Question about John Deere 6200 6300 6400 6500 7500 Water Pump (John Deere)
My 6300 john deere tractor just died going down road checked main 160 amp fuses ok keeps blowing my k102 30 amp fuse
Main fuses 160 amp ok keep blowing my k102 30 amp fuses when i turn on key
  • 86 Answers
SOURCE: i have no brakes
You have your brake rod is not attached or brakes need adjusted,or needs new brake pads !
Posted on May 09, 2009
  • 246 Answers
SOURCE: My fuse keeps blowing on my neutral safty switch
Hello williamhowar:
>>As I am Sure you are Aware, Most Backhoes do a Lot of Bouncing and Jarring. LOL.
>>If you can Trace the Harness, then Check of a Bare Wire that is May be Touching the Unit.
>>If the Harness is Good, then I will Require some More Information about this Unit in Order to Assist you Further.
>>Send me the Model Numbers Off the Unit, Please. With these I can Locate the Proper Manual and Better Assist you.
Thanks.
Respectfully
jbridger (John)
Posted on May 14, 2009
  • 9 Answers
SOURCE: john deere tractor won't stay running
Its using up the gas in the carb then it stalls. take the carb off and clean it and make sure the float in the bulb of the carb isnt sticking closed.
Posted on Jun 22, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
nova2nv
  • 197 Answers
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Posted on Nov 14, 2009
John Deere Tractor...If you put a battery with more cranking amps than what's called for will it blow fuses? When we start the mower it continues to blow fuses. This was after the battery change.
NO
a battery with a higher crank specification only means that you can spin the engine for longer before the battery goes flat
blowing fuses is from a dead short in the wiring, battery connect up wrong, problem relays
basically the positive of the battery is through the fuse) connected directly to ground at some point
Jun 18, 2016 | John Deere Garden
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
Why would a mdl 1035 john deere tractor keep blowing the starter fuse
There is a distinct possibility that this tractor was originally equipped with a 6 volt system. If it has been upgraded to a 12 volt starter, the ignition will need to have a resistor installed to bring it back to 6 volts.
I could be all wrong on this but it's worth checking.
Mar 06, 2015 | John Deere Garden
Why does my john deere 5075e keep blowing ignition fuse
It has to have a short either at the starter or the ign. switch just check the wires that carry power and make sure none are earthing out.
Aug 17, 2014 | Garden
Citroen xsara picasso 2.0hdi battery fuse keeps blowing.
If it's the main Fuse, rated above 40Amps, then usually only two components are directly connected to this circuit. The starter motor and the alternator. Both can get critical short to ground, that may blow such fuse.The thick battery cable goes directly to the starter motor and a smaller high amp wire is looped from there to the alternator. Third less likely would be main supply to ignition key switch.
Mar 21, 2014 | 2001 Citroen Xsara
John Deere L110 what is the 20 amp fuse for?
Hi. That 20A fuse is basically the main fuse. But what is year model and is engine Kohler or Briggs & Stratton? It may depend on the above, but on an L110 the circuits that need to be protected are mainly the Charging Circuit, the Operator Presence Safety Circuits, and power for the Fuel Shut-off Solenoid which is under the carby fuel bowl. If the fuse blows the fuel shut-off solenoid will close and after a few seconds the engine will stop. But even if the engine could keep running the safety circuits would respond as designed and earth out the magneto and that would stop the engine. The engine has an AC "alternator" under the flywheel and a rectifier/regulator which changes the alternator's output current from AC to DC and then regulates it to suit the battery's needs. Depending on engine model this charging system may have up to 16A capability, so that is why the fuse is 20A.
Hope this helped
Pete
<ohpedro@hotmail.com>
Nov 03, 2013 | John Deere 420,1020,2010,2020,2510,2520...
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
John Deere 6200 6300 6400 6500 7500 Water Pump (John Deere) Logo
46 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
