Question about Garmin GPS
Garmin nuvi 2555 cannot unlock maps - Garmin GPS
4 Suggested Answers
SOURCE: unable to unlock maps for
Soution:
1. Use Mapsource to find the unlock code for NT v8 (from Utilities->Unlock Maps...).
2. Using Notepad, edit gmapprom.unl file on the unit (under Garmin folder) to replace invalid code with the correct 25 character unlock code (no spaces or dashes) and hit Enter key and save.
3. Reboot.
Posted on Apr 04, 2009
SOURCE: garmin 205w nuvi cannot unlock
Ok so I decided I was going to return this thing tomorrow after hours of frustration, so I decided to get crazy with it and then figured out something that seems to have worked (will probably still exchange it for a Magellan or something other than Garmin though).
It's gonna sound crazy, but I opened up the Garmin drive on my computer (Mac, so not sure how this works on PC), and deleted everything I could see (not hidden files). EVERYTHING.
I then went ran Disk Utility and reformated the "Hard Drive" (on PC I would guess your able to do the same somehow). It still ran after that, but obviously could not find maps (since I just wiped every trace of a map away).
Next step, I ran Garmin Map Manager and transfered map for my state (AZ) (I have the latest map update saved on my computer, so I'm guessing Manager used that). Unplugged from comp, powered up, and voila! I will need to download my voices and vehicles again, but hey at least it's working again.
Posted on Apr 13, 2009
  • 4090 Answers
SOURCE: Is there any free map updates for the garmin nuvi?
Asmany as there are FREE dinners Updates are not free, unless you paid full price for it when you bought it. Free upgrades are a deceptive myth. If you get a free uograde its usually minor and was included in the price of the pack.
Posted on Sep 20, 2009
Can't unlock maps on garmin nuvi 255w after update
You can try to power down for hard reset(disconnect battery) and after connect again or reset to factory setting.
Mar 19, 2013 | Garmin nuvi 255W GPS Receiver
Need manual for Garmin nuvi2555lm
James,
Your manual is available from Garmin via this link. The nuvi 2555 is functionally identical to the manual in the link. The "lm" part of your model simply stands for "lifetime maps"
If you'd like to check other Garmin nuvi manuals, click here. In the "Market" box, select "On the Road"; in the "Subcategory" box, select "Automotive"; choose the particular nuvi model in the "Product" box.
Feb 12, 2012 | Garmin nuvi 650 GPS Receiver
Garmin Nuvi 1450LMT,how do I unlock maps?
if your unit is showing cannot unlock maps, all you need to do is connect if to a computer with the provided USB data cable and re-download the maps. when the maps are downloaded it should unlock the maps for you.
Sep 04, 2011 | Garmin nuvi 1450 GPS Receiver
Garmin nuvi 295 says "can't unlock Maps"
You can get details of how to unlock your maps at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
You should also back up your favourites folder when you've unlocked the map. You'll get details of how to do this at http://www.fixya.com/support/r8422587-backup_restore_favourites_garmin_nuvi
Mar 09, 2011 | Garmin nuvi 205 GPS Receiver
On my garmin streetpilot 7200 it says maps are locked...
I'm not sure if the street pilot is the same as the garmin nuvi. There are details of how to unlock Garmin Nuvi satnav maps at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
There's more information there than you'll need but you can skip to the part on unlocking maps. I'd imagine the street pilot wouldn't be a whole lot different from the nuvi as they're both made by garmin.
Mar 03, 2011 | Garmin StreetPilot 7200 GPS Receiver
Garmin NUVI 205 when turned on says can't unlock maps!?!
Whenever Garmin Nuvis have map problems, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Oct 24, 2009 | Garmin nuvi 205 GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Hope this helps!
I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
3. Looked on my GPS to find the UnitID
4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
5. Selected Map Product as Custom and entered the code given for the downloaded image file.
6. Hit the bottom create button to generate a 25 digit code.
7. Download Img2Gps and run
8. Click Load Folder to load the image file. Select the tick next to it.
9. Check the Use Unlock Key option and paste the 25 digit code in.
10. Load a blank SD card into your Garmin
11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
12. Create a folder called "Garmin" on the SD card
13. Select Folder/Card in Img2GPS
14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
15. Upload will take a while.
16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
18 copy the 25 digit unlock key into this file.
19. Close the file.
20. Disconnect the Garmin.
21. On Startup it should load your original maps and the new ones.
May 28, 2009 | Garmin nuvi 200W GPS Receiver
It says . cant unlock maps.
Follow this below
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
Regards
Richard.
May 18, 2009 | Garmin Nuvi 255 GPS Receiver
GPS Logo
265 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
