My Acer Aspire has lost all the icons on the work tray. I can't get any sound or connect to the internet.
All of my icon on the bottom right side of my laptop has disappeared. I can't get on the internet or get any sound. Are there any solutions?
  • Mike Wilson Jan 07, 2013
    I am using Windows XP. I tried the procedure you sugested. It didn't work. Thanks; I'll have to try something else.
  • 7,627 Answers
What OS are you using? This should work on your version of Windows. Open the Task Manager, highlight explorer.exe, click on end process, open File, top lelt corner, click on New Task (Run..), type explorer, click on OK. That should reset your Tray Notification Area.
Posted on Jan 02, 2013
  • Mike Wilson Jan 02, 2013
    I spoke too soon. It didn't work. I'm using Windows XP
  • max carson
    max carson Jan 03, 2013
    The procedure will reset the Tray Notification Area. When did this occur? Have you tried a system restore? What happened prior to this?
acdr
  • 1913 Answers
SOURCE: my wireless isnt working on my acer aspire one
go to my computer properties device manager network adapters.then enable it if disabled.
Posted on Jan 05, 2009
shivam4529
  • 150 Answers
SOURCE: My laptop won't connect to wireless internet...
It seems the two oval lights on the front of the Acer TravelMate 3003LCi are not only lights to indicate WiFi traffic, but also buttons to turn the WiFi radio on and off for security reasons. If you press and hold the left side button for 3-5 seconds it should turn back on the WiFi radio. Windows XP (and maybe other OS’s) have a power saving function that turns the radio off when not in use to save the battery, so you have to use the buttons to turn the radio back on. Seems like a pain in the @$$ to me, but it’s a clients laptop not mine so he will have to live with that.
I hope this helps someone so they do not have to go through the frustration of trying to figure out why the radio has been turned off.
Posted on Nov 15, 2007
SOURCE: My acer aspire one mini notebook doesnt connect to internet
This will happen if you let the battery go completely dead. Some files become corrupted.
Solution:- Right click on Settings (preferences some models). Select 'Network' then double click on 'gFTP'. Scroll down to '.gconf' and double click. select and double click on 'system'. Right click on 'Networking'. Scroll down to 'Delete'. Left click on 'Delete'. Confirm 'YES'. Turn off the computer, then restart. What you have done now forces the computer to re-create the networking file. Your networking icon should re-appear on the taskbar. Note this is only for LINUX systems. - Good Luck!
Posted on Feb 25, 2009
  • 40 Answers
SOURCE: cant get into the network center on my acer aspire 1 ,
If this is an aspire One with linpus lite linux,
The network center disappearing is an issue with the linux update server that seems to corrupt the OS.
The solution unfortunately is to reload the OS from the recovery disk.
The aspire ONE does not come with an ODD so you will need to use the disk on a unit that has an ODD to make the recovery USB flash drive.
You will need a USB flash drive that has at least 2GB of storage, a computer with an ODD, and the linpus recovery disk that came ywith your unit.
1. Boot to the linpus disk, one of the options should be to make a recovery USB drive, make sure that no important data is on this USB drive as it WILL be formatted and erased.
2. Follow the on-screen instructions and then insert the recovery flash drive in to the USB slot of the Aspire ONE.
3. Re-start the Aspire ONE and press F2 to go in to setup.
4. Change the boot order to boot from "USB HDD" and press F10 to save and exit.
5. Unit will reboot and recovery will start.
Posted on Jun 27, 2009
  • 5 Answers
SOURCE: lost bluetooth icon in system tray
go to my computer and C and program files... and open widdcom and find bttray aplication duble click.... its finito
Not connect to the wifi
Locate the Wireless LAN switch located on the front of your Acer Notebook. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. Move the switch to the right to turn on Wireless connections. Right-click the network icon located on the system tray next to the clock. You should see a list of available wireless networks. Select the network you want to connect to and click "Connect."
or
Power on the Acer Aspire laptop. Right-click the wireless Internet icon in the lower right corner of the desktop. Select "Enable" from the pull-down menu. Right-click the wireless icon again. Select to view all available wireless networks in the area. Momentarily a window appears with all of the available Wi-Fi networks. Select the Wi-Fi network you want to connect to, then type in the password (if required). Click "Connect," and your Acer Aspire computer connects to the Internet. Hope this helps.
