Question about Exercise & Fitness
How do you change Proform ZE9 batteries - Exercise & Fitness
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: proform ZE9 eliptical screen blanked out evry thing else works
Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replacethe left and right disc shields and side shields. Reattach the ends of thepedals to the crank axles.
Posted on Nov 15, 2011
Changing Batteries For Fan
TM5-015I-2N Precor 240v How can I get this repaired ?
Dec 05, 2013 | Proform XP 580 Trainer Treadmill
Proform pro 4500 freezes
adjust the REED switch, test it, clean it, and tight the plug or connector very well.
2) Replace the new batteries, with the same type, same marks, and the same polatity
3) clean the contacts batteries spring, with c. cleaner from some electronic store.
4) Tigtht the ribbon cable inside from control keypads.
5) Try to RUN the software calibratin for easy diagnose, troubleshooting and fix it.
God bless you
Nov 28, 2012 | Proform Sport 1000 Folding Treadmill...
Proform xp 70 stationary bike console is not getting power
IF BATTERIES ARE NEW THEN CHECK THE CABLE AND CONNECTION FROM BATTERIES TO THE CONSOLE.MAKE SURE ALL CONNECTION ARE TIGHT AND CABLES ARE NOT BROKEN,FRAYED,CRACKED,OR CORRODED LOOKING.ALSO MAKE SURE SAFETY DEVICES(KEYS,PINS,CLIPS) ARE IN PLACE .
Oct 13, 2012 | ProForm 70 Perspective Treadmill
Proform Crosswalk display will not work. Belt and incline work fine. Have changed batteries, adjusted reed switch to within 1/8
adjust the REED switch, see the diagram for to do it. clean, and tight the connector very well.
God bless you
May 11, 2012 | Proform Crosswalk Ls Treadmill Walking...
Will not change resistance
"Locked in" as in no speed control? The control devices on the motor speed control likely have failed.
If the batteries are in the upper module, a cord may be unplugged or damaged down to the speed control board. Those batteries are primarily for the display head.
Jan 23, 2012 | Proform Exercise & Fitness
Proform ZE9 eliptical screen blanked out evry thing else works
Nov 15, 2011 | Exercise & Fitness
After replacing batteries on Proform PF800 console stays lit
Pull the batteries out let it reset itself while its doing that check all cable to make the connection are seated firmly then reinstall the batteries, unless the function pad is sending a phantom signal engaging the display to be on continuously,or by pure chance the upper electronics went hay wire
Apr 09, 2010 | Proform PFTL79807 - 850 W/ Gamefit...
Exercise & Fitness Logo
32 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
