Question about Element Electronics Televison & Video
ELEMENT 40" LCD MODEL ELDFT406 KEEPS SHUTTING OFF
40 INCH MODELELDFT406 10 DAYS OLD KEEPS SHUTTUNG ITSELF OFF
What source are on?
Posted on Jan 15, 2013
xCAUSALITYx
  • 210 Answers
SOURCE: My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Posted on Oct 01, 2009
SOURCE: 3 year old Samsung 40 inch LCD TV will not turn on
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
Posted on Jan 30, 2010
  • 308 Answers
SOURCE: wondering if 40 inch 1080 LCD element was a good buy?
Not a great brand, generally when out of warranty, you are on your own. No repair except by independant shops if they will even touch it - no manuals or parts that they can get... Considered a disposable set.
Posted on Mar 24, 2010
SOURCE: tv keeps shutting off and going back on by itself
Faulty parts on PS board , bad press for Samsung
When checking the capacitors, If they are slightly rounded on the top where the X is, the cap is defective.
Because the Samsung LNS4051D would not turn on and the power
LED would blink 4 times and the relay would click and this
would repeat again and again. I replaced power supply board
parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors,
three had their tops bulged up slightly that I missed on
initial visual inspection. After seeing the reports of
problems with these caps on
http://www.fixya.com/support/t1336881-will_not_turn_or_off ,
I replaced them with Radio Shack part 272-1032, 1000 uf, 35v.
They are slightly bigger, but fit OK. TV is working fine now.
Cost was 4 x $1.59 = $6.36 plus the time. I saved between
$100 to 300 in the process of either replacing the board or
getting the unit serviced. If you are not comfortable
replacing components which means using a soldering iron, you
can replace the power circuit board, available from
www.Samsung.PartStore.com.
Some UTube showing the problem and fix
http://www.youtube.com/watch?v=tK7zFBBU6p4&feature=related
http://www.youtube.com/watch?v=Mm51C_RDIZE&feature=related
http://www.youtube.com/watch?v=BNHHrgX_6cs&NR=1
Posted on May 27, 2010
  • 277 Answers
SOURCE: MY 32 INCH RCA LCD HDTV KEEPS TURNING ITSELF ON.
Carol
These units bave a bad power supply. To get it fixed is easy.
Take it to a Servicer center where they repair tvs.
Since there are no srevice manuals they will not be able to repair this unit. With the Work Order in hand call 1-877-297-8391 and they will send you a tv.
Ps.. Make sure you get a work order or a copy.
Posted on Jul 21, 2010
TV SHUTS OFF BY ITSELF
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jun 06, 2016 | Element Electronics ELDFT406 40" LCD TV...
Tv shuts off during set up just goes bland
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Mar 28, 2015 | Element Electronics ELDFT406 40" LCD TV...
The tv wont turn on and the red led light is on?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 18, 2014 | Element Electronics ELDFT406 40" LCD TV...
Turns off
Main board fault. Contact any service technician. This is not a user repairable fault. Gopakumar Gopalan Google
Mar 10, 2014 | Element Electronics ELDFT406 40" LCD TV...
I tried to register my new Element Electonics 40" Model - ELDFT406. Says model # doesn't exist ? Also having trouble getting the tint setting.
so you shouldn\'t bother too much with it. I have the same model and it shuts itself off whenever it chooses to. I\'ve only had it since the 23rd of November, and it shut itself off after 2 days and maybe being on only 6 hours in those two days. It shut off the other day after 40 minutes. Read the reviews on Target\'s site, most people have issues.
On Facebook, the manufacturer said they would be adding this model to their site within a week, and that was around the 26th of November that they said that and it\'s still not on their site yet. I got mine at Target and I have 90 days to return it, so I\'m going to wait until TVs go on sale around the beginning of Feb and return it.
Dec 03, 2012 | Element Electronics HD LCD TV ELDFT404-B
Eldft406 HD Digital LCD TV.Just got it and the sound goes in and out.
I have this same one and it shuts itself off at random, one time after only being on for 40 minutes. It started within 2 days of it being set up and it was maybe used for 6 hours total when it first shut off. The remote hardly works too. Other people have the same problems with this TV, read the reviews of it on Target\'s site. I got mine at Target so I have 90 days to return it and I\'m waiting until around the beginning of Feb. when HDTVs go on sale again. I suggest you just return it,. You can\'t even find it on the manufacturer\'s website.
Nov 29, 2012 | Element Electronics HD LCD TV ELDFT404-B
Element 40 in flat screen model #eldft406 will not stay on
Hi, unfortunately you're not the only one. I read some reviews on Target's site and many are having the same problem. I have one of these also and after only 2 days and hardly any use it shut off, that time was after it being on for 6 hours though. Recently, it shut off when it was only on for about 40 minutes. Don't bother with fixing it, just return it to where you got it. I'm waiting until HDTVs go on sale again, I have until around Feb. 23rd to return it. This TV also has remote issues where sometimes it just doesn't work. Return it and avoid this manufacturer!
Nov 24, 2012 | Televison & Video
Wondering if 40 inch 1080 LCD element was a good buy?
Mar 24, 2010 | Element Electronics FLX-3211B 32 in. LCD...
Televison & Video Logo
716 people viewed this question
Top Element Electronics Televison & Video Experts
Josh Whitehead
Josh Whitehead
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
