Olevia 323 s13 doesn't have a coax cable connection how do you connect to cable
freetek
  • 5568 Answers
SOURCE: No cable signal on 32" flat panel Olevia tv
When you write 'tuner,' do you mean the internal TV tuner or do you have a cable box between the wall connector and your set's input?
If you are connected from the wall to the set, then the sensitive circuitry (it may only tolerate a few volts max video) is damaged.
If your set was a couple of decades old, it might be fairly easy to repair.
If the set was damaged via the cable service, you may have some recourse unless your cable provider has seen fit to absolve themselves from liability, I suspect they have.
I do not know your set but it is not impossible that the video input circuitry for cable and antenna is on a smaller assembly that processes it before reaching the main board.
The latter has obviously survived since you still have the other functions.
Posted on Aug 02, 2008
ginko
  • 19396 Answers
SOURCE: olevia tv
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where you connect the video and audio cables, if a signal board is defective, then you may get no picture on particular inputs located on faulty board.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on May 25, 2009
  • 2318 Answers
SOURCE: my 42 inch sylvania plasma tv does not have a coax
Since your TV only has audio and video input jacks, you can connect those to audio and video output jacks on the VCR. Now connect the coax cable to the RF/ant input on the VCR and you'll have to change channels by using the VCR channel selector.
Let me know if you require further assistance.
Posted on Aug 08, 2009
  • 1779 Answers
SOURCE: I need the codes for a new remote for a Olevia TV
Olevia is an extreme off brand. Try the codes for Polaroid, Syntax ect, all the off brand codes.
Posted on Jan 17, 2010
SOURCE: Tv with out coax inputs.
you can run it through a cable box or vcr that has a coax input and rca output.
Posted on Dec 17, 2010
Hooking up my ps3 using HDMI cord to my olevia 232-S13 and it says invalid format
Setting up your HDMI cable on your PS3 games console
1: Turn on your TV and set its input to HDMI.
2: Make sure your PS3 is connected via a HDMI cable.
3: Power on your PS3 and press and hold the power button for approx. 5 seconds, you will hear the PS3 start to beep, release the power button after the second beep.
4: Your PS3 should automatically configure itself for HDMI video and Audio output.
Jun 28, 2015 | Olevia Televison & Video
Connect my Olevia 323 with the signal if there is no coax input at the tv??
HAHAHA not possible it has to have a coax either from an antenna or a cable provider . unless you only plan to use as a dvd monitor
Jan 28, 2015 | Olevia Televison & Video
Arc connection doesn't work with directv
Some Directv boxes don't support ARC so you may have one that does not. There is an easy way to get around this, use an optical/ coax cable instead.
Nov 25, 2012 | Denon AVR1713
My ilo hdtv doesn't have a cable hook up
Going to have to connect (no coax fitting means it is a monitor with no tuner) via one of the rear audio/video inputs with a box that has those outputs on it.
HD is almost always connected in this way.
May 02, 2012 | iLO IWT3206 TV
Get "no signal" with coax
Check the input selection on the TV, it maybe set incorrectly.
Jan 22, 2011 | Olevia 237T 37 in. LCD TV
I have an olevia model 232-s13 started to have a fine line throug
you could sell it to me for 100 for parts tony 707 5381732
Mar 09, 2010 | Olevia Televison & Video
Jul 29, 2008 | Olevia LT32HVM 32 in. LCD Television
Olevia 232-s13 32"
Just talked to Cust Supp, on the back you will see 6 round holes around the label. The screws needed will be 6mmx12mm. I have to do the same tonight. good luck
May 15, 2008 | Olevia LT32HVE 32 in. LCD Television
Olevia LCD 32 inch
You can hook up direct but you will not get hi def channels, only the standard or digital depending on your hook up.
Oct 12, 2007 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
