Question about West Bend HiRise TM 41300 Bread Machine
Won't turn on
When I plug it in, it light up, but I can't change the menu or any of the other features, and it won't activate anything at all, including turning the paddles.
Camera won't turn on
Remove the battery from the camera for 15mins, replace the battery then go to the camera's Menu and scroll through the settings to Gate & Time then set the correct Date & time.
Apr 08, 2013 | Olympus Cameras
Tevion Dvd player won't read burned cd's or dvd's.
Transfer your .avi movie files onto a USB stick & simply plug them into the Tevion DVD player.
Select the usb button on the remote to activate & choose which film to play from the menu that pops up.
Mar 10, 2013 | Televison & Video
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
98 chevy cavalier turns over but won't start
i know industry jargon can be confusing, but lets try this. if it turns over but won't start, it could be your ''ignition module'' that sits on top of the vave cover on the motor or it might be the fuel pump or filter. make sure when you crank the engine that the key is all the way turned or it may not always make a proper contact to activate the ignition module. iv'e seen this before & had to change the ignition switch & all worked ok after that. i would need to know engine lt size to give you more details on the matter. please get back to me.
Nov 19, 2011 | 1998 Chevrolet Cavalier
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
I've got a Motorola RAZR 3 or 4 years old. I just bought a new car with Bluetooth (Ford Sync). How do I get the car to recognize the phone?
In order to make other devices see your motorola mobile phone, you should enable "discovery mode", which is activated in Bluetooth menu of your phone.
Please be aware that this feature is turning on only for 3 minutes, then new devices won't be able to find your cell phone. If 3 minutes is not enough, you can activate this feature again (and again).
This procedure is only required for initial pairing, there is no need to perform this operation every time.
Hope this helps!
Sep 07, 2011 | Motorola Mobility RAZR V3
2004 Hyundai Elantra won't start, emergency flashers keep blinking, can't shut off, lights dim, can't jump start, clicking from under dash from relays. What could it be?
The 'Keyless Entry & Burglar Alarm System" is activated. You must 'Disarm' the system using the Keyless Entry Remove (Key Fob) to "Reset" the system. The reason the engine won't start is due to the burglar alarm - it has a "Starter Kill" circuit which is activated when the alarm is activated. The alarm must be DEactivated to DEactivate the 'Starter Kill' circuit.
Another way to start the engine is to get in the car, put the key in the ignition and turn it to 'ON" and wait 3 to 5 minutes until the emergency flashers stop/turn off. Afterward, you should be able to start the engine. NOTE: This does NOT reset the burglar alarm. It will go off again when you enter the vehicle without using the remote/key fob.
Sep 06, 2011 | Hyundai Elantra Cars & Trucks
The red alert light indicates that the filter needs to be cleaned. I have cleaned it but the light remains on. I have turned the unit of and on again but it doesn't change the light. The unit is...
Tunr the unit OFF & unplug it for 15 minutes. Then plug it back in and turn it on. The electronics should have reset and reverted back to the original factory settings & the red light should no longer illuminate, as long as the filter was reinstalled properly.
Hope this helped you and thanks for choosing FixYa.
Aug 08, 2011 | Heating & Cooling
HOW DO YOU MOVE THE ARROW KEY ONCE YOU ARE IN THE MENU?
You use the button with the <> arrows to move through the menu selections. Use the menu key to select the function you want to change.
Below is an excerpt from the Acer manual. The manual can be found at http://www.retrevo.com/support/Acer-X203H-Monitors-manual/id/23224bh549/t/2/
Front Panel Controls
1.Power Switch:
To turn ON or OFF the power.
2.Power LED:
Lights up to indicate the power is turned ON.
3.Empowering / Exit:
1) When OSD menu is in active status, this button will act as EXIT-KEY(EXIT
OSD menu).
2) When OSD menu is in off status, press this button to select scenario
mode.
4.Auto Adjust button / Exit:
1)When OSD menu is in active status, this button will act as EXIT-KEY (EXIT
OSD menu).
2)When OSD menu is in off status, press this button for 2 seconds to
activate the AutoAdjustment function.The Auto Adjustment function is
used to set the HPos, VPos, Clock and Focus.
5.< / >
Press < or > to select the desired function.Press < or > to change the
settings of the current function.
6.MENU / ENTER:
Activate OSD menu when OSD is OFF or activate/de-activate adjustment
function when OSD is ON.
Jul 02, 2011 | Acer X203H bd Monitor
I can not find the search box in start meny in windows 7 ultimate
Hi there!
It's possible that you disabled it under Windows Features.
To fix this, just click on the Start Menu/orb >> go to Control Panel >> click on Programs >> click on Programs and Features >> Click on Turn Windows Features on or off (found on the left side) >> tick the box for Windows Search
Hope this helps.
May 20, 2011 | Microsoft Computers & Internet
West Bend HiRise TM 41300 Bread Machine Logo
Top West Bend Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Oloyede Monsuru
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
