 24" TV
Dtv ready?
Going to the following link will help you to find out if your television is DTV ready or not:
http://www.dtvtransition.org/index.php?option=com_content&task=view&id=51&Itemid=94
Using their online tool, select the Brand (Akai) and the Model from the list. If you cannot find your model in the list (which I was not able to for your television), they are saying that you most likely do not have a digital tuner.
All is not lost, however. As stated on the aforementioned site, you can consider one of the following options:
  • Purchase a digital-to-analog converter box that plugs into an existing television. The boxes, which are expected to cost between $40 - 70 will be available for purchase in 2008. Beginning in February 2008, U.S. households can request up to two coupons valued at $40 each. Each coupon can go toward the purchase of a single set-top converter box that will allow you to continue watching FREE "over-the-air" television on an analog set.
  • Subscribe to a cable, satellite or telecommunications service provider if all desired local broadcast stations are carried by that service.
  • Purchase a new television set with a built in digital tuner.
    Listed on the page is further information that may help you to determine the status of your TV:
  • Consult your owner's manual. If that's not possible, you may be able to look up information about your TV set on the manufacturer's website. Or, you can take an up-close look at your TV set. You are trying to find out if your set has an input connection labeled "digital input" or "ATSC" (for Advanced Television Systems Committee, which is developing the DTV format).
  • If you bought your TV set before 1998, it probably doesn't have a digital tuner at all. Almost every TV set made before 1998 was a traditional "analog" set that can't display digital TV signals without either a special converter or a cable TV connection. If you bought a big-screen, projection TV between 1998 and 2004, it's possible there's a built-in digital tuner inside. But chances aren't great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
  • If you've purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores have featured digital tuners that will let you receive the new digital over-the-air broadcasts starting in February 2009. But be wary: It's not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as "HD-ready" or "HDTV monitor" sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You'll still need a special converter or a cable TV connection.
  • Jan 12, 2009 | Akai PT5492S 54" Rear Projection...
    Can't get digital tv channels.
    The W1700 is HDTV Ready but it does not have an internal digital tuner, it only receives NTSC coded signals, not ATSQ/QAM coded signals. In order to see tv in HD you will need an external tuner with component or DVI output that you can connect to the monitors inputs.
    Jerry
    Jan 04, 2009 | Dell W1700 17 in. HD-Ready LCD Television
    Does my tv have a digital tuner (RCA Model E13320, 2/2001)?
    The digital tuner has nothing to do with the new signal you will be receiving in February of next year. The new video signal is a digital signal. The old video signal is analog. Your television receives the analog signal and converts it to what you see on television. You need a converter box to convert the new digital signal back to an analog signal your television can convert.
    Jerry
    Nov 07, 2008 | Televison & Video
    Zenith c27v36
    The short answer is no. You will not need a converter box. This set contains the ATSC tuner required for the new over-air signals.
    Dan
    Aug 07, 2008 | Zenith C27V36 27" TV
    Is my tv digital compatible or not
    https://www.dtv2009.gov/FAQ.aspx What you need to know is whether your TV set has something called a “digital tuner” already built in. If it does, your TV set will work after February 17, 2009. The best way to determine whether your TV set has a digital tuner built in is to consult your owner’s manual. If that’s not possible, you may be able to look up information about your TV set on the manufacturer’s website. Or, you can take an up-close look at your TV set. In any case, you’re trying to find out if your set has an input connection labeled “digital input” or “ATSC” (for Advanced Television Systems Committee, which is the DTV format).
    Here are some general guidelines that may help:
    TV set made before 1998 was a traditional “analog” set. If you bought a big-screen, projection TV between 1998 and 2004, it may have a built-in digital tuner inside. But chances aren’t great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
    If you purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores feature digital tuners that will work after February 17, 2009. But it’s not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as “HD-ready” or “HDTV monitor” sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You’ll still need a special converter or a cable TV connection. Hope this info above helps. Also, check your manual, and if you don't have it some manufacturers, (Philips does for some models) offer the manual on their websites.
    Apr 07, 2008 | Philips TV Tuner Video Capture PCI Card -...
    Digital or not digital
    this tv has no digital tuner built in to it. In order to recieve a digital broadcast the tuner must be atsc compliant. The best solution is to get a converter box to decode digital to analog signal.
    Apr 03, 2008 | Televison & Video
    2006 RCA TV Digetal Receiver
    NBC newsperson said I should check nbc.com to learn
    what to do for the change in February. Where is it ??
    You want my solution ? Improve your web site.
    Feb 23, 2008 | Televison & Video
    RCA 24V511T 24" TV Logo
    117 people viewed this question
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
