Question about Lexus 1999 2000 2001 2002 2003 Is200 Is300 Is350 Horn
I have error codes from p1305 to. 1325 on my lexus 1999
    New Friend:
  • Toyota Expert
  • 83 Answers
Don't see those listed here:
http://ericthecarguy.com/toyota-specific-obd-ii-codes
Posted on Dec 09, 2013
99 Lexus ls400 was in traffic car just died got it
You need a scan tool to check for error codes.
Aug 30, 2014 | 1999 Lexus RX 300
93 Lexus LS400 getting no fault codes from PCM
error code 13 change timing belt rotors water-pump and idler pulley
May 04, 2012 | 1999 Lexus LX470
I have a 1999 Lexus ES300 and I ran an OBD2 code reader on it. It gave me an error code of P1305. Which states Igniter #2 circuit malfunction. Is the igniter the same as the coil? This problem happens...
P1305 Igniter Circuit Malfunction No. 2 (1998-2000 Land Cruiser, 2000 Celica & Tundra)
this code is a toyota code so i would say it means the coil but the generic code says its cylinder no 5
P0305....Cylinder 5 Misfire Detected
so somewhere their is a faulty coil
Mar 22, 2011 | 1999 Lexus ES 300
1999 lexus rx300 check engine light blinking - car vibrates at about 50 mph but if i tuen off overdrive it will stop - got error codes P0125 and P0306
Your 306 code means you have a misfire on cylender 6. That may be the cause of the po 125. Inspecdt the coil, spark plug wire, and spark plug on cylender 6. With the age of the car I would replace all 3 items. If you want know how to test all 3 I can tell you process of elimination is the way to do it. Do you know how to find cylender 6
Oct 15, 2010 | 1999 Lexus RX 300
The VSC and Check engine light turn on for lexus 1999 the cood is p0500
Toyotas and Lexus cars have some unique feaures. If your fuel cap is loose or the O2 sensors on the exhaust are faulty this results in an emission problem and the engine computer unit (ECU) engages the check engine light and disables the VSC (the VSC light comes on to warn you that it has been disabled). However you have p0500 code which says the car has no speed sensor signal. The seed sensor is located on the side of the final drive from the transmission and its job is to measure the speed of rotation of the output shaft. The ECU will compare the signals from this shaft along with the speed sensors in the wheel hubs. If there is a difference between these signals the VSC is engaged to apply braking effort to which ever wheel is slipping (running faster) than the other or that the transmission speed sensor would warrant.
So you either have an emission fault has fed back to the VSC and speed sensor missing (p0500) condition, or you have a faulty sped sensor which has tripped the VSC light and in turn the CEL.
Check your fuel filler cap is on tight, turn radio off and disconnect the negative lead to the battery for 5 minutes (this should clear the ECU memory of the code error). If p0500 error and CEL and VSC lights come back on then check the electrical connection to the speed sensor. Ensure it is clean and making a good contact, check the wiring for continuity. If everything else looks good consider changing the speed sensor.
Sep 14, 2010 | 1999 Lexus ES 300
1999 lexus rx300. fan won't blow. ac light is on
Possibly the connector to the blower unit has been diconnected or is loose.
Apr 13, 2010 | 1999 Lexus RX 300
1999 Lexus ES300
Sometimes it will be written in ownership books in your glove compartment, if not any lexus dealership should be able to give it to you, some dealerships may want you to come in a prove you own the car.
Feb 02, 2009 | 1999 Lexus ES 300
Lexus 1999 2000 2001 2002 2003 Is200 Is300 Is350 Horn Logo
156 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Randy Ohler
ashburton
Colin Stickland
Colin Stickland
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
