Question about Philips 55PP9363 55" Rear Projection HDTV-Ready Television
Tilted tv screen
Recently purchased tv got it home picture was fine no tilting previous owner said might be wise to convergence the tv. so started to. numerous crosses off slightly so had an idea to restore factory settings, big mistake, soon as i hit the button the tv screen tilted clockwise 1.5 to 2 inches. now i dont know what to do iwant to fix it because it drives me crazy. any and all help is greatly appreciated.
  • Anonymous May 22, 2008
    same thing, I did the convergence, picture is awesome... just the stupid tilt...
  • 398 Answers
The complete convergence for the Philips projection sets usually requires a clear plastic overlay which fits over the screen and has many precisely spaced black dots. The remote is then used to enter the service mode and converge all 3 colors onto the dots, and then the settings are stored in an EPROM IC. This should only be done by someone with experience with the Philips sets.
Posted on Jun 28, 2007
SOURCE:
Generations 9316G TV Mount Won't Tilt
The installers did not anticipate you would be wanting to tilt the TV upward so did the usual.
Apr 14, 2017 | Televison & Video
Picture is slightly tilted
Its an easy adjustment but it requires you to work around the deflection yoke on the neck of the picture tube. Above the yoke is a red connector that is carrying 30,000 volts then on the yoke itself you have wires that are connected to the horizontal and vertical circuits that can carry up to a 1200 volt pulse. So this alignment is not for anyone but a technician. I personally would leave the tilt until you can have a technician touch it up for you. Take a moment to rate my answer. Thanks...
Nov 20, 2009 | JVC AV-32FA54 32" TV
Hitachi 53uwx10b Convergence Grid Tilted A Little...
If the tilt is not that bad, I would leave it be. The reason is yes you can straighten the tilt out, but it requires a mechanical alignment to all 3 CRT's then you will have to align the convergence on all 3 as well. Please take a few moments to rate my answer. Thank you.
Nov 18, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Problem after replacing convergence board
Yes, you do need to set up the convergence in order to get the picture geometry correct. the antenna and maybe some other settings will need to be restored through the appropriate user interface screens. You will need your owners manual for a guide.
Jul 12, 2009 | Samsung HCM4215W 42" Rear Projection...
Philips Rear projectoion tv picture not clear
no its not true, you can lay them flat to move, it sounds like the convergence is out of whack, download the owners manual and redo the convergence manually for the red and blue, then go back and do the same for the multi point convergence for the red and blue, also if the color looks muted or flat, the projector lenses might need to be cleaned as well as the mirror in side of the unit.... very easy to do, just use caution and DO NOT SPRAY ANY LIQUIDS INSIDE THE UNIT.... spray the cleaning rag outside the unit the wipe off the mirror and lenses....i got this same TV free from craigs list here in pa, put a new mirror in because the original was shattered and re did the convergence and this TV pic is AWSOME.... very crisp and clear...hope this helps you
Feb 23, 2009 | Philips 43PP9202 43" Rear Projection...
The picture in the screen is not straight/level
I have an older Toshiba 36inch. My manual has a topic called Tilt correction. This procedure will compensate for any local magnetic field differences which cause the image to tilt. My topic is listed in the Index under "T". See if your manual has this.
Feb 05, 2009 | Toshiba 36HFX73 36" TV
1080i connection has green hue
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 09, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Tilted Screen
Yes, there is a tilt adjust,but you should have service manual to guide you....it requires some diassembly / access in back of set.....................T.
Dec 20, 2007 | Samsung HC-R4755W 47" HDTV
Skewed picture
Convergence problem.
Dec 11, 2007 | Televison & Video
Screen Tilted and Convergence Off
dawgs79. I have the pdf files for the tv. I own the same one. I can send then to you. It shows the factory settings etc ans how to adjust it.
Aug 30, 2006 | Panasonic PT-47WX49 47" Rear Projection...
Philips 55PP9363 55" Rear Projection HDTV-Ready Television Logo
98 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
