Question about Electrical Supplies
Matching a generator to a motor
What size generator to run a 7.5kw 3ph submersible pump
  • 10,865 Answers
You need a e 3 phase generator to run a 3 phase pump first of all. Check to see that the generator is three phase. Most are not.
Posted on Jan 18, 2009
Can I change 3ph DeWalt RADIAL ARM SAW to 240v single phase motor? I have moved, no 3ph power and the motor gave up just before we moved.
Since your old motor died, it is a good opportunity to replace it with a single phase motor, provided the new motor is capable of the performance that you are needing. The new motor should have the proper motor mounts and be sized power wise for the application. What was the HP rating of the old motor?
Jan 31, 2018 | Dewalt Saws
What size generator do I need to run a 10 hp motor
on the plate attached to the motor you will find several important items
one is the wattage of the motor
this is the maximum wattage that the motor uses when under load
the gen set will need to be at least 30% bigger than that figure
next there will the number of phases that the motor is
it will read as 1 ph or 3ph
If it is 1ph that is a single phase motor and will ru from a single phase gen set
however if it is 3ph you will need a 3ph gen set to run the motor
As most single phase motors are limited to around 5hp I would be very sure that the motor is not 3ph
specialist advice from an accredited electrician or electrical motor shop is recommended before buying a gen set. as if you need 3ph the gen sets become expensive.
Aug 07, 2015 | Electrical Supplies
Looking for a new motor for a utilitech pro 0313836 submersible pump
Most submersible pump motors are interchangeable.
A 230 V motor will run cheaper. Be sure to get the correct HP motor.
Oct 05, 2014 | Utilitech 1-1/2-HP 18-GPM 3-Wire 230-Volt...
Motor runs but does not pump water
Is there water over the pump housing? Is intake on the bottom clear of debris? This may sound stupid, but is hose frozen or blocked?
Mar 28, 2014 | Utilitech 0.33-HP Thermoplastic...
Submersible pump with only two wires going to the motor. how do i connect it to the control box?
Brown wire should be active and blue should be neutral. the motor will still spin the correct direction as it is single phase . Have a look in the connector box and which ever wire is connected to the active then that will be the wire for the motor.
Mar 23, 2013 | Submersible Systems 1/2HP 2WIRE...
What size power inverter do i need for rs3 1/3 hp submersable pump?
Match inverter rating with voltage and amp draw of motor.
1/3 Hp motor amp draw chart by household voltage:
http://waterheatertimer.org/Color-codewire2.html#motor
Oct 22, 2012 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Hi i looking for water pump 10hp single phase borehole 150feet under ground 1500gpm submersible please can you rang run on single-phase 240v thanks harry 00353860818018
Don't knw what your problem is but here is a page that gives you the information, normally 3 phase on single phase motor but if you can change the winding settings you might here is the page hope it helps.
http://www.pentairpool.com/pdfs/CSeriesCommercialBronzePumpOM.pdf
Dec 20, 2010 | Pentair 10hp 3ph Single Phase 220440v 60...
Appropriate size inverter for sump pumps
First...you need to find the amperage on the pump...your inverter is rated for 6.25 Amps...(750/120)...you will need an inverter bigger then the pump..I would suggest at least 1.5 times the size of the pump..bear in mind,..the inverter wasnt designed to start motors...so oversizing is needed..
Hope this helps
May 05, 2009 | Black & Decker Husky 750w Power Inverter
Potential Motor damage
Submersable pumps pull a lot of current on start up. Up to 7 times running momentarily. This is especially true of three wire pumps. ( Ground and 2 , 110V) 4 wire pumps have a capacitor start provision ( the extra wire) and a control box that greatly reduces the starting load by shifing the phase on startup.
4200 watts should handle it how ever if you have no line losses. Excess Line losses will do exactly what has happened to you. Overheated the connections and burned up the pump.
First check what gauge wire you have going from the generator to the pump and the length of the run. Check a wire gauge calculator such as http://www.denningelectronics.com/wiregauge.htm
use at least 4 times the running load for your wats and if it is a deep well pump, more than 50 feet of head from water to spickot) then use 7 times wattage. Use 5% line loss allowable,. This will probably uncover your problem as under size wire.
The other possibility is that the breaker was going bad over time and caused the voltage drop0 that destroyed the pump.
Last item you can do, check the voltage at the generator when the pump starts, it shold not drop more than 10% on start up.
Good luck
Mar 17, 2009 | Craftsman Air Tools & Compressors
Electrical Supplies Logo
117 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
