Question about Philips Televison & Video
Philips 60pp9202/17f how do you adjust the 6 knob color box in the back of the tv. not the one in the menu guide
  • 2335 Answers
SOURCE: rca tv problem
It is a common failure. It requires replacing a couple of ICs that we call STKs. The cost of repair is always $400 plus or minus unless you can do it by yourself (You should have some basic hand soldering skills in order to do the work because it requires some soldering AND some further testing for other components that may have failed in addition to the ICs).
Check for a part that looks like the one in this link but with a different part number that is mounted on a big heatsink.
Let me know if you require further assistance.
Posted on Mar 31, 2008
Slinteriors
  • 8617 Answers
SOURCE: Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
Posted on May 22, 2008
  • 556 Answers
SOURCE: no red when hooking up component cable for dlp hd
Check the red cable this is where the red comes from, you may have a bad cable, maybe use the blue or green one just to see if the red will come through, it can be the cable box or the tv or the cable itself.
Posted on Nov 03, 2009
Slinteriors
  • 8617 Answers
SOURCE: we have a 60 inch philips tv that started to have
Thats the screen controls. To adjust it turn the color level down to zero, Then adjust the 3 knobs by balancing them to where the best black and white picture is acheived. Then turn the color level up and that should do it. Just be careful not to turn the settings too low or the CRTs will refuse to light after the set gets turned off. If that happens you will need to turn each adjustment up a little and the CRTs will relight then you will need to adjust it more. If you cannt get a good black and white picture you will need to replace the Coolant in the CRts.
Posted on Nov 25, 2009
SOURCE: I have a philips HD rear projection TV 60 in.
If yours is a rear projection TV the adjustment knobs on the focus block inside are screen (red, green, blue) and focus (red, green, blue). The ones you are referring to as color are the screen controls and they adjust the intensity of the color from each tube. The other set adjust the focus of each color. They are also not intended to be adjusted by the user. Unless major components have been changed these controls should not need adjustment. That is why they are inside the TV.
Posted on Dec 05, 2009
Color was bad couldn't adjust it better , then last week red curvy lines showed up on the bottom om screen . opened the back and found 6 adjustment knobs slowly turned one and screen went dark. repowered...
sorry but those adjustment are not the right one , to correct the color problem u have frist , u need to hire a tv tech , tv would has to adjust the screen and focus back to normal after that , need to replace the oil on green and blue picture tube
Apr 12, 2010 | Philips Magnavox 9P6034C 60" Rear...
Color projection tv
Adjust the top left knob back down till the color comes back
Feb 25, 2010 | Philips Televison & Video
Trying to adjust my Philips TV's Custom Color Temperature
Philips 32PFL3403/12 problem with colours, after 1 hour working: starts to mix colours.
Feb 20, 2010 | Philips 32PFL3403D/27 32 in. LCD TV
We have a 60 inch philips tv that started to have problem with overexposed color (blue) i thought that i could fix this, i moved the lenses a bit rendomly,that did help a little, but then i touched the...
Nov 24, 2009 | Philips 60PP9202 60" Rear Projection...
Having trouble adjusting lenses and color to correct settings.
Are you adjusting the TV using the menu or did you open the set up and turn the knobs. I hope you did not adjust the knobs without some instruction.
It may be a convergence failure. ( common problem ) or cloudy CRT fluid.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 16, 2009 | Philips 55PP9363 55" Rear Projection...
My screen turns green and then turns off
you need to adjust the screen voltage. behind the front grille and inside cover. a small black box 6 adjusters protruding from it. only adjust the the color counterclockwise that matches the problem in this case it's the green so look for the knob with "G" marked by it. there are 2 with "g" marked by them the row across the top of the box are for focus don't adjust. back the knob off untill the raster is blank with your input set to an inactive input, the picture should be blank and black.
when it is you have the adjuster close to where it should be, now change the input to an active signal and turn the color off so that you wil have black and white picture. adjust that knob untill you do have a truely black and white picture not too green or red or blue. go back to inactive video input and check that there are no lines of any color on the screen. repeat if needed. always adjust these knobs slowly the set will be watching you ! if your autofocus won't work now you have the adjustment set too low. check this function before putting back together again. these adjustments can be real touchy so be patient
Feb 20, 2009 | Sony KP-57HW40 57" Rear Projection...
