Question about Video Game Consoles & Games
Wondering with tools I need to remove the black screws and where can I find them.
    Genius:
  • 1,669 Answers
If you are referring to the jack at the edge of the unit, you can't access the inside of it from inside the case at all. It is a closed unit that has electrical contacts attached. You need to go in the hole you show and pull it from there. It appears that the plastic tip has ome of it sticking out of the hole. Is that correct? If so you can grab the edge with a tiny pair of needle nosed plyers and yank! Another way is to get a dental hook tool and pull it from inside the plastic tip....good luck!
Posted on Jan 02, 2013
How to remove the funny shaped screws on microwave
ANTI-TAMPER SCREWS
If your model has anti-tamper screws, you can remove them using using a T20H Torx type or GTXH20-100 screwdriver. If the correct tool is not available, there are several ways to remove the screws:
- Use a hammer and a small punch or similar tool to knock out the middle post of the screw, then use a standard T20 Torx bit to remove the screws. (Use safety glasses).
- Insert a small flat-bladed screwdriver (such as a jeweler's type) into the slot between the post and the edge, tap the screwdriver firmly with a hammer to loosen the screw, grip the screwdriver with pliers, and remove the screw.
This detailed photo shows how a small screwdriver fits into the screw head:
- Use a hacksaw or Dremel tool to cut a slot in the head of the screw, then use a flat-bladed screwdriver to remove the screws. (Use safety glasses).
Jun 07, 2012 | Emerson Black Microwave Oven
Ford explorer no heat clicking in dash
NO NEED TO REMOVE WHOLE DASHBOARD!!! REMOVE TWO7MM SCREWS FROM THE BOTTOM OF STEERING PANEL & PRY AND REMOVE PANEL.
NEXT REMOVE TWO 7MM SCREWS ON BLACK PLASTIC STRIP THAT YOU SEE AFTER REMOVING STEERING PANEL....PRY THIS STRIP OF PLASTIC OUT JUST A LITTLE AND CUT IN THE MIDDLE .
NEXT REMOVE TWO 7MM SCREWS FROM AROUND TOP OF INSTRUMENT PANEL (BY GAUGES ) PRY PANEL STARTING FROM AROUND VENT ON LEFT BY DRIVERS DOOR ""THIS PANEL WILL STAY IN PLACE LOOSE... NO NEED TO REMOVE!""
NEXT YOU WILL SEE 0NE 7MM SCREW BY GEAR SELECTOR AREA.. BEHIND THE LOOSE PANEL REMOVE THIS SCREW.. ALSO IN SAME AREA BUT LOWER THERE IS ONE 7MM SCREW THAT NEEDS TO BE REMOVED THAT HOLDS LOWER DASH PAD ITS FOUND BEHIND LOWER CORNER OF DASH PAD.( LOWER DASH PAD GAS PEDAL AREA )
"DON'T"!!! REMOVE THE FOUR 10MM BOLTS!!!! IN SAME AREA
NEXT REMOVE RADIO /AC CONTROL TRIM WITH THIN SCREW DRIVER OR PANEL TOOL IT HELD IN BY SIX CLIPS...NO NEED TO DISCONNET ANYTHING IT WILL STAY THERE HANGING!!
NEXT REMOVE TWO CENTER CONSOLE LOWER LARGE PLASTIC CLIPS BY FLOOR MATS. NEXT UNDER SQUARE BLACK RUBBER AT CENTER CONSOLE REMOVE ONE SILVER SCREW. MOVE SEATS FOWARD AND REMOVE TWO 8MM SCREWS FROM SIDES OF CENTER CONSOLE FROM BACK SEAT.
PRY CUP PANEL SECTION THAT WAS HELD DOWN BY SILVER SCREW ...PRY UP TOP HALF OF CONSOLE STARTING FROM SECTION WHERE ARMREST DOOR IS.. DISCONNECT LIGHTER PLUG AND REMOVE PANEL .
NOW YOU WILL SEE SIX SCREWS STARTING FROM BELOW RADIO TRIM WORKING BACK TO ARMREST DOOR
Dec 04, 2010 | 2004 Ford Explorer
How do you change brushes on milwaukee sawsall
depends on the model number but, if you can see a black screw on the upper and lower portion of the tool UNPLUG the TOOL and remove the screws and the brushes are underneath. If you don't find the brush caps you need to remove the handle halves and expose the rear of the motor to access the brushes. I would recommend going to Milwaukeetool.com and with your model number under service type it in to download a breakdown for this tool.
