Question about Honeywell HBC5WT High Impact ABS Off-white Plastic, 3-axis Rotation, Cable Feed Through Large Enough for BNC, Light Duty Wall/ceiling Mount
How to fix code B1230 on 1999 ford exploer - Honeywell HBC5WT High Impact ABS Off-white Plastic, 3-axis Rotation, Cable Feed Through Large Enough for BNC, Light Duty Wall/ceiling Mount
How do i fix my over head compass in my 2000 ford exploer
THE COVER SHOULD HAVE SOME SMALL SCREWS ? IF NOT? THEN IT SNAPS OFF BE CAREFUL FOR THE TABS CAN BREAK. DUE TO AGE AND HEAT. MAKES THE PLASTIC BRITTLE.. AND THEN THEIR SHOULD BE SOME SMALL SCREWS OR IT COULD UNWIND / SPIN OFF / SPIN ON.. MAKE SURE TO DISCONNECT WIRING BEFORE.
Dec 09, 2014 | 2003 Ford Explorer
Ford exploer overdrive
Is the check engine light on?
Feb 03, 2013 | Jeep Grand Cherokee Cars & Trucks
Were is bank 2 sensor 1 located 1999 ford exploer
Passenger side exhaust before the catalytic converter.
Mar 14, 2011 | 1999 Ford Explorer
2005 ford exploer will not start put new battery
did you check fuses under the dashboard and if you did then you may have a resest switch that needs to be reset sometimes found on the left side of the whell bering wall and just sometimes the computer needs to be reset also
Jun 25, 2010 | 2005 Ford Explorer
I did the OBD 2 fault code test on my 2002 ford exploer. Auxiliary emission control code P1400 is what came on. What do i need to do to fix it?
DPFE EGR Circuit Low Input". for a P1400 code . The sensor is located on the pass. side of the eng comp. back near the firewall. It sits on top of two small rubber hoses that attach to metal tubes. These tubes lead down to the EGR tube. . Good luck
Mar 29, 2010 | 2002 Ford Explorer
On a 1991 ford exploer wheres the fuel relay switch under my hood
My friend;
Try this;
  1. Remove the Hood & look up for a black plastic box at LH .
  2. Normally that box comes in the cabin LH side of steering column.
  3. The other box On LH side of your Engine compartment.
Or consult the internetFord exploer Forums.
Or Google search window. images.
Try it, & PLZ; let me know if I add any benefits to you.
I hope I add some thing valuable to you.
Regards;
MAR;
soer2@yahoo.com
Nov 09, 2009 | 1991 Ford Explorer
Factory code for 2006 exploer keyless door pad
if factory installed. take your title to show that you own the car to a ford dealership and they will contact ford to get the code. they will not give out the code unless you own the car.
Jun 10, 2009 | 2005 Ford Explorer
2002 Ford Explorer code #P1451
look under hood . its on the front right.
Apr 06, 2009 | Ford Taurus Cars & Trucks
Honeywell HBC5WT High Impact ABS Off-white Plastic, 3-axis Rotation, Cable Feed Through Large Enough for BNC, Light Duty Wall/ceiling Mount Logo
106 people viewed this question
Top Honeywell Home Security Experts
Sean
Mike
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
