Question about Campbell Hausfeld MP292000AV 1/4 Inch Series 2 In 1 Style Connector
Driver wont retract
Campbell hausfeld nail gun nb0065. driver does not retract in order to push in next nail.
  • 36 Answers
Check to make sure the head bolts are tight on the top, if they are it probably needs a rebuild kit from campbell housfield includes orings for the piston, gaskets ect. and instructions
Posted on Feb 13, 2009
Does the campbell hausfeld model sb504000 2 inch nailer/stapler need an external air to get started?
Sb504000 works just fine with pressure range from 60 to 120 psi depending on material. Any small compressor will work great. Using the gun at max pressure will shorten the life of the gun. Best practice is to set pressure to just under 100psi for most work and increase pressure when nailing hard wood. Using at max pressure will strain the driver and the lower part of gun (screws that hold nose to body). Some hard woods will bend an 18 gauge nail. Good luck with your gun and have fun with your projects.
Aug 11, 2011 | Campbell Hausfeld 2-in 18 Gauge Brad...
Gun fires, leaves good indentation, no nail. WCE working properly, took head apart to look for jam but nothing in there and am using compatible nails. Also oiled it but no luck. Was working fine doing...
Remove nails and use thin tool to push driver all the way up to top of cylinder. If the gun fires one nail then skips, the driver is not returning to top of cylinder. If no nails fire, then nails are not feeding into proper position. Driver must return to top to allow nails to feed into position. Most common problems are bent driver, worn piston oring and bad batch of nails(head too large). Good luck
Jan 14, 2011 | Campbell Hausfeld 2-in 18 Gauge Brad...
Hitachi nail gun,piston/nail push rod wont retract after pushing nail (stays protruding out of gun so the remaining nails stay underneath it
You have one or more worn o-rings in the head of the gun. They direct the air to the proper parts of the gun to first drive the nail then to return the driver to the top of the gun for the next nail. Depending on the manufacturer and your model number, some companies make kits to replace the o-rings (always replace all of them). For some companies you have to get a breakdown of the gun and order each o-ring seperately.
Oct 25, 2010 | Hitachi Tools & Hardware - Others
Piston blade won't retract
I've had a similar problem and found a nail had broken and lodged itself in the nail housing causing the driver to get stuck forward.
Apr 22, 2010 | Campbell Hausfeld 3 1/2" Rh Fram Nailer
Two nails at a time and one of them only goes in one quarter of an inch.
Campbell hausfeld makes a 21 and 34 degree angle nail gun. The most common mistake is the wrong nails are being used. Some after market nails will not work correctly in some guns. Check to see if the gun accepts wire welded or paper clip nails. Check the angle required. Also be sure the gun is oiled if it is not an oil- less gun. hope this helps.
Jan 11, 2010 | Campbell Hausfeld Air Tools & Compressors
16g wont shoot nails. bottom flat piece comes out
You broke the "hammer" you can open the housing and replace it, fairly simply. You can buy replacement parts at most large scale hardware or tool stores. The task takes about 10 min, and some simple hand tools.
Jan 03, 2010 | Campbell Hausfeld 2" 18GA Brad Nailer
Cambell-hausfeld framer
its double firing, after firing gun pull back, what is happening is when you fire a nail your pushing the gun back onto the wood and its putting another nail in
May 08, 2009 | Campbell Hausfeld 2" 18GA Brad Nailer
Will model no. ifn21950 shoot paslode 2
I would not recommend. Contact Campbell Hausfeld .com and order nails. You could damage your nail driver plunger if not careful. Plead rate . Thanks
Mar 27, 2009 | Campbell Hausfeld Tools & Hardware -...
Campbell Hausfeld NS2190MVRB 21 Degree Round Head Framing Nailer is jammed. How do I clear it?
Remove any nails in the magazine, and you can carefully take a pin pinch of a size that fits into the nose (where the nails come out). Try to carefully tap the driver back into the gun.This will sometimes clear the jambed nail. If the driver is severely jambed you will have to dismantle the entire unit to separate the driver from the nose of the nailer.
Mar 24, 2009 | Campbell Hausfeld Tools & Hardware -...
Campbell Hausfeld MP292000AV 1/4 Inch Series 2 In 1 Style Connector Logo
518 people viewed this question
Top Campbell Hausfeld Tools & Hardware - Others Experts
Rob Bridges
Level 1 Expert
Lawrence Oravetz
 perry tradesman    ...
perry tradesman ...
Level 1 Expert
Are you a Campbell Hausfeld Tool and Hardware - Other Expert? Answer questions, earn points and help others
