Question about Sport & Outdoor - Others
I NEED POLES FOR THIS 17 FT X 9FT NORTHWEST TERRITORY PORTLAND DOME TENT
I NEED POLES AND STAKES FOR THIS 17 FT X 9FT NORTHWEST TERRITORY PORTLAND DOME TENT SAYS IT SLEEPS 8 PEOPLE AND HEIGHT IS 70" IT SAYS NEXT TO THE UPC BAR CODE IT WAS MADE FOR KMART. I CALLED KMART THEY SAID SEARS.COM HAS SOME REPLACEMENT KITS THAT WOULD WORK THERE IS LIKE 8 DIFFERENT KITS. COULD SOME ONE TELL ME WHAT KIT WILL WORK WITH THIS TENT. THANK YOU INADVANCE.TIM
jaballou
  • 63 Answers
SOURCE: I desparately need some assembly instructions for my Barbie tent.
Mattel products, including Hot Wheels, Barbie and Polly Pocket:
In the US and Canada: 800-524-8697
Posted on Dec 09, 2008
  • 68 Answers
SOURCE: how to repair tent trailer roof
Go to an auto parts store and buy a fiberglass kit. Resin, hardener and cloth. Clean and rough the area. apply a coating of mixed resin, then a layer of cloth. Let it dry and repeat a couple of times. After you are satisfied with that get a gallon of Elastomeric, you will find it at Lowes/Home depot. Clean the entire top and apply 2 coats with a brush or roller about 24 hours apart. No rain or moisture for a couple of days. Project complete, water proof roof.
Posted on Mar 25, 2009
MNfisherman
  • 11896 Answers
SOURCE: Need replacement poles for Cabin Tent
Do you have a Northwest outlet in your area? Otherwise you can get it from the manufacture.
Posted on Jul 06, 2009
SOURCE: I need new poles for Swiss Gear tent # SG33071F
Go to Home depot and buy a tube that fit the pole. Cut it into 5 or 6 inches for the broken areas. It costs me less than 2 dollars. Let me know how it turn out on yours.
Posted on Aug 25, 2009
SOURCE: I have a greatland tent item #15710. This is a two
I am looking for a manual for Greatland Outdoors 2 room tent with screen porch item #15710, however, I guessed how the poles go together. I set up the tent by myself, but I recommend 2 people or more, especially if it is windy.
Start by stretching out the bottom of the tent into a square, and stake all of the perimeter tentloops to the ground, starting with the corners, with the stakes directed at a 30 to 45 degree angle under the tent, so the tent cannot easily pull them back out. Leave the yellow cords attached to the tentloops loose, so you can use the cords to help pull up the stakes when you take down the tent.
Now assemble the poles going through the loops across the front of the screen porch. Insert one end of a pole #1 into a pole #2 and thread them through the loops over the entrance to the screen porch. Put the long end of a curved pole #3 through the loops starting from one side, and attach to either side of the 1/#2 you made. Put the long end of another #3 through the loops starting from the other side and attach to the loose end of the #1/#2. You should tie the loose green cords on each corner of the sceen porch to the silver metal rings at the curved end of each #3.
Later, you will do the exact same assembly with a #3 on each side of a #1/#2 for the poles going across the back of the tent and the poles going through the pocket across the middle/top of the tent.
Now insert the small end of pole #4 into the curved end of a #3, then insert the small end of a #5 into the open end of the #4. There should be a rubber foot on the bottom of the #5 pole. Do the same thing for the other side of the porch. With help, you should be able to prop up the front of the sceen porch, pulling aganst the stakes holding the rear floor of the tent, and place the rubber feet of the #5 poles close to the center loops of the floor on each side.
Now prepare the #1/#2 poles for the rear, and attach a #3 to each side and tie the loose green cords to the silver rings on the short ends of the #3s. Prepare a #4/#5 pole the same as the front, and prop up the back of the tent, putting the feet near the side loops of the floor which are about 1/3 from the rear of the tent.
