Question about Directed Electronics - Python 413 Remote Start System with Two 4-Button Remote/Transmitters
Python 413 won't start my 2007 tundra
Yes i have a python 413 remote start worked good for months then quit starting my truck? my truck is 2007 toyota tundra with engine immobilizer. its seems like getting no gas?? starts fine by key?? any help?? dealer went out bussiness sloppy work but cheap and yes paying for it now.
2 Suggested Answers
  • 344 Answers
SOURCE: python 413 wont start truck seem like no gas
Take it in to who ever installed it to be check out,
Posted on Nov 29, 2012
Python remote start lighting sequence
The automated lighting has ambient light sensors and an electronics package that can cause similar issues when they fail.
Mar 08, 2017 | DEI Python 1400XP Remote Start/Keyless...
Remote start python 533 attempts to start the car, shuts off, then on a again, does it 3 times, then stops
There are three possibilities for the situation you are describing especially if the vehicle has been cold for a while. The first possible cause occurs when the smart tach feature is used. In this case, the 533 is not receiving the proper signal from the vehicle that shows the engine is running. The remedy for this problem is to connect the tach wire from the 533 a proper tach source. The other two causes occur when the smart tach feature is not used and the tach wire is connected. If the tach wire is not connected to a good source for the tach signal in which case the wiring will need to be corrected. Otherwise, the tach signal will need to be relearned.
Jan 17, 2013 | 533 2way Security Remote Start System
Python 413 wont start truck seem like no gas
Nov 29, 2012 | Directed Electronics - Python 413 Remote...
Tundra won't start after ran out of gas
Your fuel pump is packed up and you should change you fuel filter as well its clogged
Oct 30, 2012 | 2007 Toyota Tundra
I need to reset my remote start. My car is starting every three hours
Your remote starter is in timer mode. Pressing the lock and unlock buttons simultaneouly activates the timer mode. When you activate the timer mode the vehicle automatically starts every three(3) hours and runs the preset runtime for a maximum of six(6) starts.
You can cancel the timer mode by starting the vehicle with the key. If the timer mode is a problem then apparently you are setting the timer mode everyday.
Sep 30, 2012 | 4103P Python 413 Remote Start System with...
My 2007 tundra went dead. The ignition won't start
There are several possibilities ranging from a defective starter, to bad cable connections, to the onboard security system locking out the starter relay, or an aftermarket accessory interfering with the starter circuit, or a locked-up/damaged engine.
I have had vehicles towed into my shop for similar complaints when the only problem was that the customer was using a cheap duplicate key that they had made at the hardware store that did not have the required computer chip in it.
I have also had vehicles towed in where the customer had replaced the battery and did not have good cable connections or forgot to connect one of the wires that was supposed to to get hooked-up to the battery connector.
Then there are the questions: Are you getting any kind of "clicking" noises when turning the key or is it completely dead? If it is clicking, WHAT is clicking? Is it the starter motor itself that you hear or just the starter motor relay? Do you have battery power at the starter "S" terminal when turning the key? If not, is the transmission selector in "PARK"? Does the shift indicator on the dash indicate that the transmission range sensor is in "PARK"? (possible defective transmission range sensor) Are there any fault codes stored in ANY of the modules connected to your onboard computer network?
It is really hard to say without being able to see the truck.
Mar 18, 2012 | 2007 Toyota Tundra
Directed Electronics - Python 413 Remote Start System with Two 4-Button Remote/Transmitters Logo
41 people viewed this question
Top Directed Electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Directed Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
