Question about Olympus Quick Shooter Zoom Point & Shoot 35mm Camera With 35-70mm Lens
Manual for Olympus Shooter zoom 35-70mm
I have the camera and lost the manual
SOURCE: zoom malfunctioning
Update the camera software online .....tha's what I did and it worked after 4 zoom error messages.
Posted on Apr 16, 2007
informatica
  • 1114 Answers
SOURCE: instuction manual for a Camedia Digital Camera C-725 Ultra Zoom
Hi - You can download the manual by clicking the link underlined in blue below:
C-725
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 11, 2008
SOURCE: lost instructions
my dad just gave me an olympus d 490 zoom. i am looking for an adapter. anyways, i did see where the olympus company has some instruction manuals that you can download on the computer.
hopes this help .
Posted on Jun 19, 2009
jonniewalker
  • 1029 Answers
SOURCE: Need manual for Olympus Stylus 850 sw camera
you can download the manual here http://safemanuals.com/user-guide-instructions-owner-manual/OLYMPUS/STYLUS%20850%20SW-_F Please note that the user guide is in French
Posted on Aug 30, 2009
  • 11967 Answers
SOURCE: Zoom Error with my Olympus SP-550uz
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 04, 2010
Lost instruction manual and need it to operate camera
You can download and print the instruction manuals for Olympus Camedia D-540 Zoom Digital Camera in PDF format by clicking these links:
D-540 Zoom Reference Manual (English - 5.2MB)
D-540 Zoom Quick Start Guide (English - 818KB)
D-540 Zoom Basic Manual (English)
Adobe PDF Reader is required to view the manuals. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manuals.
Thanks for using FixYa.
Dec 24, 2010 | Olympus Camedia D-540 Zoom Digital Camera
Tip
Olympus Camedia D-545 Basic Manual Models: X-550, D-545 Zoom, C-480 Zoom Have...
Have you lost the Operating Instructions for your Olympus Camedia D-545?
Click here to download a digital, searchable copy of the basic users manual / owners guide.
I hope that helps.
_____________________________________
The Olympus Camedia D-545 Advanced Manual is available here.
on Apr 15, 2010 | Olympus Camedia D-540 Zoom Digital Camera
Tip
Olympus Camedia D-545 Advanced Manual Models: X-550, D-545 Zoom, C-480 Zoom ...
Click here to download a digital, searchable copy of the advanced users manual / owners guide.
I hope that helps.
The Olympus Camedia D-545 Basic Manual is available here.
Tip
Olympus Camedia X-550 Basic Manual Models: X-550, D-545 Zoom, C-480 Zoom Have...
Have you lost the Operating Instructions for your Olympus Camedia X-550?
I hope that helps.
The Olympus Camedia X-550 Advanced Manual is available here.
on Apr 15, 2010 | Olympus Camedia D-550 Zoom Digital Camera
Tip
Olympus Camedia X-550 Advanced Manual Models: X-550, D-545 Zoom, C-480 Zoom ...
I hope that helps.
The Olympus Camedia X-550 Basic Manual is available here.
Tip
Olympus Camedia C-480 Advanced Manual Models: X-550, D-545 Zoom, C-480 Zoom ...
Have you lost the Operating Instructions for your Olympus Camedia C-480?
I hope that helps.
The Olympus Camedia C-480 Basic Manual is available here.
on Apr 15, 2010 | Olympus Camedia C-480 Zoom Digital Camera
Tip
Olympus Camedia C-480 Basic Manual Models: X-550, D-545 Zoom, C-480 Zoom Have...
I hope that helps.
The Olympus Camedia C-480 Advanced Manual is available here.
Olympus Quick Shooter Zoom Point & Shoot 35mm Camera With 35-70mm Lens Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