Make another #1/#2/#3, and push it through the pocket across the middle of the tent, and connect the last #3 from the other side. The side supports for the middle are pole #8 with the white clamp on the bottom, and pole #7 slid into pole #8 (The #7 was scraped off both of mine). Leave the #7 mostly inserted into the #8 until after the center is lifted up. The #6 goes on top of #7, and insert the #6 into the curved end of the #3 poles which are already in the center pocket, and tie the loose green cords to the silver rings at the short end on each of the #3s. Now lift up the center with someone helping on the other side, and put the feet of the #8 into or near the yellow loops at the center of each side. Loosen the white clamps and extend the #7 poles until the peak of the tent is at proper height.
Move the feet of the #5 poles closer to the tent, until all is tight, and you should be done!
Posted on Sep 20, 2009
Where can I order replacement poles and pieces for my northwest territory front porch tent
check with the place you got your tent.perhaps they know who makes it ,
Feb 19, 2016 | Sport & Outdoor - Others
Where can I find an instruction manual at for the Northwest Front Porch Tent?
This video is as good as anything although I wouldn't pitch it on a hill! These are written instructions;
Setting up Northwest Territory Front Porch Tent
Nov 03, 2015 | Sport & Outdoor - Others
I have had a tent donated to our agency. Where can I get directions for erecting and finding missing parts?
This tent was made by NorthPole, which has closed its parts department. Check this notice, which does list some places you might be able to get some parts.
I caution you that this was a department store tent, made to hit a price point, and sourcing a few parts might cost far more than the tent it worth.
Aug 05, 2015 | Northwest Territory Family Cabin 8-Person...
How do I assembly the tent
Step 1 Remove the tent, poles, stakes and tent rope of the dome tent from the Northwest Territory sack. Locate a large flat area and remove any sticks and rocks from the ground. Step 2 Lay the tent fabric on the ground with the bathtub style floor face down. Pull the corners of the fabric tight and rotate the tent so the door is facing in the direction you want. Use a hammer to stake the corners in the ground. Step 3 Assemble the two long poles to their full length. The pole segments are connected by chords and will easily snap into place. Slide one pole through the diagonal sleeve on the top of the tent. Slide the other pole through the other diagonal sleeve to form an "X" with the poles. Step 4 Place the end of each pole in the corresponding grommet. The poles will bend and the shelter will be erected. Step 5 Assemble the two small poles. Slide one pole in the doorway sleeve and the other in the back window sleeve. The poles will bend slightly to create a rain peak on the door and window. Step 6 Pull the doormat tight and pound stakes through the loops on each corner. Pull the tent rope tight on the back of the tent and pound a stake through the rope loop to anchor the tent to the ground.
May 31, 2015 | Northwest Territory Sierra Dome Backpack...
Manual for a northwest territory portland dome tent 17' X 9'
I NEED POLES FOR THIS 17 FT X 9FT NORTHWEST TERRITORY PORTLAND DOME TENT SAYS IT SLEEPS 8 PEOPLE AND HEIGHT IS 70" IT SAYS NEXT TO THE UPC BAR CODE IT WAS MADE FOR KMART.
Jun 01, 2012 | Sport & Outdoor - Others
I need assembly instruction for 8 person cabin dome tent with screen house
Clean the ground of any rocks, logs or big sticks. Open the stuff sack and pull out all of the contents. Pull the poles out of their pole bag and set them aside. Remove the tent stakes and set them next to the tent.
  • 2 Lay out the tent poles and assemble them. Push the rod blanks together to make the tent poles that will support the mesh tent body.
  • 3 Unroll the mesh tent over the cleared ground. Take care not to step on or walk on the mesh panels. Avoid sticks and snags, as the mesh rips easier than nylon tent fabric.
  • 4 Clip the Timbertop tent pole clips to the poles. There are no tent pole sleeves because Timbertop uses external pole clips for its mesh tents. Criss-cross the tent poles and push the tent pole tips into the metal holes at the end of the pole clip lines. The mesh tent will now be standing upright.
  • 5 Place one tent stake into the ground and through a pole strap stake hole. Pull the tent out as you insert the stake to keep the mesh panels tight. Stake down each pole strap around the perimeter of the tent. Unzip the doors to enter the tent. Zip up the doors quickly after entry to keep bugs and insects out of the tent.
  • Oct 23, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
    Jul 06, 2009 | Wenzel Swiss Gear Grand Lodge Cabin Dome...
    Sport & Outdoor - Others Logo
    Top Sport & Outdoor - Others Experts
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
