Question about Singer 1725
What is a bobbin? and I think its threaded but the needle isn't moving
When I push the pedal the needed does not move up and down?
  • 944 Answers
Here is a link to get the instruction manual for your machine - sorry couldn't find one for free but it sounds like you could use it; a bobbin is a reel on which thread is wound, there are two - one on top and one below the footplate and fabric dogs. If you are struggling with the terminology then read the manual for threading instructions as it is not necessarily as obvious as it looks and is difficult to describe without a picture unless you know the names of all the parts around which the thread has to pass. The pedal not operating could be due to numerous reasons - please post back if the manual doesn't get you started and let me know if it has ever worked, if so what were the circumstances when it stopped working. Sometimes if a machine hasn't been used for a long time and hasn't been properly oiled/serviced (very important), you will need to start the machine sewing by hand before the motor will kick in - if that doesn't work then you probably have: 1. A faulty pedal (often the large value capacitor in these goes and is simple enough to replace if you can solder. possibly other parts although these usually fail gradually) 2. A faulty or incorrectly attached cable to the machine. 3. A faulty power plug or cable or socket or fuse if it is fused 4. Faulty settings on the machine (especially if some controls are not quite in position) 5. A faulty motor (fairly easy to repair, probably requires some spares) usually you would get some more indication of this than just not working like noise / burning/ smoke/ or working a bit but not properly. 6. Some models also have a fuse or thermal reset switch in the machine itself, couldn't get that info for sure without the manual but it is worth a check. Hope this helps - if you don't want to pay for a manual then please ask again with more details of the problem and photos of how you have it currently set up, and hopefully I can help :)
Posted on Jun 25, 2007
Looking for a manual for singer sewing machine.
I'm thinking your machine is the type that needs to wind the bobbin with it in the carrier. Ok, here it goes. 1. Thread the top as usual and through the needle. 2. Open the needle plate. 3. Move the button on the left side of the carrier to the left and push down at the same time.
3. While holding two inches of thread apply pressure to the foot pedal and monitor the amount of thread on the bobbin. Don't overload! There is an outside red line to reference for this.
Oct 27, 2014 | Sewing Machines
Needle is not moving
Of course I have to guess here--not seeing the machine, but it appears that your motor is working fine. That would leave two possibilities, I think. The first is a defective foot pedal. The second is, when you push the bobbin winder, it engages a clutch that diverts power from the needle shaft to the winder. It is possible that the clutch is stuck. To find out, disengage the bobbin winder and press the foot pedal, and see if the bobbin winder spindle is still spinning.
Jan 02, 2014 | Singer Inspiration 4206
I push on the pedal but the needle doesn't move up and down. The machine makes a sound like it is working but nothing moves. The machine works if I manually turn the wheel. I get an error of c4 which means...
Sounds like the thread on top and the thread in the bobbin have knotted up or some of the material under the foot has gotten bound up under the plate.
Aug 04, 2013 | Singer Sewing Machines
Pfaff select 1540 bobbin thread jam
if there is a thread in the hook area try taking a pair of needle nose
pliers to try & get the thread out, if that doesn't work then you might
think about taking the machine to a sewing machine shop to have the
machine checked since the needle will not go up & down & handwheel
won't move
May 03, 2012 | PfaFF Sewing Machines
Singer 4423, timing out,what line up with what
I don't think it's a major timing issue, so don't panic. Take a look at your selected stitch pattern selector and set for straight stitch, and set Tension at 3-4. Width: 4. Length: 4. Make sure presser foot Down when you rethread machine so the tesion disks open up to locate thread. Always hold thread taut when "feeling" for tension slot. Insert new needle. Needle goes all the way up into needle clamp as far as it can possibly go, FLAT side needle toward needle bar and more rounded side needle facing you. Leave 6" tail. Hold thread toward you as you turn hand wheel toward you so needle can make a loop with bobbin thread. Make sure bobbin thread isn't hanging down on or across bobbin! Make sure thread in bobbin has wound evenly - good quality thread ideal! Clean bobbin area and feed dogs for broken, loose threads and lint. Always use needles appropriate size for weight of fabric. I suggest walking away from machine, taking deep, cleansing breadth, humming a favorite tune, then doing above and see how it goes! Soon your machine will be humming happily along with you. Hope these suggestions help. Jimmy
Mar 31, 2012 | Singer 4423 Sewing Machine
E123@aol.comMy needle on my Bernina 1530 Inspiration just stopped going up and down whether I use the foot pedal or manually attempt to move the needle
This sounds like you have the machine in bobbin winding mode, just refer to your manual to take it out of bobbin winding mode. I'm not familier with your exact model, but the is typically a lever, or button that is used to wind bobbins, so the needle doesn't keep sewing without the bobbin thread in place.
Please rate my solution thanks
Mar 13, 2011 | Sewing Machines
This is the first time I am using this machine... it worked for a little while (15 minutes)and then the needle jammed. The whole part that moves the needle up and down doesn't move, manually or by pedal. I...
Unscrew the needle and you should be able to move the balance wheel, take the needle out and then look for thread jammed in the bobbin case area.
Mar 03, 2010 | Bernina Virtuosa 150
Kenmore 158.1703 sewing machine - needle not going up and down
Sounds like your worm drive gear is striped and needs to de replaced. If you twist the handel on the end of machine does the needle move up and down.
Jan 03, 2010 | Kenmore Sewing Machines
Singer 1725 Logo
87 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
