Question about JVC Ks-bta100 Bluetooth Adapter Phone & Audio For Receivers Ksbta100
Can't hear other caller when receiving call from bluetooth ksbta100
I hooked system up today, the blue & white wire is connected to power and black to ground. I am wondering if the brown wire is needed.
blueextc3221
  • 15935 Answers
SOURCE: need a wiring diagram for a radio on a 93 Explorer
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black
Illumination Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Green
Left Front (-) Blue/White
Right Front (+) White/Green
Right Front (-) Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Pink/Green
Left Rear (-) Brown/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Black/White
THanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 08, 2009
fkuk
  • 311 Answers
SOURCE: I have the Kd-S550, I need the wire connections . thanks
yellow goes to positive of the battery
red goes to the acc of the ignition(0volts whn car is off 12volts when car is on)
blue goes to a amplifier remote terminal if you have on if not the tape over the exposed copper
black goes to ground
the white of the speaker is that coming from the radio or from the car?
if it is from the radio then connect it to one side of the speaker
you need the cars radio wiring instructions and radio wiring intructions and double check each wire
Posted on Jan 03, 2010
Raditronic
  • 196 Answers
SOURCE: jvc unit
check down the radio. down the radio is the diagram chart.
Posted on Apr 28, 2010
kenw392
  • 2226 Answers
SOURCE: I need help on the
blue/white is amp remote turn on, red is ignition (switched hot pos.), yellow is constant hot, and black is ground (neg.)
Posted on Oct 07, 2010
  • 63 Answers
SOURCE: on the adapter that fits
The orange wire from the head unit is for the dimmer. This wire allows the face of the radio to dim at night when the headlights are on.
Posted on Jan 10, 2011
I need the wiring color coding of jvc kd-r526
All branded car stereo system color cods are same. FR-speaker:brown,brown with black. FL-speaker:white,white with black. RR-speaker:violet,violet with black. RL-speaker:green, green with black. Yellow:battery. Red:key main ( acc). Black:ground. Blue and blue with white: amp remote or power antenna. Thanks.
Nov 29, 2013 | Car Audio & Video
Don't no how to hook it up ...
Instructions
Hook up an RCA patch cable
between the output of your car's
stereo receiver and the graphic
equalizer's RCA inputs. Use
stereo cables with male RCA
connectors.
Connect the equalizer's outputs
to the RCA inputs of your
amplifiers. How many cables you
need will depend upon the
number of amps in the system. In
most cases, you'll need two to
three to connect the equalizer to
the inputs of your amplifiers.
Hook up the equalizer to 12-volt
power. Use the same power
connections you used to connect
your amplifiers and receiver. The
equalizer's yellow wire should be
connected to a constant power
source, one that is not switched
off with the ignition, and the red
wire (not always present) to a
switched 12-volt power source.
Splice the wires by stripping the
insulation off the end of each
wire and then soldering or
crimping them together.
Connect the equalizer's blue
"turn-on" lead to the receiver's
blue wire. This turns the
equalizer on when the receiver is
powered up.
Mar 28, 2013 | Car Audio & Video
No Sound from Jensen VM9725BT
Jimmie Monica Hey, Its not a problem with the unit. You have the blue or Blue/White wire hooked up wrong. Disconnect both the blue wire and the blue and white wire and I guarantee the sound starts working on everything. If you have one of those two wires hooked up for a power antenna or remote amp turn on, then switch which one you are using and that will fix the problem permanently. Disconnecting them both will get it to work though. I guarantee it. Please post back and let me know if it works for you. Thanks
Sep 06, 2013
Feb 22, 2013 | Jensen VM9725BT Navigation receiver
I have a kenwood stereo for 2000 saab 9-5. the tuner works but whenever i change it to cd you can no longer hear any music. it must be the wiring but i dont know which color wire is connected for the cd...
It sounds you are using an amplifier and using the blue wire (power antenna remote turn on) instead of the blue/white wire (amplifier remote turn on). Try hooking up the blue/white wire to turn your amp on. When leaving tuner mode, the blue wire shuts off, turning off the amplifier.
