Question about Celestron Optics
Telescope slews uncontrolably no reponse 16
Telescope slews uncontrollably. also gives a no response 16 code. The only way to stop it from bottoming out on the base is to turn it off.
    New Friend:
  • 3 Answers
A possibility is that the batteries are low or if you have a power supply, that the connection is loose/faulty.
Be careful about running it off power supplies as A) not all plugs are the proper size and more importantly B) not all plugs are wired the same way. If you take any random plug that 'fits' you run a 50/50 chance of frying the electronics. If in doubt, buy the Celestron cable.
I had this happen a month or two back while running on AAs and it was due to the batteries being almost drained. They don't last very long.
Posted on Jan 07, 2013
Noggin
  • 944 Answers
SOURCE: My goto telescope will not slew upwards.
I'm assuming the motor works fine. First check this link for the instructional video and check you are doing everything right. (you need quicktime to view these - you can download it from the link if you need it ; http://www.meade.com/educational/ds%20videos/qt_chap1.html Here is the link to the Meade warranty page; http://www.meade.com/support/warranties.html If your scope is no longer under warranty, you can get spares here; http://www.meade4m.com/4mshop/parts/ They have fabulous pictures of all the available parts - Check in the "mount parts" section; They show a DS worm gear assembly, and a DS gear and washer set. You can probably see better than me, but it looks as if the worm gear traverses the scope, and the gear and washers in their housing elevate the scope. There may be more than they show parts for. The real trick will be to make sure you know how to reassemble the gears you dismantle - take a photo every time you remove something so you have a record when the replacement parts arrive. It is not the most complicated gear mechanism, but it is reasonably high precision, and relatively cheap materials, so be very careful or get someone fairly gentle and mechanically minded. If you need help, post me some photos back of what you need help with, happy to oblige. Hope this helps:)
Posted on Jul 19, 2007
SOURCE: Meade DS-2114 ATS LNT
Also had the problem. I found that the LNT did not find north unless the bottom of the Smartfinder is close to parallel with the ground.
Posted on Dec 18, 2007
  • 3 Answers
SOURCE: Automatic leveling won't work
you can try moving the tube back from center a bit, rotating it also helps. The tube has become magnetized
Posted on Jul 25, 2010
SOURCE: My telescope is only slewing
Either the buttons are STICKING on your hand controller, or the hand controller cable is defective.
Contact Meade customer service:
http://www.meade.com/support/index.html
Posted on Aug 30, 2010
SOURCE: I have a Meade ETX
Yes under the rubber feet on the bottom are three screws -- take them out and you can get into the bottom. peel of the rubber feet to expose the screws.
Posted on Jan 10, 2011
Testimonial: "many thanks for your help"
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
At power up, tv scrolls uncontrolably through channels, power light flickers
1. Take remote control far away from tv - 3rd or fourth room. Then switch on tv. If uncontrollable scrolling stops , then cause may be remote button (Ch+ or Ch-) has got dirt inside and its shorting.
2. If taking remote far away doesn't stop scrolling then (Ch+ or Ch-) button on front pannel has shorted. Take a cutter plier and care fully remove button from its circuit board. ( If you know desoldering, it is far better than cutting). If scrolling stops then you can operate channel change with remote.
Jan 27, 2014 | Samsung LN46C600F3FXZA 46in Lcd Tv 1080p...
Celestron 8se slews uncontrollably. Also gives a no response 16 on the hand control.
This is a well documented problem with that scope
http://www.celestron.com/c3/support3/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=2434
http://www.cloudynights.com/ubbarchive/showflat.php/Cat/0/Number/60724/page/72/view/collapsed/sb/9/o/all
Jan 02, 2013 | Celestron NexStar 8 SE (480 x 203mm)...
Uncontrolled downshift of 1994 c220
no 4-3 or 3-2 downshift
uncontrolled downshifts outside range of kickdown switch
poor acceleration from stopped position
parking pawl will not engage
selector lever does not engage in r or p
engine will not start in p or n position
smoke in exhaust (fluid loss)
fluid loss between torque converter & primary pump
howling noise when changing gears (under full load)
howling noise which increases as engine rpm increases
1st gear & reverse too loud
3rd gear too loud
rattling noise at 1500 rpm in all positions except r
light grinding noise in p & n positions
rolling noises when driving in reverse
vacuum control circuit
Vacuum Control Valve (E300D & S350D)
Vacuum Amplifier (E300D & S350D)
Dec 02, 2012 | 1994 Mercedes-Benz C-Class
Meade LX90 GPS - When the telescope slews to a new location (tour or manual slew), the telescope then slews up a few degrees. I have to manually slew the scope down several degrees and hope I've...
Calibrate motors and then TRAIN the drives-- this sets the gear backlash.
You should Calibrate motors every time you take it outside and Train drives at least once every year. The symptom you describe is called "rubberbanding".
Train the drives.
Mar 03, 2011 | Meade 8" LX90 Schmidt-Cassegrain Telescope...
What does no response 16 mean on a 8se nexstar telescope hand controller
This means that the hand control has lost communication with the electronics board within the base of the telescope. The number following this message will indicate the address of the component that has lost communication. 16 indicates the azimuth or RA motor board, 17 the altitude (declination) motor board. Unfortunately, this number doesn't tell why the error has occurred.
To clear the no response messages, repeatedly press UNDO. This fix may be only temporary and does not address the potential underlying problem.
You may want to send it in/return it for repairs.
Mar 01, 2011 | Celestron NexRemote Telescope Control...
I have a Meade ETX 80AT telescope that only slews left or right intermittently. Is there any way that I can get into the base for a closer look as to why this is happening. many thanks
Jan 09, 2011 | Meade ETX-80AT (240 x 80mm) Telescope
Character spinning uncontrollably
hold the wiimote straight and aim at the sensor
Feb 23, 2010 | Eidos Interactive Bionicle Heroes for...
MotorFault
Hi
In response to your email the whole unit is being returned to supplier motor problem is manufacturers electrical fault the meade etx-125pe should have motor limiters fitted which stops the scope slewing more than two revolutions in any direction to stop potential wiring damage this unit does not have them or they are faulty hence motor fault.
Jan 18, 2009 | Meade ETX-125PE (500 x 127mm) Telescope
Celestron nexstar 8 i series alignment trouble
use the rewmote that came with the telescope and go into setup under telescope and push enter when it says calibrate motor
Nov 06, 2008 | Celestron NexStar 11 GPS (660 x 279mm)...
Optics Logo
78 people viewed this question
Top Celestron Optics Experts
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
