Question about Kenwood GPS
Press buttons do not work on the bottom of my Kenwood DNX-7220, everything else does through touch screen or remote
Problem first started when I pressed the up volume button and it went up to max and the down volume button did not function. After a few minutes the buttons worked. This happened a couple of times. Then all the press buttons on the bottom of the unit do not work (on/off, volume, door open, and the others). I can operate the unit with the touch screen but when I switch from ipod to gps, I cannot get back to ipod as there is nothing on the gps screen that can send me back. Right now I use the remote to switch from gps to ipod. I use the touch screen for volume control. My backup camera does not display now when I back up. The GPS and everything else works fine....only the buttons on the bottom of the unit do not work. I think the power connection to this area is broken.
  • Ross Lozon Jan 03, 2013
    Thanks for the input. Either I have dust in the area around the buttons that needs to be cleaned or I need to replace the BR2325 battery. The unit is around 3 years old so the battery may be dead. Funny that everything else works. Would not have thought the buttons rely on a battery to operate.
SOURCE: Touchscreen problem
I corrected my problem. It was a pain, but I pulled the thing apart and cleaned the screen around the edge of the frame. It had alot of dust and particles there. Put it back together and with one calibration it works fine.
Posted on Dec 17, 2007
SOURCE: doesn't opperate
I have the same problem.
Posted on Mar 06, 2008
SOURCE: powers up but no display
Battery can be replaced by you with a soldering gun. Battery is a BR2325 which is hard to find, but a CR2325 works just fine and will last longer. The BR2325 with legs for soldering to pc board is available
from Digi-key an online supplier for $1.73 US. It is easy to do. Understand that all prior waypoints and tracks are lost when this battery is replaced.
Posted on Sep 21, 2008
  • 27 Answers
SOURCE: GPS INSTRUCTIONS
this may sound silly but your reset button may be stuck on on.
try resseting everything and updating the device.
Posted on Jul 01, 2009
  • 4090 Answers
SOURCE: Hello, There,
The first bit of advice, never leave the gps in the car the temperature can warp the motherboard and the case
The battery is low too low to allow for the unit to reach the satellites. eratic behaviour is also part of low power. recharge the battery
Posted on Aug 12, 2009
My audio setup is look how do I unlook it on a kenwood dnx 6140
Press the SOURCE button for control below the Nav button on the unit. The bottom right of the screen will show a wrench icon. Press the wrench icon button. From here you select Audio Setup. Subwoofer ON OFF is an option on the screen .
Feb 28, 2017 | Kenwood Car Audio & Video
My screen on my kenwood dnx 6990hd says (DC OFFSET ERROR) What does thay mean
Basically that means there is an overload or some form of power issue with the machine.
The best thing to do is reset the unit to start with. Do you have the manual?
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 28, 2016 | Kenwood Knob Dnx-6980 Dnx-6180 Dnx-6190hd...
Esquire Wireless shuts off during play
Think I might just have discovered the issue here. I had the same problem but didn't realize that the volume was maxed on the unit (as I was controlling it through the phone). As soon I brought the volume down on the unit the problem went away.
Apr 13, 2014 | Harman Kardon Audio Players & Recorders
Screen goes crazy
It could be a wire that become exposed in the back of the radio. If it works good when your engine off. It's doing it when you have the engine is runing because more things are running wich could cause a short out.
Feb 14, 2014 | Kenwood DNX-6990HD Double-Din indash...
Volume at max and won't go down
This sounds like a common problem on these TVs. Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Aug 12, 2012 | AOC L42H861 42 in. LCD TV
LG touch phone. Touch screen keeps blanking out, it that the touch screen will not work. Screen shows everything but the touch of the screen does not work. I have took out the battery and replaced it. It...
when phone is idle, the auto lock feature locks out the screen. you can set the time when lock engages or disable completely. To unlock, press top right corner button or use touchscreen options by sliding finger up from bottom to top or press unlock button on bottom of touchscreen
Feb 19, 2011 | AT&T Cell Phones
Volume buttons on kenwood dnx 8120 are not working
Hello. Any one please help. the buttons on my kenwood DNX 8120 arent working. the touch screen and all else is fine. Help fix. thanks' Dra.
Sep 25, 2010 | Car Audio & Video
My kenwood dnx7120 button won't work but the remote n touchscreen works. how do i fix this
I have a dvd stuck in my dnx 7120 and the buttons at the buttom dont work. How do i eject the dvd with the touch screen
Sep 08, 2010 | Car Audio & Video
GPS Logo
227 people viewed this question
Top Kenwood GPS Experts
Michael Galve
Michael Galve
Mike
Are you a Kenwood GPS Expert? Answer questions, earn points and help others