Sep 11, 2010 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
Instructions to replace the samsung sgh-a877 lcd screen?
needs major work. Do it at your own risk. Did everything right but messed up and broke the tab on the touchscreen cable connector on my daughter's phone. Feel crappy. Will post with pictures later on.
1. remove battery/ Sim 2. remove all screws from the back on the black plastic cover. (6 of them) Leave the ones below the battery. 3. Use the pry tool to remove the back case. 4. remove the motherboard, three connectors, one on bottom left, antenna and top right below the board. board comes off. You also have to remove the power connector (transparent plastic) to what appears to be some hf component (cylinder). there are two wires (red, black), red goes to side marked +. remove with pry tool. 5. Remove all small screws you can see. 6. Remove the shiny plate, keyboard button layer. 6a. Remove the lcd connector screw and the connector. 7. Remove screws from the bottom of the lcd portion of the slider. You can access all screws from the back side. Use the slider to get the back of the phone. There are 5 screws. 8. Use the pry tool to take out the back slider. Be careful with the lcd connector. 9. pull up the black tab on the digitizer connection from the screen 10. remove the lcd 11. use a hair dryer to loosen the glue around the broken digitizer. 12. put the new one in 13. Put all the screws back.
Apr 10, 2010 | Samsung SGH-A877 Impression Cell Phone
Any Special tools needed for brakes on 2004 Suzuki Verona
for the fronts all you need is a set of metric sockets and a ratchet,use a c clamp to push back the caliper piston.remove the caliper mount bracket and rotor is out reverse install. now for the back if rotors have emergency brake using the same pads then you will have to buy a special tool to help you screw in the caliper piston tool costs lees then ten dollars.small cube with universal pins on each side also to be used on other vehicles.
Jan 14, 2010 | 2004 Suzuki Verona
How to remove round sander for iron shaped one
You need to remove the allen head cap screw in the center of the base, then remove the washer, and pull the base straight down off the sander. If you can't get it to pull off, try gently rocking it a little as you exert pressure to pull it off.
Random orbit sanding base
With this sanding base, you can use the tool as a random orbit sander.
Fitting and removing the sanding base (fig. B)
- Place the sanding base (3) onto the spindle (10).
- Place the washer (7) onto the spindle.
- Insert the Allen screw (8) into the screw hole in the spindle.
- Tighten the Allen screw using the Allen key (9) supplied.
- To remove the sanding base, remove the Allen screw (8) and washer (7).
Fitting sanding sheets (fig. C)
- Hold the tool with the sanding base (3) facing upwards.
- Place the sanding sheet (11) onto the sanding base (3). The holes in the sheet do not need
to line up with the holes in the base.
Large detail sanding base
With this sanding base, you can use the tool as a detail sander or an orbital sander.
Fitting and removing the sanding base (fig. D & E)
For detail sanding, the pointed end should face forward as in fig. D. For sanding large areas,
the pointed end should face to the back as in fig. E.
- Place the sanding base (12) onto the spindle (10). Make sure that the legs of the base
locate into the tool.
You can also view the factory manual here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/479727-00,MS1000%20SANDER.pdf
Be patient, and good luck! Let me know if this doesn't solve your problem and you still need help!
Mar 08, 2009 | Black & Decker Black And Decker Cyclone 4...
99 mazda protege power windows
No, just a phillips and a large flat driver or pry tool. Remove plug from upper rear side of door. Pry off the triangular cover that is above the panel and covers the backside of the mirror mount. Then lift the lower edges of the panel to pop out or pry out the nylon plugs that anchor the panel to the door. Do this carefully. Next unscrew the handle cover. You'll see the lever handle is attached to the latch rod with a nylon sleeve over the hook on the rod This is flipped around to release it. When you peek in it will be self-evident. I found this the hardest piece to get back on. Do this carefully to not lose or break the little nylon sleeve.New ones can be purchased if you do. Next you need to find the screws that secure the panel. The first is totally visible. The next is found when you pop off the soft vinyl arm rest starting from the back. The next and last is a vinyl covered screw visible in the upper right of panel. Think that's it. Then pop out the electronic controls for windows. Once removed there is a waterproof plastic attached to door with black sticky caulking. Peel this off carefully and you can reseal it later. Of course you need to unplug wiring, and also remove door handles and screws as you go. I think I got all the details for you.
Dec 15, 2008 | 1999 Mazda Protege
Install a new antenna i850 nextel phone
ok you will need a hex screw driver, remove the old antenna by removing a little black cover on the antenna which hides the screw. remove it, insert the old and remove the screw cover and screw it back in.
Oct 29, 2007 | Nextel i850
Video Game Consoles & Games Logo
16 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
