Question about HP Officejet 5610v All-In-One InkJet Printer
Cartridge error 5610v
I keep getting cartridge error. I replace the black cartridge now showing both carrtridge are in error
    Genius:
  • 1,669 Answers
Did you remove the paper protector from the jets? Did you lock the cartridge cassettes in securely. Did you cycle the power off for at least 1 minute?
Posted on Jan 02, 2013
  • Ursula Jan 23, 2013
    This was helpful but did not solve the problem. Thanks
  • 990 Answers
SOURCE: HP Officejet 5610v - Won't print black
use Q-tip to clean up the copper contact see what happen
Posted on Dec 13, 2008
rickt011
  • 11 Answers
SOURCE: error show on panel replace black cartridge
The replacement cartridge is a cheap imitation, that does not have the proper equipment to keep this error from reporting.
Posted on Feb 11, 2009
SOURCE: Cartridge jam won't clear HP 5610v
I had the same problem and just got it to work. go to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00577763&lc=en&dlc=en&cc=us&lang=en&rule=22243&product=441125
go to the section "Moving the carriage" turn on printer and then unplug power. If you still cant move the carrage then remove both toner cartridge and all the trays. Then completely disconnect printer and stand it upright (so paper feed and cartridge tray is on top) Look thru the paper feed area to the left side of toner carrage and you will see a little plastic tab around the bottom back of the carrage. That tab is suppose to be inside a track on the bottom of the carrage. I think that when we put in or took out toner we must have pushed it to hard and that piece jumped out of the track and has "locked" the carrage. I just pushed the carrage up carefully and used a letter opener to move the plastic tab back into place (tab is spring loaded) print working fine now. Hope this solves your problem
Posted on Feb 15, 2009
laxmankumar
  • 191 Answers
SOURCE: Keep getting replace yellow ink cartridge error message
Where did you get the error message on printer or computer?
If you get the message on printer remove all cartridges and reinsert the cartridges and align the ink cartridges. If the alignment page prints successfully then the problem is resolved.
If you get the message on the computer disconnect the usb from computer. uninstall the software and reinstall the full feature software by selecting connect USB later.
Posted on May 24, 2009
  • 169 Answers
SOURCE: Alignment error on the HP L7680
you need to reset the printer using the # and the number 6 buttons and while holding down the buttons plug in the power cord.See if it works else try the same with # and the number 9.
If you want any further support a technician can help you online for free.You can find free online technical support at http://tinyurl.com/m7ghqz
Posted on Jun 19, 2009
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
Can the printer print with only the black cartridge in or do you have to have both the black and color cartridges for the printer 5610v all-in-one to work?
90% of HP printers require both. I have not personally tried the 5610, but when I worked retail, I remember hearing a lot of complaints about it and HAVING to have both color and black in.
The reasoning behind having both cartridges in:
Ink is a liquid. When a liquid sits, it dries. Inkjet printers use print heads (microchips) to transfer the ink from the tanks to the paper. If these print heads get clogged. Say goodbye printer (or atleast is ends up costing more to fix, than to replace).
Aug 28, 2011 | HP Officejet 5610 All-In-One InkJet...
CARTRIDGE FOR 5610V
Black Cartridge HP 27
Color cartridge HP 22
Photo cartridge HP 58
Jan 27, 2010 | HP OfficeJet t45 All-In-One InkJet Printer
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
HP Officejet 5610v all-in-one printer
Cartridges may be clean but not seated properly in their respective cradles. Also make sure each cartridge is in its respective cradle.
Aug 14, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Paper Jam/Cartridge can't move
Hello Julie how are you? Regarding on your problem try to remove your cartridge then installed it properly. Or try to open the back of you printer and try to see if their is a small piece of paper left during a paper jam incedent you have.
Jun 16, 2009 | HP Officejet 5610v All-In-One InkJet...
HP C6280 says out of black ink
Something is wrong with your Blach carrier or connections. Use a bit of alcohol and clean the array of gold contacts where the Ink cartridge plugs in. Most of the pins are shutter and piezo control (get the ink on paper) but a few do other stuff like check ink level, # of hours runtime, etc. This is very common problem with inkjet printers. Hope this helps.
Also... rub the contacts on the printhead with a pencil eraser to make them shiny and bright.
Cheers!
Mar 26, 2009 | HP Photosmart C7280 Printer
Error show on panel replace black cartridge
Dec 25, 2008 | HP LaserJet 2840 All-In-One Printer
Dec 13, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610v All-In-One InkJet Printer Logo
77 people viewed this question
Seeker5211
Seeker5211
