Question about Sanyo Televison & Video
Sanyo DP52440 was unplugged then replugged and then a HDMI code popped up on the sceen and said to plug in dvi into HDMI1 and use audio 3 jacks for sound. I get a picture but now am required to plug i
Everything was fine, then once the tv was unplugged then plugged back-no sound with just the HDMI cables. This goes for the dvd player we had plugged in with an HDMI cable. Suddenly no sound through the HDMI inputs, I also had to eliminate the HDMI from the dvd player and replace with standard component cables. I went along with the code on the tv and plugged in component cables with a HDMI cable and have sound. We have had picture the whole time. Bought a new HDMI too- no change.
  • 192 Answers
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Posted on Jun 24, 2007
simplemitch
  • 752 Answers
SOURCE: No input detected on projector
it sounds like the A/V reciever does not upconvert the component signal to HDMI. Not many do. The Marantz recievers will (SR6001, SR8001, etc..). Also bear in mind that HDMI cables are finicky and may require amplification over a few meters long.
Posted on Dec 04, 2007
SOURCE: No video throught HDMI output
press set up go option number 1 then go hdmi monitor and input yes. then press set up again
Posted on Dec 11, 2007
micromaster
  • 3614 Answers
SOURCE: PS3 been working fine over
TV Connectivity
The issue of connectivity between the PS3 and the display is very complex and depends on the type of TV (Analog, Digital or HD Ready), the maker of TV (until recently, only Toshiba TVs have component AV connections as standard in Europe, most other Euro TV sets use SCART which can not carry an HD signal) and specification of TV (the very latest HD Ready TV sets have wider connectivity options than earlier HD "capable" TVs from the same manufacturer which may have lacked HDMI), and finally the configuration of the PS3 model purchased.
Posted on Feb 18, 2008
  • 6 Answers
SOURCE: HDMI->DVI cable won't work
Are you using a HDMI to DVI cable or are you using a HDMI to DVI adapter? Sometimes, though not on all products you have to go into the menu and select which out put your using for each source and whats going through it. You might need to go into your dvd player menu and tell it not to try to run audio through the cable. That way it's not trying to force a signal through the cable that cant be accepted by the TV. That might possible solve your problem for the DVD player. Let me know if it works
Have a Great day
Posted on Aug 11, 2008
Why has audio failed?
DVI does not have the means to provide audio - it is video only (like the VGA connector on your computer monitor). HDMI on the other hand provides video AND audio signals.
Aug 30, 2015 | Sanyo Televison & Video
I just bought a phillips blu ray and trying to hook it up to my sanyo 50" plasma through a hdmi i get video but no sound the tv says to use the dvi port and audio 3 inputs but the blu ray does not hav
Hello there, the hdmi cable is a great way to get high definition video from a bluray player to a tv, but if the bluray player is part of a surround sound system you will need to get the sound to the tv separately. There is often a red and white audio terminal in the rear of the bluray player, sometimes located next to a yellow terminal, these are known as a component connection as each component (coloured terminal) is separate and operates a separate function, but all 3 connections can be used together to create a SCART equivalent. You may need to connect an 'Audio Component to 3.5mm jack' cable from the white and red terminals to the headphone/line in socket on the tv.
alternatively, as wilth my player, there is a button on the remote which switches the audio source from component, hdmi, SCART, etc, this may be the same for you.
hope this helps.
Mar 12, 2014 | Televison & Video
When i try to play my x box on my sanyo tv no sound comes out of the tv
Try a different HDMI input and a different cable.
DVI is same as HDMI in regards to the picture signal, but lacks the audio.
Apparently for some reason the TV does not pick up audio and that could be because the HDMI port has a problem (say physical contact) or because the cable has a problem or (of course) because the XBOX does not output signal for some reason.
My first two picks would be the port and the cable.
hope this helps!
www.coppelltvrepair.com
Oct 08, 2012 | Sanyo 52" Class LCD 1080p 120Hz HDTV,...
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
How do i set up multi screen on my 42" HDTV Insignia
You may use an HDMI / DVI cable to connect to your computer. Next if you have windows 7 hold your windows key and hit the letter "P" (for projector) this will allow you to bring on the multi-montior feature on your computer. Make sure to select the option that says EXTEND. Please note that when connecting a DVI device you must use the HDMI IN1 (dvi) jack on the back of your TV. you cannot use HDMI In 2.
1. Turn off your TV and all connected equipment.
2. Connect an HDMI/DVI cable or DI-HDMI adapter between the HDMI in 1 (dvi) jack on the back of your TV and DVI OUT jack on the DVI device.
3. Connect an audio cable between the DVI audio IN jacks on the back of your tv and the DVI audio jack on the dvi device.
turn on the tv then turn on the dvi device.
May 02, 2011 | Computers & Internet
Problem using Audio 3 sound inputs for HDMI video
Normally this problem is simply a matter of selecting the correct default audio playback device in the Windows control panel (sound option).
Check the Playback tab and set the default device to either DVI or HDMI.
http://pcaudiohelp.com/fix-hmdi-sound-to-tv
Feb 25, 2010 | Sanyo DP50747 50 in. Plasma TV
What type of audio jack rgb/dvi in on rear of lg 50ps3
the dvi out of pc via adaptor to hdmi on tv has no audio,ok.
so LG diagram shows separate audio into Audio in RGB/DVI.
Resulting in video in on HDMI ok,but audio on RGB.Can not get both together.
Fix is revert to DVI to RGB lead with audio on RGB/DVI input.
The audio jack would only work with mono plug for audio in, to RGB.
Dec 08, 2009 | LG Televison & Video
Can i use tv as computer screen
The same VGA cable you would use to connect it to a computer monitor.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 29, 2009 | Sanyo DP42848 LCD TV
HDMI output from AVR-4806
You say your connected from the DVD to the Denon with an HDMI cord and the Denon to the TV with an HDMI cord and you get no DVD video? can you get the Denon setup menu? if so change the res. output on the DVD to 480p, 720p or 1080i but not 1080p
Feb 15, 2009 | Denon AVR-4806 Receiver
Televison & Video Logo
109 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
