Question about Sony VAIO PCV-RS310 PC Desktop
Instructions on how to replace the motherboard on a Sony Vaio PCV-RS310
2 Suggested Answers
  • 25 Answers
SOURCE: Instructions on how to replace the motherboard on
Hello halhoffer, the link to the system reference manual can be found here. Just click on system reference manual, this is just in case you run into any complications in this process. First off when replacing the mother board, if you plan to use the same components from your old desktop, make sure they are all compatible with the new motherboard. For instance, your old motherboard uses DDR(1) ram, if the new motherboard only accepts DDR2or3 then you can't use your old ram. That being said, here's the process in a nutshell.
1) Ground yourself (always important when you start working on a computer, static electricity can ruin components)
2) Open case
3) Remove the parts from the motherboard that can be removed. This includes disconnecting everything from the power leading to the motherboard so you can remove it freely. The ram sticks will need removed (push the tabs outward and they should pop out smoothly). If you plan on re-using the same processor, you will need to remove the heat sink/fan that is on top of it and carefully remove the processor, however if this is the course of action you are going to follow. I would recommend doing a little research because removing and re-using CPUs (Processors) can be one of the most difficult things when it comes to switching out computer components and if done improperly can cause damage. If you have any cards in the slots, poking out the back of the computer, unscrew them so you may remove them. If you are going to use the same case for the new motherboard, then you can leave the hard drives and cd/dvd drives in, but remove their cables from the motherboard so that you can remove it.
4) Once the motherboard is no longer attached to anything else inside the computer, you can unscrew the screws that should be found throughout the motherboard that are holding it into the case. Once all are unscrewed it should pop out with little to no resistance.
5) Pretty much everything in reverse to install the new motherboard. Screw it in, if it's the same motherboard model, simply plug all the cables back into where they were and re-seat the cards, CPU, and ram sticks. If it's a different model, it will come with an installation manual that will have everything labeled on it so you know where everything goes.
Hopefully this helped you with your problem, good luck with the project and have a great day halhoffer!
Posted on May 16, 2011
Pcv-rs310 video controller
Try this http://esupport.sony.com/perl/model-home.pl?mdl=PCVRS310
drivers and software..Or you can click on support and scroll down you will see vaio detect my computer
Apr 14, 2013 | Sony VAIO PCV-RS310 PC Desktop
I wiped out the dvd and cd driers on my son pcv-rs310
Uninstall both of the drives from Device Manager located under My Computer and then scan your computer for new changes it should detect the drives and it will install the driver itself hopefully you are using win 7 or vista it will install the driver itself.
Jul 20, 2012 | Sony VAIO PCV-RS310 PC Desktop
Everything is small
either change your resolution, or change right click and go to personalize and change the settings there for icons
Jun 23, 2012 | Sony VAIO PCV-RS310 PC Desktop
I wiped the drive on a sony pcv rs310 desktop. I cant access bios , and nothing comes up on monitor. nota nothing blank. I cant get OS to install or monitor to even blink
I assume you tried hitting the delete key while it was booting. Also you need to use a keyboard that is NOT usb. The usb drivers were deleted during the format. The pc will probably not boot if it does not see a keyboard. Also make sure you are not using a usb hub and remove all usb devices. Disconnect all devices except keyboard and mouse and monitor and try again.
Thanks for using FixYa
Jun 21, 2011 | Sony VAIO PCV-RS310 PC Desktop
2) Open case
Apr 26, 2011 | Sony VAIO PCV-RS310 PC Desktop
What video card comes with this computer?
IntelĀ® 845GV Integrated Graphics
64MB max. Dynamically Shared Graphics Memory
Jan 02, 2011 | Sony VAIO PCV-RS310 PC Desktop
I would like to set my Sony Vaio PCV-RS310 back to factory setting. Please help.
Hi and welcome to fixya,
After making a back up of your most important files, restart the computer and press F10 to start the recovery console. Follow the instructions on the screen and it should take you to a Full Factory Setting..
Hope this helps
Where do I find replacement motherboard for Sony
hi.. please check the back plate of your branded asus case.. if its same from the clone computer you can change if not.. its better to buy clone unit cause some parts of your pc desktop could be use...
regards
Mar 17, 2010 | Sony VAIO PCV-RX403N PC Desktop
Sony VAIO PCV-RS310 PC Desktop Logo
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
