Question about Canon PowerShot S1 IS Digital Camera
Losing power rapidly...
I've had my S1 for about two years now. I've used mainly the Canon rechargable batteries which have lasted about a week of heavy use before needing recharging. Alkaline batteries lasted less long, but were fine for emergencies. Recently I've needed to recharge after a day's use or less. And about a week ago my camera stopped working at all; it will turn on and immediately off. I've tried it with newly recharged batteries and several sets of new alkaline batteries. Any suggestions? I love this camera and have a new baby...so I need it to work!
    Problem Solver:
  • 13 Answers
The only thing I can suggest is that the metal connections on your camera have corroded due to the long life of your camera. I had a similar problem where any batteries I used would not work, regardless of what kind of battery it was. Turns out I had a nice greenish layer of corrosion on my connections which I sand-papered off. This might be a little tricky if your connectors are way inside of a battery holder, but it can be done nonetheless. Try taping some sandpaper to the flat end of a pencil and clean it out that way. Hope it works.
Posted on Jul 27, 2007
Can I use rechargeable batteries?
If it requires AA or AAA,yes you can use rechargables,or I guess any type battery which is made rechargable.They seem to last a little longer too.I am so disappointed how fast my digital camera eats batteries that I am trying to sell it and repair my SLR.
Good luck! Greg
Aug 12, 2010 | Canon PowerShot S1 IS Digital Camera
I've owned this great little Black and Decker CST800 grass trimmer for 6 years and only use it in Montreal summers (5 months long). Just this past week, I brought it in to recharge it and left it for 5...
never charge batteries that long usually only 3to5 hours if ni-cd . most batteries last 3 or 4 years . totally discharge pack and try to charge again . if nothing buy new battery pack
Jun 15, 2010 | Black & Decker 8 Inch 12 Volt Cordless...
Cannon sd750 digital elph will not charge, either on charger or on pc. would this need a ew battery , it is two years old , advice please much appreciatd
As you've guessed, it's time for a new battery. Rechargeables are only meant to last 1-2 years, regardless of their use. Fortunately, your camera uses the NB-4L battery, for which there are many inexpensive generic altenatives these day. Here's some examples from Amazon. Make sure you read the user reviews before purchasing, as some generics are better than others.
Feb 13, 2010 | Canon PowerShot S1 IS Digital Camera
Battery always going dead use 4 regular lithium batteries
in this camera and most of fuji AA batteries, the batteries keeps draining even with the machine off .
if the camera is not on use REMOVE the battries.
i will recommend regular recghargable batteries with at least 2700 Mah type NiMH.
you can recharge them several times and they will last almost as those lithium batteries on that model. plus they will be cheaper
Oct 08, 2009 | Canon PowerShot S1 IS Digital Camera
Will only work with 1.5V battery output instead of 1.2V
How old are the rechargeables? Also, am assuming you are using NiMH and not the inferior low-power NiCads. Rechargeables NiMH really aren't meant to last more than a year or two, regardless of how often they were recharged. If the batteries are older than a year, suggest trying a new set.
May 31, 2009 | Canon PowerShot A80 Digital Camera
Flash will not power on
YOU NEED TO REPLACE THE CONTACTS ORT USE SOME AMONIA AND WATER TO REMOVE THE CORROSION.
Nov 03, 2008 | Canon Speedlite 430EX TTL Flash
Purple hue on image or vertical lines (noise)..viewfinder has normal color or flickers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Dec 31, 2007 | Canon PowerShot S1 IS Digital Camera
Going through batteries abnormally quickly
Hi. I bought a used A70 that had that problem. I disassembled the outer body panels and found that a base panel assembly screw was too long, and was touching the LCD's ground cable, at the cable's tip. I changed the screw for a shorter one and it was settled. It never happened again.
May 31, 2006 | Canon PowerShot S1 IS Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
80 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
