Question about Vector Power on Board 500 Watt Power Inverter with USB Charging Po
I HAVE A VECTOR 500 WATT INVERTER, MODEL VEC067CP0B, S/N OFK27N108263 THAT SMOKED WHEN FIRST USED. I BOUGHT IT IN 2008 BUT USED IT FOR THE FIRST TIME DEC 25, 2012. CAN U HELP ME WITH A SCHEMATIC OR SOLUTION TO THE PROBLEM. I HAVE IT DISSASEMBLED NOW.
  • BD WATT Jan 01, 2013
    PROBLEM IS, THERE WAS NOTHING PLUGED INTO THE INVERTER, SO NO LOAD ON IT. THE FAN WORKED, BUT SMOKE CAME OUT OF THE UNIT.
    THANKS
SOURCE: Puff of smoke
yes u got da inverter overloaded out puts r gone 2hot and fan couldnt cool it enough now this inverter basicly a amplifier amp does da same problem when da out put r blown yes i got da unswer
Posted on Mar 03, 2009
  • 7 Answers
SOURCE: I have a 400 watt vector inverter prower on board
yes if this is close to mine there is a cover over 2 feuses on the back
Posted on Jul 05, 2009
SOURCE: my vector power inverter needs to be reset
Inverters use high power transistors to create an A/C voltage from a D/C input. These transistors are the common point of failure when the units are not cooled properly or used beyond their rated capacity. (Actually, you should always buy an inverter that’s rating for continuous use is well below what your actual need is). What’s most likely happened is that these have shorted out and need to be replaced. Unfortunately, replacement parts alone will likely cost nearly what a new unit costs.
Sorry to be the bearer of bad news; but you basically have a nice paperweight with some pretty lights and fans on it.
Posted on Aug 15, 2009
nitrospawn
  • 290 Answers
SOURCE: Vector vec 051D 3000 watt fan won't run anymore, unit overheats
your inverter needs to cool at all times , if the fan does not work,try buying a small standing fan to blow cool air to you machine, it is possible that your heater is making the inverter to over heat please avoid using the heater on the inverter
Posted on Feb 27, 2010
  • 608 Answers
SOURCE: vector 2500 watt inverter red led fault light no
There is a fuse on these things at the back of the case. Could be in a slide out plastic holder, or in a round holder with a knurled screw or bayonet type cap. If this fuse is not blown, then the news is not good.
Posted on Mar 21, 2010
Manual for black and decker 1200 watt invertor
some idea for inverter, collect inverter circuit Books from market.
May 28, 2012 | Black & Decker Vector Cable Kit for 1200...
Need to know what size fuse how many amps and volts for this device.
Rule of thumb for 12vdc to 120vac inverters is 1 amp of fuse for every 10 watts of power. So, this one would use a 7 amp fuse.
Jul 06, 2011 | Inverter Vector Power - 70 Watt, Model...
With the vector 2000 watt converter do you need to run 2 batterys.
well unless you bought the 24 volt unit no one battery will run the unit, according to black and decker this unit is not being made, did you buy it new or at a yard sale?
one way to tell is look on bottom of unit, it will tell you if it is 24 or 12 volt model.
Mar 06, 2011 | Black & Decker Vector MAXX SST Series,...
Plugged it into the recepticle in my2009 trailblazer, and it started smoking. removed it quickly
Hello Dusty,
Sounds like your inverter was already having issues. Otherwise, the power port in your trailblazer is wired backwards (center contact should be positive, barrel or ring should be negative).
Aug 26, 2010 | Inverter Vector Power - 70 Watt, Model...
Vector 3000 watt model VEC051D
Time for a new inverter. Lesson learnt I dare say.
Check polarity!
Sep 05, 2017 | Vector 3000w
Bought a new vector maxxsst 1200 watt inverter
Inverter run on batteries sir, and if these batteries are not charged, the run time {the number of hours it will work} reduces.
S0, you will need to connect the inverter to a power source.Theses will allow your batteries to be charged and enable it to run for a long period of time.
Make sure your batteries are still OK.i.e working properly
May 03, 2010 | Vector ® Maxx SST 1200 - watt Power...
When I switch the power on the inverter, it squeals briefly and then shuts down.
Two possible problems; input voltage too low, or the output load too high. If input remains at 12v or higher and it shuts off with no load, then the inverter is bad.
Mar 19, 2010 | Vector 750-watt Power Inverter Power...
Feb 26, 2009 | Vector VEC056 MAXX Power Inverter
I think my inverter burned.
it depends on what burnt in it, you should check it out to know
Jan 13, 2009 | Vector VEC 024 400-Watt Power Inverter...
Puff of smoke
Have you looked at the fuses within? I have two in the one I am trying to fix!!
Peter
Nov 19, 2008 | Vector VEC056 MAXX Power Inverter
Vector Power on Board 500 Watt Power Inverter with USB Charging Po Logo
71 people viewed this question
Top Vector Electronics - Others Experts
Matt Olenzek
Matt Olenzek
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