TV problem 46GW948 GE 48? Thomson Guide Plus GemStar
i hope this helps. on the tv, press menu, then channel up or down to "screen", then menu;
then channel up or down for adjust projection tv(6), then press menu;
then use the volume up and down, as well as the channel up and down until each of the 3 colors are lined up. press menu after each color i slined up to go to the next color.
hope this helps.
May 29, 2008 | Televison & Video
GREEN GHOST
If you want to adjust focus and screen there is a focus block some sets they can be found on the front behind the gril then behind a cut out held in place by screws if not check from the rear. But a ghost like you say sounds like a convergence problem
Mar 21, 2008 | Philips 9P6444C 64" Rear Projection...
Color blurry
If it is in in the menu aslo one of the main boards are defective. Contact Philips @ 1888-744-5477 and the will do the repairs in the set is under warranty if just out of warranty they will still help have your receipt.
Jan 22, 2008 | Philips 50PFP5332D 50 in. Plasma...
Can't watch footbal
NOTE: ----DO NOT TOUCH THE CONVERGENCE BOARD " -------
1. Bring Up 1 Projector Light 2. Bring Your Color Convergence + Sign and Should Be Center In Your TV 3. If Not Adjust Center with The 2 Tabs Just Above That Projector Tube You Have Lighted 1 Tab Will Move + Sign Horizontal Then Roll The Other Vertical Then Roll..U Will See--" 4. Once Your + Sign Is Center Turn Up Your 2 Other Projectors Make Sure They Are Able To Adjust Across The + Sign You used 1st Make Sure the 2 Other + Signs Move Left And Right And Up And Below The Vertical and Horizontal Lines. If Not Adjust There Tab to Make This Possible. 5. Using Your REMOTE Converge The + Signs Together. ---------------- IF YOU MESSED WITH THE CONVERGENCE BOARD ------------------- 6. Now Lower The 2 Lights So Your 1st Projector Is Lighted 7. Bring Up A Menue On Your TV -- Look At It ...Are The Lettering Center and Square ..?? 8. If They are Lower That Projector and Light Your Projectors 1 At A Time To Verify Letters are Center and Square. ---------------If You Have To Adjust The Menue To Bring Center And Square -------- 9.Looking At The Convergence Board You Will See 3 Rows Of Adjustment Dials Each Row Is For 1 Projector. ---TAKE NOTE TURN THE ADJUSTMENT Slowly--- 10. Locate The Row that will adjust The Projector You Have LITGHTED".... 11. Label On A Paper What Each Knob Will Do To The Screen Very Help-Full 12.Adjust Your Letters Dead Center and Square then Lower That Projector Light And Bring Each Projector Lighted At 1 Time To Verify Menue Is Center And Square. 13.Leave On Your 3rd Projector and Bring Up Your Light On The 1st Projector 14. Adjust the Letters Of Your 1st Projector Over The Letter Of Your 3rd Projector 15. Switch To Your Convergence + Sign To Help --Turn Knobs Slowly --- 16. Make Your Letters Merge Together And Your Lines Square. 17. I Use The Top Letters and Lower Letters And Keep The box Square 18. Hey If Your Projector Colors When Looking Through The Rear Of The TV Are Not Equal With Take And loosen The Wing Nuts And Turn The Lens To Focus the Color and Make Narrow Or Wide....All 3 - Equal DO NOT GET UPSET THIS WILL TAKE TIME MAYBE ALL DAY SO RELAX HAVE FUN" Do Not go Sticking Your Hand Into The TV While TV Is Plugged into The Wall" ---
Dec 16, 2007 | Philips Televison & Video
Televison & Video Logo
29 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