Sep 28, 2011 | JVC AM FM CD DET FACE CAR STEREO
Wireing diagram to hook up amp sub and 4 speakers
Here's the color codes for the wires.
Blue=power antenna
Blue/white=remote turn on for amp
Red=ignition
Yellow=battery
Black=chassis ground
Grey=right front (+)
Grey/black=right front (-)
White=left front (+)
White/black=left front (-)
Violet=right rear (+)
Violet/black=right rear (-)
Green=left rear (+)
Green/black=left rear (-)
RCA Connections:
Red=right rear to amp
White=left rear to amp
And that should be all the wires. Good luck!
Sep 26, 2010 | Alpine TDM-7582 Cassette Player
Have a wiring harness for a CQ-C8100U panasonic CD Player/Head Unit, need a wiring diagram to hook it up to a 2002 Ford Explorer Sport 2 Door
Hello! Since I do not know if your vehicle is equipped with the Standard or Premium System I'll give both sets of wiring...You can identify which system you have by looking at the color of the ground wire...
Red=Standard and Black/Green =Premium
Standard...Constant +12=Green/Yellow...
Switched=Yellow/Black...Ground=Red...
Illumination=Blue/Red...
Standard Speaker
FR + White
FR - Green/Orange
FL + Orange/Green
FL - Light Blue/White
RR + Orange/Red
RR - Black/White
RL + Pink/Green
RL - Pink/Blue
Premium...Only power difference is Ground=Black/Green
Premium Speaker
FR+ White/Red
FR- Brown
FL+ Green
FL- White/Orange
RR+ Purple/White
RR- Blue
RL+ Blue/Black
RL- Yellow
Guru.....saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Feb 18, 2010 | Panasonic CQ-C8100U CD Player
Which colour wire to use to hook up a trailer for a Kia Carnival 2000,trailer leads are yellow, green,black,brown,red,white and blue(no connection). just want to know which lead goes to which in the Kia?...
Here is a cheat sheet I compiled that you will find very helpful:
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are Color, Function, Mark on the plug.
Seven wire Trailer plugs
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
Oct 28, 2009 | 2000 Kia Amanti
Wire colours
Check if this applies to your Rover
White/Blue - Perm 12v,
Yellow/Red - Switched Igntion,
Red/Black - Night time illumination,
Black - Earth
 Blue/Green & Grey/Black at ISO Connection is LH Front Door Speaker
 Red/Green & Brown/Black at ISO Connection is RH Front Door Speaker
Blue/Yellow & Grey/White is LH Rear Speaker
Brown/White & Red/Yellow is RH Rear Speaker
Power connector:
1. n/a
2. n/a
3. n/a
4. 12V permenant
5. n/a
6. n/a
7. 12V (ignition on)
8. Ground
Speaker Connector:
1, 2: rear right speaker
3, 4: front right speaker
5, 6: front left speaker
7, 8: rear left speaker
Sep 01, 2009 | Philips Car Audio & Video
Can,t figure out how to wire it up to my 1995 jeep and would like to find out how to wire it up?
Dont know what model you have so here u go!
1995 Jeep Wrangler Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Purple/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Blue/Red
Car Radio Dimmer Wire: Red/Black
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Gray
Left Front Speaker Wire (-): Yellow
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Brown/Red
Rear Speakers Size: 4′
Rear Speakers Location: Rear Roof
Left Rear Speaker Wire (+): Gray/White
Left Rear Speaker Wire (-): Brown/White
Right Rear Speaker Wire (+): White/Black
Right Rear Speaker Wire (-): Brown
1995 Jeep Cherokee Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Violet/White
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
1995 Jeep Grand Cherokee Car Stereo Radio Wiring Diagram
Radio Switched 12V+ Wire: Red/Gray
Radio Dimmer Wire: Orange
Radio Power Antenna Trigger Wire: Green/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Purple/Yellow
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Blue/Pink
window.google_render_ad();
Jun 03, 2009 | Pioneer DEH-P2000 CD Player
JVC Ks-bta100 Bluetooth Adapter Phone & Audio For Receivers Ksbta100 Logo
29 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
