Question about Wrangler Jeep Twin Stroller
No start i have 1998 jeep wranger its getting fire to cap but not to plugs
  • 21 Answers
Could be camshaft possition sensor. Located in distributor assembly. Relatively easy fix, but costs around $150 being that it is a dealer only part. Hope this helps!
Posted on Jun 15, 2009
Won't go forward or back
what wont, what jeep, and what engine, and what trans.
and year.
like 2002 Jeep Wranger, with 5speed manual stick
or 2008 Jeep Wranger, with 6speed mt box
pretend we are blind, we are...
got PT 4wd. is transfer case i neutral>?
Feb 06, 2014 | Jeep Cars & Trucks
99 jeep wranger 4.0 Engine.... Just started this week... At start up it is taking longer cranking time before engine fires up... It seems to be getting progressively worse with each time I start the...
if your battery, and starter and plugs and wires is ok, then i would give the vehicle a fuel pressure test to see if the fuel pressure is ok according to the specs, if it is ok, i would check the fuel injectors.
Jun 18, 2011 | Jeep Wrangler Cars & Trucks
I have a 1998 jeep wrangler 4 cylinder it is not cranking because it is not firing what could be the cause?. I have pulled the plug wire off to see if there is fire but it is not getting fire to the plugs.
COIL PACK HAS PROBALLY CRAPPED OUT.IF IT ELECTRONIC. SEE IF THE COIL WIRE HAS SPARK IF SO COULD BE A BAD CAP WIRES AND PLUGS OR ROTOR OR TIMING HAS JUMPED ON THE ENGINE
Oct 27, 2009 | 2002 Jeep Wrangler
Miss Firing
You might have a small leak in your vacuum system, check all of the hoses and plugged vacuum connections. Check your plugs and wires, distributor cap and rotor. Sometimes a crack in the distributor cap will cause carbon to build up. Since carbon is an electrical conductor it might be jumping from one cylinder to another that is not in line with the firing order.
Jul 10, 2009 | 1998 Jeep Grand Cherokee
4 cyl. won't start,new plugs, wires,cap,etc.
a crank sensor tells the coil to fire.are you getting a signal at the coil to fire?
May 25, 2009 | 1995 Jeep Wrangler
Backfire into intake
I'ts quite possible that your distributor is installed one tooth off and is too far advanced, causing the plug to fire before the intake valves are closed completely. Turn it one tooth counter-clockwise and try it again.
Mar 25, 2009 | 1998 Jeep Grand Cherokee
I have jeep wranger i am getting fire to the cap but not to plug
did someone remove the rotor ? remove the cap and verify the distributor rotates when you crank the engine , and that the rotor is there , i doubt you have all bad plug wires , not even likely , so back to basics . a defective cap is possible .
J5
Jan 18, 2009 | Jeep Wrangler Cars & Trucks
Spark plugs
Firing order for the 4.0L 6-cylinder is as follows:
1-5-3-6-2-4
As for the spark plugs, it looks like the Autolite AL 985 plugs are what you need. If you are going to replace the plugs, might as well also replace the plug wires, the distributor cap and rotor (if you have those, I dont recall which year they went to the distributorless ignition).
Dec 31, 2008 | 1998 Jeep Cherokee
98 jeep cherokee classic
camshaft position sensor.
Aug 18, 2008 | 1998 Jeep Cherokee
Wrangler Jeep Twin Stroller Logo
73 people viewed this question
Top Wrangler Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Wrangler Baby Gear Expert? Answer questions, earn points and help others
