Question about AO Smith Pump Motor 1.5 HP 2 Speed Thru Bolt BN50 115V
Bn50 pool pump bearing replacement
Bearing replacement
  • fec1950
    fec1950 Jan 03, 2013
    I need to replace the sealed bearing in the motor, It seems to be running ok just very noisey. I have repaired motors before but not pool pump types. Do you have to have a puller to remove the bearings???? And do you need to have them pressed on???
2 Suggested Answers
tbreeze47
  • 3083 Answers
SOURCE: We have a AO Smith
Here is a replacement motor:
http://www.spapumpsandmore.com/SearchResults.asp?Search=+177803-02
You might have to sign up for shipment, but it looks like they have them.
Good luck, and hope this gets you going again.
Posted on Sep 12, 2010
Information on bearings replacement intelliflo 4 160 pool pump motor
If you have the necessary bearing pullers and the replacement bearings and the shop press, then go for it. Otherwise, a new motor is the best bet.
May 10, 2017 | Pool Pump Pool & Spa
Bearings for electric motor
replacing bearings can be tricky, but if you are willing to try most of these motors use 6203 2rs c3 bearings all for the back bearing, the front could be 3 different sizes. after removing them bring the rotor to your local pool pump motor repair shop, and have them remove and replace. about $20.
Jul 15, 2015 | Hayward 2HP Pool Pump Motor A O Smith...
I have century lasar pool/spa motor bn50 115volts 16.4/4.4amps 1.5hp 2spd runs on lowspeed but will not run on high speed can it be repaired or what?
I'd start by checking the relay that controls the motor first. Put a meter on it and verify that the high speed terminal is getting voltage. If not, it is the relay or something other than the motor. If the high speed terminal is getting voltage but not kicking on, a fix is possible, but you may want to weigh that against the price of a new motor.
Aug 16, 2013 | AO Smith A O Smith Motors Century 1hp 115v...
How to replac bearings in century pool & spa motor
if bearings are bad motor overheating and ruining seals replace whole unit less hassle
May 10, 2012 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
REPLACE BEARING IN A USQ1202 POOL MOTOR AND STILL NOT SOUNDING CORRECT. NOT SURE WHAT GOING ON. NEED HELP
bad bearing, damaged bearing during install or a bad end bell= makes a low to high roaring noise over and over
Jul 15, 2011 | Smith 2hp Pool Pump Motor A O Electric...
Start pool up this year pump is louder makng whine noise, works fine and it is not getting hot Is the pump going
loud screaching noise??? sounds like bearing failure. this most common failure of pool motors. YOu can try to replace the bearings or replace the motor.
May 22, 2010 | Hayward 1.5hp Max Flo Inground Pool Pump #...
I have a Hayward max-flo ii pool pump and it is very noisy. I already replaced all seals because it was also leaking. Are the bearings the cause of the noise? If so how do I replace bearings?
The bearings have likely lost their lubrication and have failed. You may be able tot find a local electric motor repair shop to replace the bearings. It really is not a diy project. However, if you can't find a local shop to do it, most folks replace the motor.
May 15, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
How do i tear down impellar housing on ao smith 2hp bn50 pool motor?
take the impeller housing cover off. the shaft is threaded onto the impeller. Host the shaft and unthread the impeller.David
May 16, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Pool pump is very loud
loud pumps are most times caused by bad bearings and need to be replaced or better yet replace the whole pump new bearing cost about $100 to replace but not always easy to find someone to do hope this helps
Mar 13, 2009 | Hayward Super Pump 1 1/2 - Hp for In...
AO Smith Pump Motor 1.5 HP 2 Speed Thru Bolt BN50 115V Logo
61 people viewed this question
Top AO Smith Plumbing Experts
David Baisa
Lawrence Oravetz
Boyet Soriano
Boyet Soriano
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
