Question about Lexus 1999 2000 2001 2002 2003 Is200 Is300 Is350 Horn
Have a problem with my 1999 Lexus the fault codes are p1305 p1310 p1315 p1325 what does this mean
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 50 Answers
I have my 1999 lexus rx 300 that have code p0300, p0171,p1325 and when I'm driving it fast the is hesitating and jumping up I wanna know what to do for that
Po171-bank 1 running to lean
air to fuel ratio not right not enough fuel supply
P0300-random/multiple misfire detected
check spark plugs, HT leads, injectors, ignition coils, low compression, wiring
P1325-no info found code doesnt excist
Nov 29, 2016 | Lexus RX 300 Cars & Trucks
P1300,p 1305,p1310,p1315 how do i fix these fault codes on a Occasionally stall & engine check light on.
You have an at times fault which is loss of spark on all four cylinders. Worse case is the engine control module (quite expensive) so lets keep that for last cause. If it were to fail it would more than likely 100% of the time. Therefore the most likely causes are either a dirty connector or loose ground. See image 1&2 below to uncover coil on plugs. locate connector plugs common to all four plug wires. There are two junction connectors A & B. With key off remove connectors, check for bent pins and spray with DOXIT a radio shack product that is a great No Touch pin cleaner. Replace connectors. One wire from each of the four coil on plug wires leads back to the ECM (Electronic Control Module) Connector A (it is labeled). disconnect and perform same procedure using spray. Reconnect...you'll need to clear codes by disconnecting positive battery terminal for 3 minutes. Test run vehicle to see if troubles have cleared...If not; do you have a multimeter and a wee bit of experience using one? If so put on lowest ohm setting...Hold one terminal on the negative battery terminal...right on the post...Hold the other on bare metal of chassis as in fender...record reading...While holding lead on battery terminal move the other lead to metal of engine block...record readings...Must be close to zero ohms about 1 to 200...If readings are around 2000 ohms the car has an inadequate ground...If so send me a message...saailer@ec.rr.com
May 10, 2015 | 2003 Toyota Corolla
Code p1315
DTC P1315 is Igniter Circuit Malfunction (No.2).
Check No. 2 ignition coil.
See the link below for more information from a 2000 to 2002
Toyota Echo Service Manual.
Diagnostics: Engine: P1300, P1305, P1310, P1315 Igniter Circuit Malfunction (Echo)
Hope that helps.
Sep 19, 2013 | 2001 Toyota Echo
P1300,p 1305,p1310,p1315 how do i fix these fault codes on a Toyota echo 2005.
P1300 Igniter Circuit Malfunction / 14
P1305 Igniter No. 2 Circuit Malfunction / 15
P1310 Igniter No. 3 Circuit Malfunction /15
P1315 Igniter No. 4 Circuit Malfunction
Jan 07, 2013 | 2005 Toyota ECHO
I have a 1999 Lexus ES300 and I ran an OBD2 code reader on it. It gave me an error code of P1305. Which states Igniter #2 circuit malfunction. Is the igniter the same as the coil? This problem happens...
P1305 Igniter Circuit Malfunction No. 2 (1998-2000 Land Cruiser, 2000 Celica & Tundra)
this code is a toyota code so i would say it means the coil but the generic code says its cylinder no 5
P0305....Cylinder 5 Misfire Detected
so somewhere their is a faulty coil
Mar 22, 2011 | 1999 Lexus ES 300
I have error codes of p1300,p1305, p1310, p1315, on my toyota an am looking for the deffinations and issues thse codes create. I have a 2002 tacoma.
P1300 = ignition system malfunction (#1 coil/igniter circuit fault)
P1305 = same as above but #2 coil
P1310 = #3 coil
P1315 = #4 coil
Oct 31, 2010 | 2002 Toyota Tacoma
Occasionally stall & engine check light on.code read p300 misfire
Sent is just now. Let me know if you get it. GLad to help, and Thanks for choosing FixYa!
Nov 19, 2008 | 2000 Toyota Corolla
Lexus 1999 2000 2001 2002 2003 Is200 Is300 Is350 Horn Logo
344 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Randy Ohler
ashburton
Colin Stickland
Colin Stickland
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
