I have a kenmore elite oasis washer model #11027087601 i need to pull the inner tub. how?
I have the washer half torn apart and Im trying to get the inner tub out. im wondering if there is a trick to pulling it out before i just horse on it and break something else. i have got it to slide up the shaft about an inch
5 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: washer wont spin or wash
F51 trouble code is the washer sensor. Try unplugging the system for 1 minute then plug back in and see what happens =. If that does not work then open the back of the washer by the knobs and in the middle there are 3 sensors check which one has a burnt mark on it and replace it. Other thing is to call Kenmore and see if they will come out and replace since this is a VERY serious problem.
If you are satisfied with my answer please raate
Posted on Feb 12, 2009
  • 1937 Answers
SOURCE: I have a kenmore elite washer mod.#110-27062602
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.27062602&pathTaken=partSearch
Assuming that this is the Oasis type washer, see the Whirlpool Service Manual for their Cabrio washer which is basically the same as the Oasis.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
It has troubleshooting and teardown procedures.
Posted on May 08, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite oasis washer has error code f1
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: my kenmore elite oasis He washer model 110.2708260...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 27, 2010
Kenmore Elite Oasis washer does not lock
First, OL/UL stands for "Overload", so in other words, the washer things the tub is too hard to move because it's overloaded and the motor is struggling or the unit is way out of balance causing the washer to struggle. The most common problem is a nut below the inner tub that needs to "float". Floating is when the tub fills up with water to a certain level the inner basket will rise about 1 inch from the center agitator. What this does is disengage the basket from the motor so that the agitator can rotate independently from the basket. If the basket does not float then when it tries to agitate the whole basket will turn back and forth at the same speed as the agitator and this will cause the OL/UL error code.
Nov 22, 2012 | Kenmore Oasis 4.6 cu. ft. Canyon Capacity...
My Kenmore Elite Oasis HE model number: 110.27072603 washing machine shows LID error code. It wont work at all.... went half way through cycle... help.
Greetings,
this washer has a lid switch problem...or possible main board failure, but lid does concentrate on the lid safety switch. If you remember when you open the lid it stops..well, its a safety feature and prevents tub from spinning with lid open...this one is more difficult to service if your not use to working on washers...try unplugging machine and leaving off for awhile...does the door lock? check switch for lid fault
Nov 25, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite oasis he has a rattle inside when starts to spin and when it slows down. sounds like loose change but i cant see how the money could get between the inner walls. unit is 2 years old.
Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
the rear tub.
Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
the front tub removed. Go ahead, remove the pulley and bolt, and if
the basket comes out, then check everything out.
If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
and tub assembly.
Front - loader: Remove Bellow
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
May 24, 2010 | Kenmore Oasis HE 27082 Top Load Washer
May 08, 2010 | Kenmore 22422 Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer wont spin or wash
Feb 12, 2009 | Kenmore 27032
Kenmore Ellite Oasis - model #27042603
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Jun 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
