My hp deskjet f2410 can scan but cannot print. The paper is able to run through but blank paper came out. There is no signal of low cartridge. Anyone can help?
SOURCE: HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Posted on Oct 22, 2008
  • 848 Answers
SOURCE: Deskjet F380 is normaly printing but it will print blank
If the printer is printing blank pages, make sure you are using the correct printer driver and make sure the paper size is correctly selected in the driver. If the printer is printing black only, the Ink option in the printer driver may be set to Black instead of Color or a setting in the software may be set to print black only. Also, the print head nozzles may be clogged. From the Utility section found in the printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
Posted on Feb 04, 2009
jilpeshpatel
  • 259 Answers
SOURCE: HP J4580 Printing blank pages
fist click the start menu
and click the printer and fax
and select the hp printer and rith cilck the proparties and seat the print colar coular that time
select only black...............ok
Posted on Apr 08, 2009
cene765
  • 787 Answers
SOURCE: hp 5550 deskjet not printing
This is typical cartridge problem.Which cartridge changed?This printer can print with the only one cartridge inside it, whatever which.Try this: Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
If this not help your printer has problem in carriage unit and need repair.
Posted on Nov 04, 2009
  • 16 Answers
SOURCE: HELP PLEASE
Remove one cartridge and close the access door. If the cartridge light goes off, the bad cartridge has been removed. If the light continues to blink, remove the other cartridge and reinstall the first one. If the light goes off, the cartridge in the printer is the good one.
Posted on May 31, 2010
I need a print copy of a user manual
[PDF]HP Deskjet 2540 All-in-One series
www.hp.com/ctg/Manual/c03847745.pdf
Hewlett?PackardAdvanced printer management tools (for networked printers) . .... Learn how to useyour HP Deskjet 2540 series. ?. Printer parts on page 4. ? ... Paper-width guide for the input tray. 7 ... Press the Wireless button and the Start Copy Black button from theprinter .... One corresponding cartridge is low on ink and will need.
[PDF]HP ENVY 4500 e-All-in-One series
h10032.www1.hp.com/ctg/Manual/c03784120
Hewlett?PackardThe printer is printing, scanning, copying, or is on and ready to print. ENWW .... You do not need to manually reload the paper or make any operations. ENWW.
[PDF]USER'S GUIDE - Brother
Dec 29, 2015 | Office Equipment & Supplies
PAPER FEEDS INTO PRINTER BUT COMES OUT BLANK
HP DeskJet f4280 Spitting Out Blank Paper. - HP Support ...
h30434.www3.hp.com > Printers & All-In-Ones > Print Issues
Solved: I can hear it printing, but the paper is blank when it's finished. ... Mark as New; Bookmark; Subscribe; Subscribe to RSS Feed · Highlight · Print · Report ... green checks say every thing is good to go, but the test print comes out blank,. ... Reinstall the cartridges into the product, and then gently close the cartridge door.
my printer is printing blank pages, and i just changed ink
Nov 18, 2015 | Office Equipment & Supplies
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
My hp deskjet f4180 printeris acting like it is printing, but the pages are coming out blank. The cartriges are new, they worked for the first few pages, then it started printing lighter, and lighter...
Hello. It sounds like the cartridges are running empty, strange that new cartridges would run empty so quickly. Depending on the cartridge number the 21 and 22 are very low capacity. you do have the option of using a 57 colour also which has approx double the capacity, but unfortunately the black is only a 190 page cartridge (according to them, real world testing has shown much less)
If it has been refilled try this link below to get it flowing again. http://www.fixya.com/support/r3986425-unblock_print_heads
If the Cartridges are HP Brand jump on the phone to HP to obtain a replacement cartridge.
F.Y.I Most compatible cartridges (21 and 22) have a capacity of approx 20ml of ink, compared to HP that hold approx 6ml. I would recommended SkyWell Brand of compatibles as they have great colour and a large capactiy.
I hope this helps Regards GM
Apr 26, 2011 | HP Deskjet F4180 All-in-One InkJet Printer
Hp deskjet f2410 installer
The installation software for the HP Deskjet F2410 printer can be found at the following site,
http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
When you arrive at the site, input your printer's model number (f2410), into the block marked,
" for product" and click the arrow, you will then be guided to the drivers for your printer.
You should be happy with the results.
Feb 01, 2011 | Office Equipment & Supplies
My printer hp deskjet f2410 blinking all..n then i'am can't printing my file..???please help me...
1.Check if there is low ink level in cartridge
2. Check if there is any piece of paper stuck inside
3. Unplug the power cord while its ON , Press and hold OK and CANCEL at the same time, while holding them plug in the power cable and then release the buttons.
It should fix the problem
Jan 03, 2011 | HP PSC 2410 All-In-One InkJet Printer
Top light blinking, will not print
I believe that the top light is the low printer cartridge signal. Did you replace the cartridge or just take it out and reinstall it? Did you use a new HP cartridge or refilled cartridge?
Try a new ink cartridge from HP and double check that you have the correct cartridge for your printer. If that doesn't solve the problem, contact HP.
Sep 15, 2009 | HP DeskJet 5550 InkJet Printer
HP Laserjet 1500 Color, Print out Blank
Hi devi960:
Pages print, but all
colors do not print or
the pages are
completely blank.
One of the print cartridges might be
low or empty.
Run an engine test and see if all four colors print. If
not all colors print, replace one or more of the print cartridges. If the
engine test is successful, replace the formatter.
If the printed pages are completely
blank, the file might have blank
pages.
Check the file to make sure that it does not contain blank pages.
A print cartridge might be low or
empty.
Check the printer control panel for a Supplies Status message,
print a Supplies Status page, or use the embedded Web server
(HP color LaserJet 2500 series printers only) to see the levels
remaining in the print cartridges. Replace any print cartridges that
are low or empty. Messages are not created for non-HP print
cartridges.
If you are using non-HP print
cartridges, one or more print
cartridges are low or empty. The
control panel lights do not indicate
low or empty for non-HP print
cartridges.
Replace one or more of the print cartridges.
Font DIMM might be selected but the
font DIMM is not physically installed in
the printer. (This issue applies only to
printers using an Asian-language font
DIMM.)
In the settings for this printer, clear the Font DIMM check box on
the Configure tab if no font DIMM is installed in the printer. Select
the Font DIMM check box only if the font DIMM is physically
installed in the printer. If you think that the font DIMM is installed,
make sure that it is installed correctly.
The paper curls when
exiting the top output
bin.
The paper needs to print to the
straight-through paper path.
Open the rear output door to print to the straight-through paper
path. Remove each sheet as it exits the printer.
The stack was slightly curled when it
was placed in the tray.
Turn the stack over in the tray.
The paper does not meet
specifications.
See the user guide for information about print-media specifications.
If you are printing on light media, the
Type setting might not be correct.
Select Light in the Type is field in the printer driver.
Nov 13, 2008 | HP LaserJet 1500L Printer
Hp d2360
Uhm, it usually happens when your print cartridge is empty.
Nov 05, 2007 | HP Deskjet D2360 InkJet Printer
91 people viewed this question
k24674
jasbo
jasbo
