Question about Philips 42PF9631D 42 in. Plasma Television
Removing closed captioning
We cannot remove the closed caption feature. It only comes up on the HD channels. When I go to "menu" with the remote, it does not allow me to choose the caption option. It is not illuminated as are the other options which can be accessed. When I try to access the menu from the side of the t.v. the message "keylock" appears on the screen. I have followed the instructions but cannot remove CC -I can change the size etc. MY TV is a 42" Flat Screen Plasma Model # 42PF9631D/37. Purchased 2006.
It took two years to get CC on the screen!
Worked it out. The Direct TV remote has a yellow button and that did it. I don't know whether I had inadvertently programmed it that way but problem gone.
Thanks.
Posted on Jan 19, 2009
How do you shut off the closed caption feature?
I do not know this dvd player, but on most anything with closed caption, you hit the cc button on the remote until you come to '0' or 'off'. As CC has about 6 channels it can use, but really only channel '1' is used. So you might have to cycle through the CC channels until closed caption disappears. Hope this helps. You might also have a setup menu on this DVD where you can control the CC.
Just cycle though it till you get to '0' or off, exit the setup menu.
Jan 07, 2011 | KLH DVD-221 DVD Player
I have a element 26 inch model# elchs262 .a black band apears in the center of the picture. pushing any button on the remote removes band for a few seconds also time and date and a code apear in band...
This is a text box. This can be turned off under the closed captioning. There should be a cc button on your remote or the closed captioning features can be accessed from your television's menu. Turn closed captioning completely off to get rid of these text boxes.
Sep 28, 2010 | Element Electronics Televison & Video
How do you remove the subtitles?
Subtitles are controlled by 'CC". Closed Captioning. Look for a CC button on the remote or captioning.
Captioning usually is in the menu as well under 'settings'.
Closed captioning has several settings. OFF turns all captioning off. CC1, CC2, CC3 & CC4 are captioning styles. Text is for text channels.
Mar 31, 2010 | Toshiba 57H84 57" Rear Projection...
Cannot turn CC off.
Features preferences
Caption service
This allows you to select the Closed Captions service levels of analog
broadcasting to be displayed.
Closed Captioning allows you to read the voice content of television
programs on the TV screen. Designed to help the hearing impaired, this
feature uses on-screen ‘text boxes’ to show dialogue and conversations
while the TV program is in progress. Captions will appear on the screen
during captioned broadcasts.
& Select Captions service.
é Press the cursor right.
“ Select the desired Caption service:
• CC 1, 2, 3 or 4
Dialogue (and descriptions) for the action on the captioned TV program
shows on screen.
Usually CC 1 is the most used. CC 2 may be used for alternate languages
if they are being transmitted.
• T 1, 2, 3 or 4
Often used for channel guide, schedules, bulletin board information for
Closed Captions programs, news, weather informations or stock market
reports.
Not all Caption services are necessarily being used by a TV channel during
the transmission of a Closed Caption program.
Features menu
& Select Features in the TV Settings menu.
é Press the cursor right to enter the Features menu.
“ Select the menu items with the cursor up/down and adjust the settings
with the cursor left/right.
Closed captions
This displays the transmitted CC- or CS-text on the screen according to
your chosen CC or CS service in the Setup, Features preferences menu,
This text can either be permanently displayed (assuming that the
service is available in the broadcast) or only when mute is active.
& Press the cursor right after having selected Closed captions.
é Select On, Off or On during mute.
Oct 28, 2009 | Televison & Video
Cannot select caption? Its grayed out..
grayed-out?you mean no letters?better check first if the station has this closed captions features turned on in its transmission just to be sure.or try another channel for testing the closed caption features of your unit.
May 29, 2009 | LG 52LG50 52 in. LCD HDTV
Closed captions go on and off sporadically
if the comcast box is not hd then the control is with your tv/remote.
If the comcast box is hd, then you can control it from the comcast remote. To do this press cable, then power and in 2 seconds press menu to get to the hidden hd setup menu, scroll down to closed captions and set it to enabled or disabled then press power twice to get back to you rtv
Nov 26, 2008 | Toshiba 42LX177 42 in. LCD HDTV
How do I remove the closed caption from Sanyo Model DS24424 without a remote control
If the front panel has the menu feature, you can do it by pressing it and use the Volume/Channel buttons to navigate through the OSC screen until you get to close caption to turn it OFF.
Apr 25, 2008 | Televison & Video
Removal instructions for close caption
If you are hooked up to a cable receiver, the closed caption must be disabled in the cable receiver. With most cable receivers the closed caption must either be on or off and there is not cc button on the remote.
Feb 14, 2008 | LG 42LC2D 42 in. LCD HDTV
These flat panel TVs are all board replacement only for any type of repairs. Your problem seems to be on the main board where the microprocessor is located. Which means if you're not a technician then you have to take it somewhere to be serviced.
C-Dog
Jan 20, 2008 | LG 37LC7D 37 in. LCD HDTV
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Philips 42PF9631D 42 in. Plasma Television Logo
196 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
