Question about Frigidaire GLEQ2152ES Electric Dryer
I have a frigidaire gleq2152es1 that keeps blowing heating elements, what is the cause?
I replaced the element 2 months ago and it broke again. we dont dry sneakers or anything like that. any help?
  • Frigidaire Master
  • 8,220 Answers
Are you re-stringing the element? if so you need to make sure you have no gaps in the element.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 02, 2013
  • 159 Answers
SOURCE: Frigidaire Dryer takes too long to dry.
First thing I would do is to take the drum out of the dryer and make sure the back is not all clogged up with lint. That is a very common problem with Frigdaire dryers. The back is where the dryer draws the heat from and it sounds like you have plenty of heat. The only place the heat will go is up and that may be why you are geting burn marks. I wold also clean out the front where the lit filter is that to gets blocked up. I think if you check all that ad clean it out good the dryer should work just fine.
Posted on Jul 13, 2007
SOURCE: Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Posted on Sep 15, 2008
  • 686 Answers
SOURCE: How do you change the heating element on a frigidaire AEQ6000ES2?
WITHOUT THE MODEL NUMBER THIS WILL BE AN EDUCATED GUESS PRY THE TOP UP AT THE EDGES IN FRONT BETWEEN THE TOP AND FRONT PANEL. THEN INSIDE THE FRONT PANEL WILL BE 2 SCREWS HOLDING THE FRONT TO THE CABINET THEY MAY BE 3-4 INCHES DOWN ON BOTH SIDES UNDO DOOR SWITCH WIRES AND RAISE UP FRONT AND REMOVE. NEXT REMOVE THE THREE SCREWS IN THE MIDDLE OF THE DRUM ON THE INSIDE. UNDO BELT OF COURSE AND REMEMBER HOW IT IS ON. AFTER 3 SCREW REMOVAL PULL DRUM OUT AND THERE SHOULD BE ABLE TO SEE HEAT ELEMENT. WHEN INSTALLING NEW ONE FOLLOW DIRECTIONS TO THE LETTER IT MATTERS. GOOD LUCK TO YOU.
Posted on Apr 12, 2009
TheMobilian
  • 8220 Answers
SOURCE: GLER331AS2 BLOWS COLD AIR
Just use my simple GUIDE
Posted on Jun 09, 2009
TheMobilian
  • 8220 Answers
SOURCE: HOW DO I GET TO THE HEATING ELEMENT ON MY
Pretty dang simple. Check out these repair PIX with MANUAL
Posted on Aug 31, 2009
Heating element keep breaking up
Disconnect your dryer vent and run your dryer ,If your dryer works fine you have a clogged vent ,or poor ventilation. p s your dryer room will get humid so open window if one is in the room.
Jul 13, 2015 | Frigidaire Dryers
Heating element keeps going out
Make sure the water fittings on the top of the water heater are not two dissimilar metals...this causes electrolysis. If you do, you need a dielectric union to connect the two metals ie copper & galvanized steel
Dec 02, 2013 | Eemax Heating Element 240 Volt 9500 Watt
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Frigidaire Gallery Dryer # GLEQ2152ES1. Bought it used. No probles for several months. Moved to a different location. Dryer works but not heat and shuts off frequently. I replaced the control...
Hello - Since you have previously replaced the control board and confirmed that the high temp sensor is working fine, unit may possibly have a defective sensor, heating element, power supply or a communication problem with the control board. I suggest contacting a professional to move forward accurately. The technician usually warranties their labor just in case something else may turn out to be the root cause of your initial problem.
Oct 20, 2012 | Frigidaire GLEQ2152ES Electric Dryer
My dryer blew its fuse like 6 times, I would go to the garage and click it dryer fuses on and off and at first that worked but no it will run and stay on but just doesnt blow hot air
That sounds to me as if the heat element has broken and when it broke a small part of it fell onto the metal housing where the heat element fits into,as a result of the broke element no longer being suppost safe and sound it the housing but instead it sat on the housing and created a short circuit that caused the fuse to blow.
By replacing the heat element it should once again heat and not blow the fuse
GENE
Sep 18, 2011 | Dryers
I have a Bryant Heat pump installed 10 years ago. It keeps blowing a breaker(now a fuse) in the air handler. I have had a technician out here three times. He has replaced all four relays and checked for...
One of the heating elements is stretching enough when it gets really hot and it is touching a metal part somewhere which blows the fuse...
Pull the heating element part out and you should be able to see where it is arcing and causing the short...
heatman101
Feb 14, 2011 | Heating & Cooling
Wire Scraping sound and sparks inside rear dryer drum area.
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
Feb 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer not hot
Tht means that the element is not heating on.
You need to call a technician to test the element, the thermic sensor, and the control assembly.
The most likely is a defective heating element, that must be replaced.
Jan 31, 2009 | Kenmore 73952 Gas Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
78 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
