Question about Baby Gear
Instructions for ant kingdom kit - Baby Gear
The oil seals have collapsed. How do they get repaired?
What model saw in particular are you after.? Let me know ant i'll try and get the Parts Breakdown for you.
Jan 26, 2013 | Husqvarna Maintenance Kit For Model 36,...
We have had our ants for 3 days and they don't seem to be interesed in making tunnels. We put in four holes, like the instructions, but they are just staying on the surface. Help?
According to the Uncle Milton site, ants are much less active in the winter. This is probably why your ants are not being active and tunneling.
Jan 08, 2012 | Uncle Milton Ant Farm Gel Colony
I recently bought a Kingdom Hearts 2 game and tryed to play it on my PS2 but everytime I put it in a disk drive it does this weird noise and then in a couple of minutes says that it cant read the disk. But...
What is probably happening is that the disk is either too scratched or too dirty to be read by the PS2's optical drive. Try cleaning the disk with a disc cleaning kit or by simply rubbing in with a microfiber cloth or 100% cotton shirt. If that fails to make it clean enough to be read, then you will have to get another, cleaner copy of Kingdom Hearts 2.
Mar 05, 2011 | Square Enix Kingdom Hearts II for...
To whom it may concern: July 12, 2010 (Order # 652165) I ordered an Ant Far & kit #174, requesting it be sent to my daughters house in a different city. On Aug. 3rd I received an email stating to...
Dear Mrs. Birch,
I understand your frustration with the Uncle Milton Industries and would follow the exact course you have set were it me in your place. Please understand that this site has no connection whatsoever with that company. We are here to help you solve a variety of technical problems and assorted issues in a wide range of catagories. Here is the email address for Uncle Milton's ant department:
mailto:ants@unclemilton.com?subject=Ant Replacements
I hope they resolve your issue quickly and to your satisfaction:)
Aug 24, 2010 | UncleMilton Uncle Milton's Ant Farm Game
My blue ant came with no directions and i don't know how to pair it
Blueant Supertooth Light
Click here to view your user guide and instructions in PDF format:
http://www.supertooth.net/PDF/ST_Light_English.pdf
You'll need Adobe reader to view it. It's free. Download here if you need it:
http://get.adobe.com/reader/
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Dec 29, 2009 | Blueant Supertooth Light Bluetooth Speaker...
Basic cable scrambled on ANT input but not PIP
it sounds like you have the common problem with these models. The poblem has occured so offten that toshiba issued a service bulliteen about it. There is a problem with a cuircit board called the Hypermodule its a signal processing board/ the ideal situation would be replaced this board but it has happen so much it may be difficult to find this ooard so this board can be repaird. The secound problem is to fix this board 11 very very small parts called capacitors need to be replaced. i have also replace these and only someone advance in solder should attempt it very small. twezers and magnifer. You can hire someone but it very labor intensive. Our shop charges 300 just in labor It can be fixed but I would adviise its just no worth it
Dec 09, 2009 | Toshiba 42H81 42" Rear Projection...
Instructions for ant farm
http://www.unclemilton.com/company/manuals/AntFarmGelManual.pdf
You'll receive 25 to 30 non-breeding adult Harvester worker ants.
Important: Before you open the tube of ants, place the
tube in the refrigerator (not the freezer) for about 15
minutes. This makes the ants less active and easier to
place into the habitat.
When you're ready to add the ants, carefully
open the plastic tube and gently shake or tap
them in. Replace the habitat lid securely.
Mar 12, 2009 | Uncle Milton Ant Farm Gel Colony
Baby Gear Logo
53 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
