Question about Zoom H2n Handy Recorder
Zoom H2n Handy Recorder wont power on
With battery nor ac cord. Worked fine tgen one day just would not power up ! Any help ? Thanks !!
SOURCE: Zoom H4 Handy Recorder
If you used the adapter to power it with batteries in, you may have blown it
Posted on Apr 06, 2008
  • 17 Answers
SOURCE: H4 zoom battery operation
try resoldering the circuit board where the power socket is ... as there is a switch on the socket that disconnects the batterys
Posted on Jul 17, 2009
hmerchant110
  • 7191 Answers
SOURCE: need english translation of zoom H4n handy recorder
You can download the English manual from:
http://www.zoom.co.jp/english/download/manual/english.php
Direct download link: http://www.zoom.co.jp/archive/English_Manual/E_H4.pdf
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks
Posted on Dec 29, 2009
Testimonial: "Guru, thanks for taking the time to send me the information on downloading the instruction manual!"
ray2551
SOURCE: Zoom H4 does not power up on battery power.
Probably two years too late, but I recently got a used H4 and it was having this same issue. Upon reading the documentation, it seemed as though it required a specific type of AA batteries. If you update the firmware (mine was 1.3) to the latest version (currently 2.4), you can toggle the battery type under the menu (most likely alkaline is what you want). It also added lots of other great features!
Posted on Dec 11, 2012
jimkovacs7
  • 151 Answers
SOURCE: My Zoom H4 will no longer run with batteries.
Take it apart and check that all the boards are plugged into each other. Simple to do, and great design, but vibration can pull them apart. Also, check that the battery connectors are not oxidized...
Posted on Apr 08, 2014
Who can fix my Zoom H4N recorder remote jack and ac power jack?
I think you will find that no one will fix this as it is considered a disposable product like most modern electronic devices like this.
Oct 15, 2016 | Zoom H4n Handy Digital 4-track Recorder
My h4n wont turn on. What can I do?
Are you running on batteries or electric? Batteries: replace Electrical: make sure your plug is all the way into wall and into recorder. God luck and have a pleasant day. Leave feedback for I'm new
Jul 14, 2016 | Zoom H4n Handy Digital 4-track Recorder
Zoom H2n playback is not working. File selection works but will not play. The menu screen gets to the file "play" is pressed and the menu goes to file management screen. Am I missing a step?
Probably not. It should play when "Play" is pressed and no connective menu or step should appear between pressing of "Play" and starting of Play. You can try restarting the device. Turn it off, take out Battery, Re-Insert Battery, then Turn it On and then try to play. If the problem doesn't go away, Contact Authorized Service Center (If in Warranty) or any Gadget Professional (If Warranty is expired).
Mar 29, 2014 | Zoom H2n Digital Handy Recorder With...
How to perform a factory reset on zoom H4
Hello ! Actually what you do is download the latest firmware from the ZOOM page. Find HANDY H4 (you can Google that) and go to the Download tab. Follow all instructions. Be sure to have new batteries or be plugged in to AC while you reset. I've done it on my H4(I have 2) and H4n and it worked fine. Be patient, it takes a while once you start. Good luck !!
Mar 09, 2014 | Zoom H4 Handy Recorder
Www zoom co jp
did you format the card after putting it in the recorder?
press menu
use toggle switch (the scrolling wheel on the right side) to scroll till you find sd card on the menu
push in on toggle switch to select it when you have sd card on the screen
when you do that you'll see 2 choices remain or format
select format then press in on toggle switch
you will be asked if you're sure you want to format the sd card
select yes
the manual said it is important to format your card in the recorder
hope this helps
W
May 07, 2013 | Zoom H2n Digital Handy Recorder With...
Play button does not work
Me too! No metronome playback either!
Mar 25, 2013 | Zoom H2n Digital Handy Recorder With...
Hello. I have a problem with my ZOOM H4 recorder. When I try to turn it on (using ZOOM adaptor) it shows the the battery is low (but batteries aren't included) and tells me to turn it off. Also, when its...
I have exact same problem, I got it to work temporarily by turning unit on then connecting AC adaptor into unit, it forced it to run, I formatted card and it worked for an hour now back to same old problem, I'll keep you informed. I believe it's faulty switch. help me if you can.
Oct 07, 2010 | Zoom H4 Handy Recorder
My Zoom H4 will no longer run with batteries. If I use AC adaptor it works fine but I get nothing on battery power
Probably the connector where you plug the AC adapter into has a switch contact that disconnects the battery when external adapter is used and it has gotten bent so when the adapter is not plugged in, it no longer makes contact to the battery power. This is pretty common for devices that use both battery and adapters.
Aug 23, 2009 | Zoom H4 Handy Recorder
Jul 02, 2009 | Zoom H4 Handy Recorder
Zoom H2 handy recorder
I presume you have tried new batteries, and/or the problem persists with the AC adapter. If so, have you tried replacing the SD card?
If these do not work then it is probably time for a repair, but I'd ask the Zoom Corp or your dealer first. They may have heard of similar problems and know a painless fix.
www.zoom.co.jp (Japan)
Aug 27, 2008 | Zoom H4 Handy Recorder
Zoom H2n Handy Recorder Logo
24 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
