Question about Samsung HP-T5064 50 in. Plasma HDTV
Samsung tv turns on and off intermittently - Samsung HP-T5064 50 in. Plasma HDTV
How to fix my Samsung tv ..picture goes in and out intermittently
The inverter board is responsible for the backlight so you can see the picture. If the picture just goes off intermittently then that means that the backlight is being turned off. And since the inverter board powers the backlighting you might want to look there.
Feb 25, 2016 | Samsung Televison & Video
Samsung DLP TV shuts off
sounds like your power supply is going south...check the voltage coming out of the wall first
Feb 25, 2008 | Samsung DLP HL-P5663W 56" TV
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
Tv turns off after approximately 5 hours
Possibly the switch near the lamp housing door, the plastic expands and the switch can switch intermittently, but could be related to lamp life, dust etc. Make sure it's well ventilated and vents are dust free, tape over that switch TEMPORARILY and see if it still happens Fixing Samsung DLP TV that keeps turning off
Jul 16, 2014 | Samsung Televison & Video
My tv (Samsung LE40B620R3W) keeps turning off intermittently
Check ur Sleeping timer modes,see it is not on like 30,60,120 mins?If ur Sleeping timer modes is off.Than ur tv power supply board is the causes and the problems,it not consistinly giving ur tv the right voltages anymore that why ur tv it turning off intermittently.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jan 13, 2011 | Samsung LE40R74BDX 40 in. LCD Television
I HAVE A 50'dlp SAMSUNG TV-HL-S5087W THAT TURNS OFF
probably a bad (intermittent) control board.
Nov 14, 2009 | Samsung HL-S5087W DLP TV
Samsung 50'' Plasma Turns off and on intermittently
This model is known for power board issues. You used to be able to get the repaired. its probably easier to buy a used one.
check ebay or www.RNS-Systems.com
Oct 16, 2009 | Televison & Video
Unit intermittently makes the TV flicker the sound and picture.
I would be checking and trying new leads from the antenna part of your telly to where they go into the wall , we had a problem with a new tv that used to turn itself off and on we got the tv replaced with another new one and it still did it . it turned out to be a faulty cable from the pay tv box on top of the telly as they emit FM waves just like the radio and it was sending signals to the remote on the tv to turn it off
May 17, 2009 | Samsung HT-WX70 Theater System
Samsung HDTV DLP high pitch wine, intermittent
Your color wheel is broken you can get one at partstore.com.
Aug 12, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung PCK5315RX TV turns off
you tv problem is intermittent have a tech resolder you tv circuit.also have him check the power supply you could be having problem with the component there.probably the regulator diode or cap.good luck
Aug 01, 2007 | Samsung PCK5315RX TV
Samsung HP-T5064 50 in. Plasma HDTV Logo
81 people viewed this question
Henry  Thomas
Henry Thomas
