Question about Vizio VBR140 Blu-ray Disc Player - 1080p
Connect to internet with vizio vbr140 blu-ray
  • 16 Answers
SOURCE: our vizio blu ray player
Please inspect the HDMI connector on the back of the Blu-Ray player to make sure none of the pins (top and bottom) are not push back inside the connector. If there are return the unit for a another unit.
Posted on Feb 24, 2011
muntejaya
  • 10421 Answers
SOURCE: what is my code to hack the multi-region on my
Please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__hytg34
Posted on Feb 27, 2011
  • 6 Answers
SOURCE: my blu-ray vizio plays the movies but at a momwnt
From what you told me I think the bluray disk is damaged or scratched,and does the bluray player do this with every movie?
Posted on Mar 01, 2011
dss902
  • 16 Answers
SOURCE: I have a Vizio VBR120
The default IP mode is set to Dynamic, which means your player will automatically detect and use
your network settings after you connect your Ethernet cable, but you can manually change these
settings if you are an advanced user and are comfortable with networks.
1. Turn on your player and your TV. If a DVD is not in the disc tray, the Home menu will be
displayed. If a DVD is in the disc tray, press SETUP to display the Home menu.
2. Connect one end of an Ethernet cable (not included) to the Ethernet port on your player
3. Connect the other end of the Ethernet cable to your home network (usually your router
home network must have broadband Internet access such as cable or DSL.
4. Press to select Settings, and then press SELECT.
5. Press to select Network, and then press SELECT.
6. Press ^ or down to select Wired and then press SELECT.
7. Press to change IP Mode to Manual and then press SELECT.
8. Manually change your network settings such as IP Address, Subnet Mask, Default
Gateway, the Primary DNS, and Secondary DNS.
9. Press ^ or down to select Apply and then press SELECT.
Note: If you need additional help setting up your network, please refer to the user manual for your
router or contact the manufacturer of either your router or your Internet service provider if they
provided the router for you.
Your ip settings will look something like this 192.168.2.1
You might be able to find you setting by going to Network Connections -> 2x click on Local Area Connection -> then click on the support tab.
Posted on Mar 05, 2011
SOURCE: When I try to update
unlock server error 11000404 on a vizio blu ray vr210
Posted on May 14, 2011
Universal remote code for a Vizio Blu-Ray Player
The universal remote brand will have it own unique code for Vizio.
Jul 14, 2014 | Vizio Vbr120 Blu-ray Player/ Internet Apps
Connecting to internet
Why would you browse with a Blu-ray disc player?
Apr 16, 2014 | Vizio VBR140 - Blu-ray disc player
Unlock region code for vizio vbr122 blu-ray player
Try this WEB site for a region free code.
DVDFab Region Reset for DVD & Blu-ray drives (under Free Stuff)
http://www.dvdfab.com/download.htm
Feb 14, 2013 | Vizio VBR122 Blu-ray Player with Wireless...
Vizio vbr 333 firmware update
http://cdn.vizio.com/documents/downloads/accessories/VBR120/VBRFW_Instructions.pdf
Dec 23, 2012 | Vizio 3d Blu-ray Player With Wireless...
What is the Netflix activation code
My netflix stopped working cause I didn't update my Credit card info when I got a new card.
I can browse Vudu just fine but after getting billing info correct for netflix, Doing a system factory reset of the visio I still get a Not connected to the internet message when trying to start Netflix.
Oct 22, 2012 | Vizio VBR220 Blu-Ray Player
Netflix will not connect internet on vizio blueray player
see this steps and fix it. God bless you
    • 1 Reset the player if the device stops behaving normally. (Keep in mind that rotation sounds and picture issues during search are normal.) Select the "System" menu from the setup area and choose "Restore Factory Settings" or a similar option. Allow the device to restart and then try the disc again.
    • 2 Insert the disc face up in the tray. If playback fails to start or if it starts and then stops, wipe the disc with a soft cloth and try again. Throw out any heavily scratched discs that won't play.
    • 3 Change the "TV Aspect" to 16:9 in the setup area of the menu if the picture expands left and right or if the picture size is wrong and you're using an HDMI (High Definition Multimedia Interface) cable.
    • 4 Set the wireless Internet router to automatically allow new devices to connect to it if the Insignia player won't connect to the Internet. The player uses only WPS to connect. Some routers that use different automatic setup protocols won't work.
    • 5 Make sure that the connection between the player and the television uses an HDMI cable if you're watching a Blu-ray movie. Some Blu-ray discs will only play over an HDMI connection. Also, remember that some Blu-ray discs won't work with PiP (Picture-in-Picture).
Oct 15, 2012 | Vizio VBR220 Blu-Ray Player
How do I up date my 3D BLU-Ray
http://maxdalton.hubpages.com/hub/Troubleshooting-Vizio-VBR133-Blu-Ray-Player-Problems
"Internet Apps Problems If you're experiencing problems with the Internet apps that come pre-installed, such as Netflix, Vudu or Pandora, check the website belonging to the company operating the app to see if the service is down or if there is a way you can contact the company to ask about the issue. Alternatively, try restarting the Vizio VBR133 Blu-ray player to see if that resolves the issue."
HTH
GSS
Jun 22, 2012 | Vizio Televison & Video
Vizio VBR140 Blu-ray Disc Player - 1080p Logo
60 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