Jan 16, 2013 | Acer Aspire 3690 Notebook
Turn on WIFI on Aspire 3620
or
hope this helps
Oct 11, 2012 | Acer Aspire 3620 5560 TravelMate 2400 2420...
Acer Aspire 5733 Wireless connection lost
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
Sep 13, 2012 | Acer Aspire 5733 Laptop
I have an acer 5553-5097 and wen i try to conect to internet is says unidentified network no network acess, please help
Right click on your "internet" icon in the bottom right side of the screen, and click diagnose problems. This should work, if not, restart your computer. If this is a network you have connected to before this should fix you right up.
Feb 28, 2011 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Cant find connect to internet icon on task bar
right click your my network places icon from the desktop. Select L ocal area network. Right click on that and select properties. Select Internet protocol TCP/IP. At the bottom you can find show notification icon when connected. click on the check box.
Dec 12, 2009 | Acer Aspire One AOA150-1570 Notebook PC
Lost signal on acer aspire 6530 lap top, dont know if my daughter has pressed a wrong button or switch ?
There is a little satellite icon next to the always blue (when turned on) skip to next (song) and stop (square) touch buttons. Put your finger on the satellite icon for a few seconds, then move off, a green message should come up on the bottom of your screen saying "Wireless LAN enabled", if it says "Wireless LAN disabled" then there is another problem with your connection.
When the wireless is enabled check that you're connected to the wireless network. Start > Control Panel > Network and Internet > Network and Sharing Center (in Vista) you should be able to see:
"Access Local and Internet"
If it's not connected to the internet try resetting your wireless router, if that doesn't work, check you have the correct network password. Right click the two little PC screens (icon) in the bottom left, in the new window right-click your network and go to properties. In the new window, "Security" tab check the settings and type in the correct network security key (password) again. Hopefully you will have a record fo the network security key or your problem will have already been fixed before you get to this point. :)
Sep 27, 2009 | Acer Aspire 6530-5143 Notebook PC
Acer Aspire On Netbook - lost wireless connectivity completely
Relax.. check all your drivers in device manager:
Vista- type device manager at startup
XP- right-click my computer -> hardware -> device manager
Make sure all the drivers is ok with no question marks or errors, if it does, reinstall your drivers from your driver CD.
Apr 03, 2009 | Acer Aspire 1414 Notebook
My daughters acer one will not connect t the internet and there is no connection icon in the system tray can anyone help
Right Click on "My Computer"
Select "Properties"
Select " Hardware" tab
Click "Device Manager"
click the "+" sign network icon
check if the wireless card is there.
if you see the wireless icon..
then Go to Control Panel
select Network and Internet connection
Select Network Connection
then Right Click the wireless connection ( menu will pop out)
check if the wireless is Enable
to restore the icon to the desktop: select properties after the instruction above
on the general tab
check the " Show icon notification area...
Check "notify me when......
Mar 15, 2009 | Acer Aspire One PC Notebook
Acer aspire lost internet connection how do i connect
Look on the Function keys on the keyboard (the F1 through F12 keys) Do you see a wireless icon on one of the keys? If you do, then look for a Function (Fn) key on the keyboard. Press and hold Fn, while holding Fn, press the funtion key with the wireless icon (example: the wireless icon is on the F2 key; press and hold the Fn key, while holding the Fn key, press F2, release both keys).
Mar 01, 2009 | Acer Aspire 5735 Notebook
Notebook Acer Aspire 4720 Set Wireless lan Not working.How to.Tell me Please. Thank You. paharata@hotmail.com
three switches to check.
one on side that is mechanical....check
wireless connection in control panel, network connections...check...
bottom right in tray...right click on the icon...repair...check.
let us know.
Oct 09, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
