Question about Lexus 1999 2000 2001 2002 2003 Is200 Is300 Is350 Horn
I have a lexus which has got fault codes p1305 1310 1315 1320 1325 could u tell me the faults
It's a Lexus 1999 model all lights are on but my car is losing power
  • Toyota Master
  • 694 Answers
Sounds like multiple cylinder misfires bad coil or coils
Posted on Mar 02, 2014
I have a 1999 Lexus rx300 and a couple months ago the check engine light started blinking. Since then it takes a while for it to accelerate and has no power going up hills. Any thoughts or ideas?
when you get warning lights flashing, I would have thought that you would go to a service shop and have the fault codes read and have the fault fixed
it is what you should be doing now
Jun 02, 2016 | Lexus Cars & Trucks
My lexus es300 1999 model is bring out black smoke from exuast and I have change brain box, air filometer, but it did not stop
Have you checked fault codes? There are so many things that could be causing it, checking and repairing any codes would be a start.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/oscar_403cc49e0f00cda7
Jun 15, 2015 | 1999 Lexus ES 300
How do I fix code 13 engine speed sensor Above 1000 rpm
Clearing the codes is simple that is done by removing the fuse of the EFI from junction box 2 for 10 seconds. Make sure to remove the jumper wire and switch the key off before clearing the codes.
Here are some common Lexus vehicles 1990-1995 codes:
Code 12 and Code 13 Rpm signal circuit fault
Code 14 Igniter signal circuit fault
Code 16 ECT control signal fault
Code 21 and Code 28 Main oxygen sensor fault (for ES300; SC300 & GS300 models)
Code 22 Coolant temperature circuit fault
Code 24 Intake temperature sensor circuit fault
Code 25 and Code 26 Air fuel ratio fault (for ES300 & SC300 models)
Code 27 Sub-oxygen sensor circuit fault (for ES300 CA & GS300 models)
Code 31 Low airflow meter voltage (for ES300 and GS300 models)
Code 32 High airflow meter voltage (for ES300 model)
Code 35 Barometric pressure sensor circuit fault (for GS300 & SC300 models)
Code 41 and Code 47 Throttle position sensor circuit fault
Code 42 Vehicle speed sensor circuit fault
Code 43 Starter signal
Code 51 Switch condition signal fault (for ES300; GS300 & SC300 models)
Code 52 Code 52 and Code 55 Knock sensor circuit fault
Code 71 EGR system circuit fault (for ES300; GS300 & SC300 models)
Code 78 Fuel pump control circuit fault (for GS300 & SC300 models)
Nov 18, 2014 | 1990 Lexus LS 400
Check system light on Lexus 250
Check lights have been on all vehicles for over 30 years,
so what possible question could you have
You didn't check for codes?
Didn't google the codes?
Don't understand the vehicles fault codes?
You do understand you need a repair shop
& professional test equipment to proceed
Mar 05, 2013 | Lexus Cars & Trucks
What is a vsc light
You have a system fault or malfunction that
need to be diagnosed in the VSC function
or that part off the system a code may point you to
Only a trained tech will have an answer to why
something isn't working & only after the problem is found
You won't know what to ask & they won't tell you if you
go to a dealer. A repair shop may work more closely
with you if your in need of knowing alot & I would suggest
you always be part of the solution & educate your self or
else do your vehicle repairs
Sep 04, 2012 | 1999 Lexus Gs 400
I have a 2003 lexus ls 430 my check engine light came on with the vsc off, and exclamtion mark all at the same time and I don't know what that means?
Hi there:
When this comes on as it has it means: When the center differential is locked, VSC control turns off and the VSC OFF indicator illuminates. This is straight from the Lexus diagnostic chart.
The system is faulted in some way so you will need to have the fault memory read out, and then depending on what fault code or codes are stored will determine the type of diagnosis that will need to be performed.
A dealer would be your best bet to get the cause determined. Their scan tool, when hooked up to you vehicle will give them all of the information they need to rectify your condition. After the scan results are found, replacement parts or adjustments can be performed.
Hope this helps.
Jun 04, 2012 | 2001 Lexus LS 430
I have a 1999 Lexus LS-400. Appears to have charging problems (ABS, VSC, & Battery lights on). While running if I disconnect red terminal, car remains running (alternator). Starter checked was OK....
firstly check with your car scanner ,read for fault code, as my experience the alternater fault due to leak in alternator regulator ,check with multimeter for your voltage, at least with light and air con on, it should at least 13.6volt.normally with alternator light on when engine running.conform alternator,replace one thank you
Apr 05, 2011 | 1999 Lexus LS 400
Check Engine light and traction control light stay
there is nothing to do here but have the dealer run a scanner test to see what trouble codes were set with the lights coming on, until then there is no way to tell what the problem might be as there are over 200 possibilities.
Jun 22, 2009 | 1999 Lexus ES 300
2001 Lexus engine check light on VSC off light on
You can actually google this by putting lexus code ### for each one it will tell you what each one means
Jan 27, 2009 | 2004 Lexus LS 430
Lexus 1999 2000 2001 2002 2003 Is200 Is300 Is350 Horn Logo
201 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
ashburton
Colin Stickland
Colin Stickland
jamie suver
Level 1 Expert
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
