Question about LG 47LH50 47 in. HDTV LCD
42LG60 tv - 4 yrs old - horizontal lines like interference - checked all connections and cables
Flickering on screen - seems to have happened when we changed provider to Verizon FIOS - tried the DVD and still get the lines
  • 39 Answers
SOURCE: Permanent horizontal line approx. 4" from top of screen
if this line is in the picture, that is possible burn in screen. if you have a black bar at the top or faint white lines that come down from top this is caused by defective filters in vertical circuit or bad vertical output. mch
Posted on Feb 20, 2009
  • 267 Answers
SOURCE: vertical purple lines appear when watching tv but not dvd
You unit should be under warranty. contact the manufacture for the nearest authorized servicer.
Posted on Jun 26, 2009
phil_frye
  • 295 Answers
SOURCE: The screen on my 4 yr old 42 inch LG plasma keeps
I believe that you are experiencing an intermittent problem with what's called your florescent lamp ballast. The best thing is that it can be repaired/fix. There should be a LG repair shop in your area. Cheaper to bring it in than have a service tech come to your residence.
Should be between $200 to $300 for a repair.
Blessings,
A/V Media Guy
Posted on Nov 22, 2009
  • 10 Answers
SOURCE: picture on all channels is dark
seems like its the inverter thats either not working or the tubes are faulty
Posted on Mar 27, 2010
  • 1779 Answers
SOURCE: I have a 1 year
Yes, return it ASAP. Defective Plasma Display Panel.
Posted on Nov 29, 2010
Why do I have rolling horizontal lines on my hitachi big screen t.v.?
Need the model number of the Hitachi which should be listed n the rear cover. I should be able to assist but will need the Model Number to determine which chassis design you have.
Apr 02, 2013 | Hitachi Televison & Video
Goast dark line running from top to bottom of screen...tv was 2.5 yrs old when started
what type of tv and also check cables like the RGB, AV cables if you are using them, it sounds like interference or maybe a/c hum noise
Dec 14, 2010 | Philips Televison & Video
My tv has thin black horizontal lines on screen while showing picture. this is not caused by cable since it happens while using ps2 or dvd player. I recently moved, but it was working fine after the...
that could be a sign of a bad panel. my experience is that these panels are more expensive than the tv itself, but might be worth looking into since I've heard about prices coming down
Mar 27, 2010 | Philips 42FD9954 42 in. Plasma HDTV
Bottom of screen flickers, and eventually the screen 'freezes'
they have problem lines in tv screen harizontall lines how i can fixed in HDTV prima 29inch.2008 model .give me ANSWER .
Jan 17, 2009 | Prima CV2011 TV
Line on the Picture Screen
panel t-con parts n/a will most likley be replaced.
Nov 03, 2008 | Protron PLTV-32 Television
Horizontal Lines scrolling on screen
I had a similar issue with my Mitsubishi HD 1080. My power supply went out, I had it replaced and it works like new. However, just today I had AT&T U-Verse installed. When the cable guy was showing me the new HD channels all seemed good. This evening (about 5 hours after being installed) I started seeing these horizontal lines across my screen. The picture was still HD quality, but those annoying lines just wouldn't go away. Anyway, after reading a few blogs on-line suggesting interference or bad grounding, it hit me!!! The AT&T guy who installed my U-Verse (cable, internet and phone) had set the modem on top of my TV!!! It was just starring at me this whole time. So I removed the modem off the top of my TV and put it on a side table just to see what would happen and sure enough the lines were gone!!! You may not have the exact same problem, but it may be some type of interference (cell phone, modem, etc, either on top or around your TV that is causing the issue... Hope this helps. Thanks.
Oct 31, 2008 | Televison & Video
Green line down left side and geen snow
Horizontal or vertical bars on the screen could be from an ac line interference, adjacent magnetic field, bad input wire connections.....especially HDMI connector cables. A bad HDMI cable causes all kinds of unwanted picture interference. Check the conditon of all connection wires for proper fit and function. Keep in mind the method in which you connect your tv will result how the tv performs. As well this line problem could be a circuit issue too, requiring a technician to look at it.
Jul 23, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
After a household power blips during bad weather, we have horizontal lines ....
Unfortunately there isn't any way to repair your tv as the magnet has distorted the tube that is in the tv and with CRT becoming obsolete the repair is likely to be very costly so probably your chaepest option is to buy a new tv .
Mar 13, 2008 | Televison & Video
Sony tv kv-32fv300
you probably aren't checking this posting out anymore, but maybe someone else will see this and it can help them.
i was having the same problem, did a search and found this solution. worked like a charm!! go here:
http://www.floggingenglish.com/2008/07/22/diy-tv-repair-fixing-screen-flicker-on-a-sony-hd-wega/
Nov 24, 2007 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Flickering crispy screen
maybe ur screen was put into a lot of magnetic interference. so check for any magnetic rays emitting devices like speaker adapters etc. a simple check would be to degauss( its in the screen properties). raja
Feb 28, 2007 | LaCie Electron IV 19" CRT Monitor
LG 47LH50 47 in. HDTV LCD Logo
262 people viewed this question
Computer Repairing
Computer Repairing
