Question about Nokia 6300 Cellular Phone
Charging does not work socket needs replacing
Replace the socket :p :D
Posted on Jan 02, 2013
My sons kurio 4s power button doesn't work. I have to plug it into a charger
Check the battery is charged - it may be duff and need replaced if it is not charging or your power adaptor may not be charging it - check it with a multimeter - the power socket on laptops and tablets are very susceptible to damage - if that fails then plug it into a pc using the usb port - it will charge very slowly as usb only has a very low charge current but be patient and if it charges up after 12 hours using the usb method you will know one way or another whether its the battery or the power socket or charger.
May 09, 2014 | Tablets & eReaders
Proscan 7044K-C tablet won't charge
Test your charger with a multi-meter, does it output the correct supply? If not you need a new charger.
If your charger is ok, take a look at the charging socket, is it damaged in any way? Does the charger feel loose when it's plugged into the socket? If so you may need to have your charging socket repaired/replaced.
After checking all this the next thing I would try is a new battery. However, most tablets will at least work from main supply, even if the battery is faulty.
Mar 21, 2014 | Tablets & eReaders
I have android tablet by kocaso and charge cable doesnt make good contact must play with end that goes into tablet to get a good connection
I suggest trying a different cable or charging unit if the cable is integrated into the charger, If that doesn't work, the socket on the tablet is likely to be defective and this problem may get wore with time until the tablet will not charge. Check that the socket in the tablet is not obstructed with dust or fluff; you might try clearing this with canned compressed air.
If the socket in the tablet has become defective it will need replacing and this a difficult job (it may be easier to replace the tablet !) and usually must be undertaken by a trained expert.
Personally, I would welcome an alternative solution to this problem though.
20.April.2014
Jan 27, 2014 | Kocaso 7" Capacitive Touchscreen Tablet...
IPod Touch 4th gen won't charge with from a wall socket
Have you tried different outlets? I have an outlet in my room that won't charge my devices all of a sudden for some odd reason.
Dec 02, 2013 | Apple Audio Players & Recorders
The nokia e71 smartphone does not charge properly i have replaced the battery with a new one yet the problem has not gone away. is there anything else i can do to fix this ?
This phone has a problem with a loose charging socket. With mine, if I hold the plug tightly into the socket it will charge. When I let go it stops charging. The inexpensive solution is to tie a 3 inch rubber band to the charging wire at the plug. When you need to charge, put the plug in the socket and stretch the rubber ban up around the top of the phone. This will keep the plug securely into the socket and it will charge.
Nov 10, 2012 | Nokia E71 Smartphone
My nokia e63 does not charge. I buy new battery but same problem were encountered. What will I do? tnx n good day.
Does work all ok and dont charge? Maybe its broken dc jack connector, or the charger or a fuse inside. Try with usb on pc some nokia can charge from pc.
Jun 30, 2011 | Nokia E63 Cell Phone
The adapter is plugged in but it is not charging what will i do? My battery is 0% and its not charging.How will I use it if I'm not at home.?
The problem is either your charger or the dc socket you need to try the charger first if that doesnt work then your need a new dc socket needs resoldering or replacing
Dec 06, 2010 | Compaq Presario CQ60-220US PC Laptop
It wont come on or charge
Check the power adapter with a multi-meter, the output voltage on the power plug that connects into the power socket of the laptop should be at a voltage slighly higher that the voltage that is printed on the label on the bottom of the adapter. If the voltage reading is low or none at all the the power adapter needs to be replaced.
If the voltage is OK then plug the power plug into the laptop and wriggle this plug in the socket. If the charge LED light flickers on and off and in a certain position the LED light stays firmly on then the power socket on the laptop is either faulty or there is a dry solder joint with the power socket where it attaches to the motherboard. This fault can be repaired but it requires dismantling the laptop completely to get access to the power socket. I sugest you get a quote first.
If connecting the power to the laptop doesn't work then the fault could be a faulty charging circuit/electronics and may require a replacement motherboard.
Sep 20, 2009 | Acer Aspire One PC Notebook
Gateway mx6453 power socket only accepts a clean connection if..
no u just need a dc socket replacement but an expert has to do that using soldering iron
Mar 16, 2009 | Gateway MX6453 Notebook
My phones charging socket doesnt work!
you will need to take the phone to a mobile service center and have them replaced the charging port.....
Oct 07, 2008 | Samsung SGH-E900 Cellular Phone
Nokia 6300 Cellular Phone Logo
19 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
